Micro Serrations
alnico357
Micro Serrations
Postby alnico357 » Tue Mar 24, 2020 3:56 pm
Yesterday I used a Lansky Puck to put a course grind edge on my carry Delica. I mainly slice stuff and don't shave with it. I think it is going to be my preferred method. :) Just a thought.
Re: Micro Serrations
Postby sal » Tue Mar 24, 2020 7:43 pm
Hi Alnico,
Welcome to our forum.
The question of micro serration has been a discussion for the the past 50 years that I have been in the knife industry. Some say they don't exist and some say they do.
This should be an interesting discussion.
Pancake
Postby Pancake » Wed Mar 25, 2020 1:40 am
Like, there is a difference between your edge finish. You can notice if you have like 220 grit finish or 2000 grit finish. If you try to slice your finger along the edge, 220 grit edge is going to bite more then 2000. But, there is this misconception that low grit finish is not sharp, that is pure BS, you can have shaving sharp edge of someting like DMT X coarse and it will have so much raw agression during a slicing cut.
But again, regular serrations, full Spyderedge is going to blow even the coarsest of finish out of water.
Postby Evil D » Wed Mar 25, 2020 5:08 am
So when I sharpen my SE Caribbean on CBN rods I have micro serrated serrations. It's like SE inception :D
Seriously though that combo will cut anything. Give it a try. I like to strop mine on my Goldenstone sheath edge. If you don't right it'll still shave hair but is still toothy and aggressive.
Ruudr
Postby Ruudr » Wed Mar 25, 2020 5:28 am
I also depends what kind of steel you use. A steel with a lot of carbides performs most of the time better with a coarse finish. I believe Scienceofsharp.com has a nice article about it.
Pancake
Postby Pancake » Wed Mar 25, 2020 7:07 am
Sadly I dont have any CBN or diamonds rod....
Postby Evil D » Wed Mar 25, 2020 7:14 am
I wish I could find the old Edge-U-Cation about serrations that was on the website back in '05 when I got my SE Native, it basically explained that serrations had micro serrations. I don't recall exactly how it was worded but it sold me on SE way back then so whoever wrote it needs a raise.
bearfacedkiller
Postby bearfacedkiller » Wed Mar 25, 2020 7:28 am
I like a finish around 600-800 on my folders and outdoor knives. Sometimes as low as 1200.
Kitchen knives will often get a much finer edge.
Sumdumguy
Postby Sumdumguy » Wed Mar 25, 2020 7:39 am
My Caribbean comes away far "sharper" from the brown rods, than it does the whites. Perhaps there is some validity to the micro serration theory.
Postby Evil D » Wed Mar 25, 2020 7:55 am
Have you done the full grit profession brown/fine/UF? If I take the time to let each one polish out the grit from the previous rod and then strop, I get ridiculous edges. There's nothing like serrations that tree top hair off your arm without touching skin.
soulspy
Postby soulspy » Wed Mar 25, 2020 9:06 am
I like a toothy edge. Mirrored edges look nice, but those "micro-serraations" cut like a dream.
Pancake
Postby Pancake » Wed Mar 25, 2020 11:59 am
Hey David, I was thinking about ultra fine stones, just for kicks. I only have one SE H1 blade, but it can get pretty sharp of the fine rod, but I always need some stropping to get that slicing edge. Are the ultra fine worth it?
Postby Evil D » Wed Mar 25, 2020 12:59 pm
Well I wouldn't say they're "essential" but I definitely see a difference when I use them, and I like having the whole Sharpmaker set just so I can do any steel and any edge finish I want.
soc_monki
Postby soc_monki » Wed Mar 25, 2020 1:14 pm
Setting the bevel with the diamond rods (30 degrees) or on my 325 grit diamond stone, and then putting a microbevel (40 degrees) with the brown stones leaves an edge that will pop hair if you just glide the blade along your arm, but will slice through pretty much anything with very little effort. To me it is a much better edge than fully polished, but I don't really do any push cutting. If I were push cutting all day a polished edge would work for me.
As it is, coarse bevel with a slightly higher grit microbevel. Works for me. Everyone at work is amazed at how sharp my knives are. I am too lol!
