Para 3 clip issue with tip down carry
bhoff
Post by bhoff »
Not sure what happened to my first post regarding this but here it is again. I've had my para 3 for a while now and have been running it fine with the stock tip up carry position without issue. However, when attaching the clip in the tip down position I run into two problems. If the clip is attached on the side of the pivot screw the action goes from a free drop to being so stiff that even flicking the knife heavily with the wrist will not open it. When the clip is attached on the other side only two of the three screws are able to contact the liner with the third one not screwing in and falling out. Not sure if anyone has run into issues such as these but any information would be great.
