Manix 2 G10 advice
Curtis
Manix 2 G10 advice
Postby Curtis » Mon Aug 31, 2020 6:38 am
Hi,
Had my Manix 2 G10 for a few months now and I have noticed a slight amount of play in the blade in the open/locked position. Is this normal? My Tenacious by comparison has no play whatsoever. Thanks in advance.
Re: Manix 2 G10 advice
Postby Wartstein » Mon Aug 31, 2020 7:29 am
Welcome to the forum! :)
I don´t have a G10 Manix, just a lightweight, but this one has no blade play at all, and I have used it quite a bit.
Do you experience side to side or up and down play (for addressing the former you could try and tighten the pivot screw a bit)?
RustyIron
Postby RustyIron » Mon Aug 31, 2020 8:04 am
Like Wartstein suggested, you might need to adjust the pivot screws a little. This is part of regular maintenance for those who want a knife to be spot-on perfect. Of course this only applies if the play is side-to-side.
If the play is up and down... well... that seems rather odd. If that's the case, I'd hose it out with some kind of aerosol cleaner with a nozzle. There might just be goop in there.
TomAiello
Postby TomAiello » Mon Aug 31, 2020 8:08 am
That's not normal. Have you adjusted the pivot? I can create that blade play by loosening the pivot, but tightening the pivot fixes it. And you don't need to loosen the pivot that far to create a drop free action--it's possible to have a nice free swinging blade with zero play.
I'd suggest tightening the pivot a little at a time and rechecking as you go.
Albatross
Postby Albatross » Mon Aug 31, 2020 8:19 am
Like others have said, the pivot is a likely cause. You might want to check the body screws as well. Sometimes a loose body screw can affect the tightness of the blade.
sal wrote:
Fri Nov 09, 2018 3:01 pm
...But in general, I'm all about high performance, Ergos, safety. That's why I've been accused of "deigning in the dark"...
razorburn
Postby razorburn » Mon Aug 31, 2020 8:18 pm
There should be absolutely no vertical blade play, unless it's a clone.For horizontal play they do have some.
Postby Sharp Guy » Mon Aug 31, 2020 10:34 pm
...For horizontal play they do have some.
Hmm...I just checked all mine (7) and only one LW model had a little side-to-side play. I tightened the pivot a little so the blade closes with a little wrist flick. It's now as solid as all the others
TomAiello
Postby TomAiello » Tue Sep 01, 2020 9:49 am
Interesting thought. I wonder where the OPs knife was purchased.
soc_monki
Postby soc_monki » Tue Sep 01, 2020 1:45 pm
I think my Manix 2 (G10) has a little side to side play, but I haven't checked in a while and haven't tried to tighten the pivot. It's so inconsequential I don't even worry about it.
Spyderco : Resilience, Tenacious, Persistence, Manix 2 G10, Para 3 G10, Para 3 LW, Paramilitary 2,
BBS Paramilitary 2, Amalgam, Native Chief, Blade HQ Manix 2 XL, Shaman, Gayle Bradley 2, DLC M4 Shaman
Kershaw : Tone, Thermite, Atmos, Natrix 7007cf, Natrix 7008cf, Bareknuckle 7777, Bareknuckle 20cv, Concierge, 7777CFM390 Bareknuckle
Zero Tolerance : 0566CF, 0770CF, 0770GRYBW, 0562CF, 0470, 0456CF, 0095BW, 0801TI
Ontario : Rat 1
CRKT : Caligo
Civivi : Plethiros, Baklash, Incite, Vexer
Cold Steel : AD10, 4Max Scout, SR1 Lite
Benchmade : 810-1401 Contego, 15080-2 Crooked River, 15080-Custom Crooked River, 560BK-1 Super Freek, 15085 Mini Crooked River, 15085-Custom Mini Crooked River, 940-2, 550-1 Griptilian, 950bk Rift, 940-1, Custom Sheepsfoot Griptilian
Buck : 110, Bucklite 422, 110 LT, 110 Slim Select, 112 Slim Pro, Custom 110, 1978-79 110
Artisan : Tradition
Hogue : Ritter RSK MK1-G2
Kabar : Becker BK2 Campanion
Hinderer : XM-18, XM-24
Users browsing this forum: Bing [Bot], Holland, jacala, Majestic-12 [Bot] and 24 guests
cron
