My modified Manix 2 XL (Quarantine Project)
Matt David
Postby Matt David » Sat May 02, 2020 11:26 am
So, out of all the knives that I own, my Manix 2 XL had my favorite blade design. You just can’t beat the sliceiness of broad FFG blade. However, I always felt like the handle was a little to broad for my hand. My favorite handle design in my collection is hands down the Emerson CQC-8 (not a huge fan of the blade though), so I decided to combine the two. While I was at it, I decided to throw a Benchmade style Axis lock on it as well. Here is the result, it’s now my favorite knife of all time lol What do you guys think??
P.S. Because this is an amalgamation of designs that aren’t mine, I won’t be selling this, making anymore, or sharing CAD drawings with anyone.
SkullBouncer
Re: My modified Manix 2 XL (Quarantine Project)
Postby SkullBouncer » Sat May 02, 2020 3:09 pm
Wow -- great design and build from two great knives into one and separately employing the different strengths / qualities of each.
Congrats on a Job Well Done!
SB / BRUCE
Surfingringo
Postby Surfingringo » Sat May 02, 2020 3:23 pm
Tight work Matt!!
JRinFL
Postby JRinFL » Sat May 02, 2020 3:36 pm
Now that the prototype is done, maybe we can get Sal and Ernest to sign off on the collaboration model? Very nice work!
Used to be JR in CT with a much earlier join date. :rolleyes: :spyder: Native in 440v was my gateway Spyderco! :spyder: Wharnie for the whin! Friends call me Jim. As do my foes.
Postby TkoK83Spy » Sat May 02, 2020 3:45 pm
That's very impressive work! Great job. Looks like taking a chance worked out!
20 :spyder:'s in 11 different steels
2 - ZT's - 0460 and 0470
1 - Microtech Ultratech DE OTF
1 - Civivi Elementum
Postby kennethsime » Sat May 02, 2020 3:48 pm
Very nice! All cut on a CNC? I take it you don't use the choil much?
I've always thought that the CBBL was pretty darn similar to the axis lock. I know that one uses a caged ball bearing with a central spring, and the other uses a perpendicular bar with two "omega springs," but otherwise how do they differ?
Lost to the Ages: C90GRE Stretch 1 ZDP-189 British Racing Green | C28GRE2 Dragonfly 2 ZDP-189 British Racing Green
C12BK2W Matriarch 2 VG-10 Emerson Open | C81G2 Para Military 2 S30V
Currently Rotating: C81GPRGR2 Para Military 2 K390 Ranger Green | C223GPRGR Para 3 K390 Ranger Green
C90FPIV2 Stretch 2 Straight Spine, VG-10 Rit Dye'd Dark Apple Green | C223GP Para 3 S30V Green Canvas Micarta
C41BORE5 Native 5 Lightweight REX 45 Burnt Orange | C223BORE Para 3 Lightweight REX 45 Burnt Orange
C101GY2 Manix 2 Lightweight Maxamet Gray | C28GFG Dragonfly VG-10 Foliage Green
MT27 Mule Team 27 Micro-Melt PD#1 Ranger Green | C36GPGR Military 204p Dark Green
SkullBouncer
Postby SkullBouncer » Sat May 02, 2020 3:51 pm
And BTW --- Welcome to the Forums............now get to work on the Next One!! :) :p
- BRUCE :cool: :cool:
Postby PeaceInOurTime » Sat May 02, 2020 4:32 pm
Great work! I'm jealous.
Matt David
Postby Matt David » Sat May 02, 2020 5:01 pm
I've always thought that the CBBL was pretty darn similar to the axis lock. I know that one uses a cadet bass bearing with a central spring, and the other uses a perpendicular bar with two "omega springs," but otherwise how do they differ?
Thanks! and yes, it was all cut on my homemade CNC router. As for the two locks you're right, they are similar with a couple important differences. There are the in-your-face differences you mentioned, but a couple others too.
1. Axis lock bar reacts against liner - CBBL reacts against a steel bar.
2. Axis lock bar also acts as the stop pin for closed - Manix stops against the same steel bar.
3. Axis lock has completely independent stop pin for open - Manix uses same steel bar.
4. Axis locks require liners to cover the pocket housing the "omega" spring. - Manix only is lined for strength, and the compression spring is housed in that same steel "bar". 1 part, 4 functions = good engineering.
