The lock tab sits in the cutout notch in the tang and that provides the detent.
Probably much easier to machine a little hole compared to a large cutout that has to be milled.
sal wrote:Knife afi's are pretty far out, steel junky's more so, but "edge junky's" are just nuts.![]()
Man I can get behind this. I think that Sal mentioned somewhere Eric is working on it.araneae wrote: ↑Fri May 15, 2020 10:45 pmEverything good about the paramilitary got better in the P2. The Para 3 took those refinements and made it more compact. The para 3 lightweights solved the issues I had with the g-10 version, the clip placement and the somewhat blocky handles. I'm probably done buying g-10 variants and I'm expecting a P2 lightweight will materialize sometime soon.
CQI sets Spyderco apart from a lot of other companies. Simply making a good knife and then calling it a done deal isn't their way, but that's how most of their competitors work. There's almost always room for improvement, but each generation, a Spyderco knife tends to have noticably less room for improvement than the previous version.
Probably one of the (few) points where we DON´T agreekennethsime wrote: ↑Sat May 16, 2020 10:13 amMan I can get behind this. I think that Sal mentioned somewhere Eric is working on it.araneae wrote: ↑Fri May 15, 2020 10:45 pmEverything good about the paramilitary got better in the P2. The Para 3 took those refinements and made it more compact. The para 3 lightweights solved the issues I had with the g-10 version, the clip placement and the somewhat blocky handles. I'm probably done buying g-10 variants and I'm expecting a P2 lightweight will materialize sometime soon.
I picked up a Manix 2 LW recently and while it's a great knife, my biggest takeaway is that I can't wait for a Para Military 2 Lightweight.
