Best torx wrench set
JuPaul
Postby JuPaul » Wed Mar 04, 2020 6:42 am
I wasn't sure if I should post this here or in off topic...
Anyhow, I want to upgrade my torx wrench set. I don't want to spend an obscene amount of money, but I'd like a quality set. What kinds are you all using for your spydie maintenance?
- Julia
FK
Re: Best torx wrench set
Postby FK » Wed Mar 04, 2020 6:48 am
Wiha,,, not too $$$, excellent quality.
This is what Spyderco customer service uses..
Regards,
FK
Albatross
Postby Albatross » Wed Mar 04, 2020 6:50 am
I've been using Wiha and have zero complaints. From what I've seen, they're widely regarded as being the "best". I can't confirm this, but I alao haven't stripped a screw since getting the set either. They can be purchased individually, which is great if you only ever need a t8 and the occasional t10. The set my wife got me is a 6 piece and costs about $25 on Amazon.
sal wrote:
Fri Nov 09, 2018 3:01 pm
...But in general, I'm all about high performance, Ergos, safety. That's why I've been accused of "deigning in the dark"...
Postby TkoK83Spy » Wed Mar 04, 2020 7:04 am
I got this one around 6 months ago, I've used it quite a bit and have no complaints. Though lacking the T9 bit is a bit odd, I haven't needed it and thankfully have a cheaper set in that has one if ever needed though.
https://www.knifecenter.com/item/BO09BO ... bit-driver
Currently have 18 :spyder:'s in 11 different steels. Constantly adding and purging!
curlyhairedboy
Postby curlyhairedboy » Wed Mar 04, 2020 7:04 am
Wiha for stationary sets, and i've had a very good experience with these for carrying in my pocket for adjustments:
https://www.harborfreight.com/7-pc-mni- ... 97469.html
they definitely work better than you'd expect. well-hardened and well machined.
EDC Rotation: PITS, Shaman, CF S90v Shaman, Ikuchi, Amalgam, CruCarta Shaman, Lil Native, Sage 5 LW, Ouroboros, 4V Shaman, Watu
Always in Pocket: Hawkbill Dragonfly 2 H1
Special and Sentimental: Southard, Smallfly G10, Squarehead LW, Calendar Para 3 LW, 40th Anniversary Native
Would like to own again: Sheepsfoot Caribbean
Wishlist: CQI Kapara, Tanto PM2, Shaman Sprints!
GarageBoy
Postby GarageBoy » Wed Mar 04, 2020 7:07 am
Wiha
The husky multi bit one works in a pinch
Pancake
Postby Pancake » Wed Mar 04, 2020 7:25 am
Wiha.
I have one small set from Boker with Wiha bits, best 15 € I spend on this hobby
On belt: Bow River, Waterway
Kels73
Postby Kels73 » Wed Mar 04, 2020 7:30 am
I use a Wheeler Fat Wrench on my guns, and I really like it. Admittedly though, I've never used it on knives, so I can't comment on that.
Dazen
Postby Dazen » Wed Mar 04, 2020 7:48 am
This is what I use most of the time.
Wright.88
Postby Wright.88 » Wed Mar 04, 2020 8:31 am
BONDHUS, 12632, T6-T25 GORILLA GRIP FOLDUP TORX TOOL SET https://www.amazon.com/dp/B000E7ZLHQ/re ... xEb5T613GH
I’ve had one of these for years and have never stripped a torx screw or any of the tool heads. It’s not the most ergonomic though if you’re using it often.
Also use a leatherman bit kit from my wave and extender which has worked really well.
Rinzler
Postby Rinzler » Wed Mar 04, 2020 8:36 am
Same here except I'm using their microbits. The micro bits are surprisingly strong and wiha makes good tools.
JuPaul
Postby JuPaul » Wed Mar 04, 2020 8:52 am
I actually have that Gorilla foldup set, but I want to stick it in my car for days like yesterday when the clip screws on my Smock wiggled loose. And I've got a little set of bits from benchmade. Looking for a new second set for home since it's nice to have two when you need leverage from both sides. Looking like Wiha for the win!
