Lil Manix
Doeswhateveraspidercan
Re: Lil Manix
Postby Doeswhateveraspidercan » Thu Mar 12, 2020 4:59 pm
Neat idea but I do not find anything in the Manix line I actually like except for the XL.
aaronkb
Re: Lil Manix
Postby aaronkb » Thu Mar 12, 2020 5:52 pm
I’d buy one
Sumdumguy
Re: Lil Manix
Postby Sumdumguy » Thu Mar 12, 2020 6:35 pm
I'll put up my blast shield in advance of this idea.
If the CBBL won't work on a small one...
Compression lock?
*ducks*
Spydergirl88
Re: Lil Manix
Postby Spydergirl88 » Thu Mar 12, 2020 6:39 pm
Compression lock?
*ducks*
I support this idea too
Sal Glesser wrote:
These are not leggos.
Team Wire Clip
:spyder: :spyder: :spyder: :spyder: :spyder:
JuPaul
Re: Lil Manix
Postby JuPaul » Thu Mar 12, 2020 6:44 pm
Theldraskien wrote:
Thu Mar 12, 2020 4:42 pm
based on my experience with the Manix XL I think it may also be habituation to the opening method. I found it really difficult to unlock the XL one handed when I first got it, but after a couple of days practicing it was no problem. I don’t think it had anything to do with the spring lightening, I think it was my fingers getting stronger.
I definitely had to get the trick of opening the cbbl. In fact when I first got one I didn't like it for that reason. But once I figured out how to hold it and use the pocket clip for some leverage, I came to love it. I sold my lightweight for that reason, though. With the frcp scales I just couldn't get as good of a grip. I might give it another shot with the rex45 model if I can get one. Not sure, though.
- Julia
JMM
Re: Lil Manix
Postby JMM » Thu Mar 12, 2020 9:42 pm
With the CBBL viability question in that small of a platform -- what about using the bolt lock (Sage3)? It's absolutely wonderful for that size of knife. Just a thought..
Re: Lil Manix
Postby kennethsime » Thu Mar 12, 2020 9:52 pm
I support it! The Manix never really felt great to me; very "locked in" if it fits your hand perfectly, but I always felt my hands were too large for it. At any rate, I'm all about the XL/Mini iterations of already-great knives, because I'm OCD and like things that match.
Speaking of, I'm still looking out for a 3" Straight Spine Stretch and Dragonfly. :-)
Lost to the Ages: C90GRE Stretch 1 ZDP-189 British Racing Green | C28GRE2 Dragonfly 2 ZDP-189 British Racing Green
C12BK2W Matriarch 2 VG-10 Emerson Open | C81G2 Para Military 2 S30V
Currently Rotating: C81GPRGR2 Para Military 2 K390 Ranger Green | C223GPRGR Para 3 K390 Ranger Green
C90FPIV2 Stretch 2 Straight Spine, VG-10 Rit Dye'd Dark Apple Green | C223GP Para 3 S30V Green Canvas Micarta
C41BORE5 Native 5 Lightweight REX 45 Burnt Orange | C223BORE Para 3 Lightweight REX 45 Burnt Orange
C101GY2 Manix 2 Lightweight Maxamet Gray | C28GFG Dragonfly VG-10 Foliage Green
Pancake
Re: Lil Manix
Postby Pancake » Fri Mar 13, 2020 12:59 am
Not for me.
Manix is already small for my taste.
On belt: Bow River, Waterway
rabbitanarchy14
Re: Lil Manix
Postby rabbitanarchy14 » Fri Mar 13, 2020 2:15 am
i have been asking for this for a long time and have started threads asking for this. i want one in 3" or 2.75-2.8".
everyone just told me to grind down a good manix, no. i would like one made that size with the cbbl.
and just to say again this is around the perfect size of accaptable. a normal size knife is 3.125" ish.
and just because there are people who say that it is too small just have compensation issues. if you have a reason for work to use a bigger knife fine but carrying a massive blade makes all knife holders look bad wipping out a huge 3.5 - 4" blade as though its a weapon, no you dont look kool you make us all look bad.
In-Possession - Para 3 S35VN, Para 3 G10 M390 Red, Dice XHP, Lil Native S30V comp B, Manix 2 M390 G10 BR, PM 2 M390 DLC BL, PM 2 K390 RG, MKM Voxnaes Isonzo N690, Benchmade 555HGBlu, Ontario Rat 2 Gr G10
On-Deck - Manix 2 DLC ?, Brouwer, Lil Native compression 20CV/M390
Loved Steels - M390/20CV, S35VN, BD1N, XHP, S30V, N690, K390
BLJace
Re: Lil Manix
Postby BLJace » Fri Mar 13, 2020 3:57 am
Compression lock?