Spyderco : Resilience, Tenacious, Persistence, Manix 2 G10, Para 3 G10, Para 3 LW, Paramilitary 2,
BBS Paramilitary 2, Amalgam, Native Chief, Blade HQ Manix 2 XL, Shaman, Gayle Bradley 2, DLC M4 Shaman, Magnitude
Kershaw : Tone, Thermite, Atmos, Natrix 7007cf, Natrix 7008cf, Bareknuckle 7777, Bareknuckle 20cv, Concierge, 7777CFM390 Bareknuckle
Zero Tolerance : 0566CF, 0770CF, 0770GRYBW, 0562CF, 0470, 0456CF, 0095BW, 0801TI
Ontario : Rat 1
CRKT : Caligo
Civivi : Plethiros, Baklash, Incite, Vexer
Cold Steel : AD10, 4Max Scout, SR1 Lite, SRK
Benchmade : Contego, Crooked River, Custom Crooked River, Super Freek, Mini Crooked River, Custom Mini Crooked River, 940-2, 550-1 Griptilian, 950bk Rift, 940-1, Custom Sheepsfoot Griptilian
Buck : 110, Bucklite 422, 110 LT, 110 Slim Select, 112 Slim Pro, Custom 110, 1978-79 110, 119
Artisan : Tradition
Hogue : Ritter RSK MK1-G2
Kabar : Becker BK2, BK10, Dog's Head, BK7
Hinderer : XM-18, XM-24
Sumdumguy
Postby Sumdumguy » Wed Mar 25, 2020 2:18 pm
Not yet. I generally do brown, then white, if necessary. I have Diamond rods, but I haven't had to use them on much.
I'll be upgrading my sharpening setup eventually.
Mike Blue
Postby Mike Blue » Wed Mar 25, 2020 2:25 pm
If photos can't prove the case that grit scratch marks are equal to microserrations, then we need someone with a much better camera rig to take photomicrographs.
Postby Evil D » Wed Mar 25, 2020 2:39 pm
I've seen lots of very very high magnification pics of edges that basically look like the ridge of a mountain top. The more coarse the edge finish, the more jagged the ridge is and visa versa. There are certainly teeth of some sort, whether or not the closely resemble what we think of as serrations is debatable. Those jagged teeth still manage to cut despite being...jagged, as opposed to a high polish edge where the ridge is very crisp and smooth and far less jagged.
Mike Blue
Postby Mike Blue » Wed Mar 25, 2020 3:05 pm
Some single point has to break the surface tension of the material being cut somewhere along the edge. Mulitple points make that begin sooner. The balance between polished edge and a toothy feel may well be completely subjective. I can understand an art chef wanting a polished edge so that the food bits are nearly transparent. I can also understand the second line cooks wanting a toothier edge because all that prep work won't get done without one.
Stuart Ackerman
Postby Stuart Ackerman » Wed Mar 25, 2020 11:22 pm
I will do some pics of a Serrata and a Sustain side by side...both at 400 grit...and then both at 1000 grit, as soon as I can find my digi-scope?
The magnification will be the highest I can crank it, hopefully?
Postby kennethsime » Wed Mar 25, 2020 11:41 pm
Looking forward to this.
Lost to the Ages: C90GRE Stretch 1 ZDP-189 British Racing Green | C28GRE2 Dragonfly 2 ZDP-189 British Racing Green
C12BK2W Matriarch 2 VG-10 Emerson Open | C81G2 Para Military 2 S30V
Currently Rotating: C81GPRGR2 Para Military 2 K390 Ranger Green | C223GPRGR Para 3 K390 Ranger Green
C90FPIV2 Stretch 2 Straight Spine, VG-10 Rit Dye'd Dark Apple Green | C223GP Para 3 S30V Green Canvas Micarta
C41BORE5 Native 5 Lightweight REX 45 Burnt Orange | C223BORE Para 3 Lightweight REX 45 Burnt Orange
C101GY2 Manix 2 Lightweight Maxamet Gray | C28GFG Dragonfly VG-10 Foliage Green
MT27 Mule Team 27 Micro-Melt PD#1 Ranger Green | C36GPGR Military 204p Dark Green
Users browsing this forum: Bing [Bot], FullFlatMind, Google [Bot], Granoo Fink, Majestic-12 [Bot], Pancake, pkennethv, tangent, tbdoc4kids and 45 guests