- Julia
steelcity16
Postby steelcity16 » Wed Mar 04, 2020 9:21 am
I am a big tool junkie and have everything from Snap On to Wiha to Wera to Witte to Felo to Vessel to Bonhus to Harbor Freight! But for drivers and bits I have found PB Swiss to be the best there is. Expensive but totally worth it. Definitely go for the bits and bit holder. Much cheaper to replace a bit than a screwdriver! And the Crosshandle Driver is perfect for knives with loctite. It allows you to turn the driver while applying constant downward pressure so you will likely never strip a screw if you do it right.
https://www.shop.pbtools.us/SwissGrip-S ... 10-30M.htm
https://www.shop.pbtools.us/PB-C6-400-1 ... s_c190.htm
steelcity16
Postby steelcity16 » Wed Mar 04, 2020 9:31 am
Harbor Freight gets a bad rap, but a lot of their stuff is just as good as the expensive brands. Made in the USA is nice in theory, but I have found Made in Taiwan to be nicer in quality than USA Made stuff in many cases, and I purposefully seek out USA Made things where possible.
These Pittsburgh Professional Screwdrivers are an insane value. They are rock solid drivers, and well hardened and machined as you said. I've had drivers from Wera and Wiha round where these things just keep going. Read the reviews if you don't believe me.
https://www.harborfreight.com/8-piece-p ... 94607.html
these are also fun for beater drivers!
https://www.harborfreight.com/8-piece-b ... 94899.html
DSH007
Postby DSH007 » Wed Mar 04, 2020 10:00 am
I have the Bondhus Gorilla Grip as well. It's a nice tool.. as you mention, it's great on the go.. I stick it in my bag when travelling just in case anything comes loose. I find that it is also really useful compared with skinny-handled tools when you need to get some leverage on the more stubborn screws..
I also have a Wiha set that sees a lot of use. Like a lot of others, I highly recommend Wiha. I don't think you'll be disappointed with any of their sets..
Rick H.
TomAiello
Postby TomAiello » Wed Mar 04, 2020 10:16 am
I've actually had better luck with PB Swiss than Wiha. I've stripped a couple Wiha bits. The PB Swiss driver makes it easier for me to keep strong, even pressure on the bit while I'm turning it.
Postby The Deacon » Wed Mar 04, 2020 10:20 am
Wiha definitely has the reputation for quality, but I've had good results using all three of these sets. The Home Depot Husky set has seen the most use, and has yet to bugger a screw or damage a bit. Lowes Kobalt set works well too, but offers less grip. Unless you're working on one of the very small knives that need a T3 driver, any of these will work for you.
Postby kennethsime » Wed Mar 04, 2020 10:25 am
I used to have the Husky multi-driver, but recently graduated to this Wera set that I've been quite happy with.
I went Wera over Wiha for two reasons:
  • I like the handle swell for extra purchase, and
  • I like green :cool:
Lost to the Ages: C90GRE Stretch 1 ZDP-189 British Racing Green | C28GRE2 Dragonfly 2 ZDP-189 British Racing Green
C12BK2W Matriarch 2 VG-10 Emerson Open | C81G2 Para Military 2 S30V
Currently Rotating: C81GPRGR2 Para Military 2 K390 Ranger Green | C223GPRGR Para 3 K390 Ranger Green
C90FPIV2 Stretch 2 Straight Spine, VG-10 Rit Dye'd Dark Apple Green | C223GP Para 3 S30V Green Canvas Micarta
C41BORE5 Native 5 Lightweight REX 45 Burnt Orange | C223BORE Para 3 Lightweight REX 45 Burnt Orange
C101GY2 Manix 2 Lightweight Maxamet Gray | C28GFG Dragonfly VG-10 Foliage Green
bearfacedkiller
Postby bearfacedkiller » Wed Mar 04, 2020 10:27 am
Been using the husky for years and it hasn’t buggered up a screw yet.
Postby Sharp Guy » Wed Mar 04, 2020 10:31 am
Wiha
Yep! I have both. I primarily use the Wiha set but keep the Husky one in my desk drawer to occasionally snug clip screws etc