*ducks*
I love the idea of a mini manix, but if we add in the compression lock aren't we coming close to a mini shaman?
actually... i want a mini in both.
:spyder: I used to collect a lot of knives... I still do, but i used to too. :spyder:
Pancake
Re: Lil Manix
Postby Pancake » Fri Mar 13, 2020 4:21 am
I could write down a long response, but I am going to write just this: Just because you have a opinion, it is not going to make everyone else with different opinion wrong. That is very childish approach to a discussion.
I wish you could get a Mini Manix.
Re: Lil Manix
Postby Evil D » Fri Mar 13, 2020 4:27 am
For about a year straight I struggled between which I preferred, the Manix 2 or Para 2 and ultimately it came down to ergos and lock differences. What I realized about the M2 is that you need to be able to plant the butt end of the handle into your palm in order to get enough leverage to pull back the lock cage. I suspect this is why we've never seen anything bigger than the XL with a CBBL. So, going the opposite way, I think a smaller Manix 2 handle would make it even easier to operate the lock since it would be easier to palm the handle to get that leverage. This is an area where the compression lock is a significantly easier to operate design.
Sumdumguy
Re: Lil Manix
Postby Sumdumguy » Fri Mar 13, 2020 4:33 am
Compression lock?
*ducks*
Not even slightly. The Shaman and Manix are wildly different designs, regardless of lock type.
curlyhairedboy
Re: Lil Manix
Postby curlyhairedboy » Fri Mar 13, 2020 4:53 am
Based on models such as the lil native and the ikuchi, I think it's apparent that the lock size and packaging concerns for the compression lock are a lot more friendly to smaller knives than perhaps the CBBL. What's interesting is the ceramic BL has seen use on smaller knives before. Maybe there's a way to fit a cage around that so you don't have to dig in a finger?
EDC Rotation: PITS, Shaman, CF S90v Shaman, Ikuchi, Amalgam, CruCarta Shaman, Lil Native, Sage 5 LW, Ouroboros, 4V Shaman, Watu
Always in Pocket: Hawkbill Dragonfly 2 H1
Special and Sentimental: Southard, Smallfly G10, Squarehead LW, Calendar Para 3 LW, 40th Anniversary Native
Would like to own again: Sheepsfoot Caribbean
Wishlist: CQI Kapara, Tanto PM2, Shaman Sprints!
jdw
Re: Lil Manix
Postby jdw » Fri Mar 13, 2020 10:20 am
I wish that we would see some small autos out of Golden.
--Wovoka
Notsurewhy
Re: Lil Manix
Postby Notsurewhy » Fri Mar 13, 2020 2:22 pm
Not sure how well the ergos would scale down on the manix design, but I'd love to see some smaller cbbl knives. I prefer the cbbl to the compression lock and think it is seriously underused.
Sumdumguy
Re: Lil Manix
Postby Sumdumguy » Fri Mar 13, 2020 2:29 pm
I'm Notsurewhy. :P
Notsurewhy
Re: Lil Manix
Postby Notsurewhy » Fri Mar 13, 2020 2:50 pm
I'm Notsurewhy. :P
The first step toward knowledge is admitting ignorance.
Some day I'll make it to step two :D
kodai78
Re: Lil Manix
Postby kodai78 » Fri Mar 13, 2020 2:56 pm
I have 2 Manixes a LW and a second that had the swirly brown and black slabs with a big void in them that I swapped some aluminum scales onto. Neither was especially stiff at any time that I recall. Certainly the scale swap one was never difficult to operate. That said I would love a mini with a wire clip and G10, the LW is a nice knife but I prefer my cutting tools to feel denser in hand.
:spyder: Smock, Baby Jess Horn CE, Spydiechef, Schempp Bowie,Ti Fluted Military, Titanium Military, Native S30 V and G10, PM 2 in S35VN, and S110V, Manix 2 LW BD1, Sage 5, Positron black CPM S30V, Chaparral w/Raffir Noble scales, SuperLeaf VG 10, Ladybug H1, Dragonfly 2 in ZDP 189 and Superblue/420J1 and H1, Delica in ZDP 189, Clipitool Standard, the Cook’s knife VG10, Santorum, paring and utility knives, all in MBS 26. :spyder:
Re: Lil Manix
Postby Mushroom » Fri Mar 13, 2020 2:59 pm
If this type of knife ever happened, the ergonomics around the pivot virtually wouldn't change. The primary changes would be to blade length and handle length. It wouldn't be a "scaling down", but more of a "trimming off."
This is how the Para 3 was derived from the PM2 and how the Lil Native was derived from the Native 5. They maintain the same ergonomics in the pivot section and adjust the front end of the blade and the back end of the handle.
- Nick
:spyder:
Users browsing this forum: Bing [Bot], DougC-3, Featherblade, Google [Bot], ladybug93, spyderwolf and 20 guests