#2 was very important for me because i needed the blade to close further than the Manix was designed to, had to modify the blade slightly to work.
I should mention mine isn't quite an axis lock, I made my liner out of 7075 aluminum, this was easier on my machine and required to get the balance right at the front of the choil. The down side to doing this is i can't have the lockbar react against aluminum, it would wear out in no time. If you look at picture #6 you will see I added a steel bar above the lock that acts as both a stop pin for open and a surface for the lockbar to slide on and react against when locked open. I also nested the liners just because they were aluminum, I didn't want them getting dinged up over time being exposed.
Postby Wartstein » Sat May 02, 2020 5:02 pm
My 2 cents, if I may:
For me CBBL and Axxis lock are pretty different, and I much prefer the former - not because this is the Spyderco lock, but for some practical reasons (they are technically different too of course)
- The Axxis lock has a much weaker detent, an Axxis lock knife (Minigrip) is the only folder that ever came open in my pocket and cut me (twice). On the flop side I think the CBBL is the second strongest Spyderco lock concerning detent, right after the backlock
- I much prefer that the CBBL takes a bit more force when operating it. The Axxis lock is cool, but somehow feels like a "toy CBBL for kids" in use. TOO easy to operate
- The Omega springs do breal eventually in my experience - did so twice on my Minigrip.. Though I have to say: Benchmade provided great customer serivce, did send me replacement springs for free (from the US to Europe) and installing these is pretty easy.
Postby Wartstein » Sat May 02, 2020 5:06 pm
Great work, which I would never, ever be able to do myself! :)
And it took a long time for your second post.. the first one was in 2018 (just looked that up), and also about a great project (tip up Millie mod)
But may I ask: Why did you switch to an Axxis lock? (Not a criticism, just a question, though I personally prefer the CBBL by a lot)
VooDooChild
Postby VooDooChild » Sat May 02, 2020 5:08 pm
Cool.
sal wrote:
Thu May 28, 2020 8:14 pm
... "The edge is a ghost"...
Matt David
Postby Matt David » Sat May 02, 2020 5:36 pm
Thanks! I switched locks because I needed the lock to close further than the Manix. One way to do this would be to just have the blade point down a little more than the Manix, but I REALLY wanted the blade to come out straighter. Basically the clearances just weren't there, I would have had to make a compromise somewhere anyway, and I just like the feel of the axis lock, so why not just make the compromise there and move on. That's pretty much it lol
It came with some headaches though, which was pretty much all having to do with the spring design and manufacture. I've got a repeatable processes now though, so if my custom springs ever break I can just make new ones quick.
Matt David
Postby Matt David » Sat May 02, 2020 9:54 pm
Sorry for the slow responses guys, I've only posted once before so the mods still need to approve everything. I've been poking around this forum all day though and there are some super knowledgeable people on here! Definitely will be sticking around and posting more in the future. Thanks for the warm welcome everyone!
gundamaniac
Postby gundamaniac » Sat May 02, 2020 10:03 pm
That is some impressive work there! Great execution!
Knivesinedc
Postby Knivesinedc » Sat May 02, 2020 10:20 pm
The Manix XLS! (Xtra Large Slim) Beautiful work my friend. I am very much a fan. Looks super comfortable to hold.
BLJace
Postby BLJace » Sun May 03, 2020 1:15 am
*whistles* That there is a pretty, custom piece. Very jealous of that one!
:spyder: I used to collect a lot of knives... I still do, but i used to too. :spyder:
ChrisinHove
Postby ChrisinHove » Sun May 03, 2020 9:05 am
Very nice! Well done!
hovan2yourknives
Postby hovan2yourknives » Sun May 03, 2020 7:53 pm
Great work and love those springs! Definitely look stronger than omegas. The only thing I’d suggest (if it doesn’t effect the functionality of the lock) is to grind and shape the remainder of the forward choil on the blade.
Bill1170
Postby Bill1170 » Sun May 03, 2020 8:03 pm
Good points, Wartstein. I also prefer the more positive closed blade retention of the CBBL. Likewise, the coil spring durability is a highly desirable feature.
Users browsing this forum: BaronRadium, cbrstar, DTPrime, elena86, GrandallK, Ratamaque, tonijedi and 68 guests
