Manix rex 45 chips
Manix rex 45 chips
So this was my first real investment in a knife and intro to spyderco. It's a beautiful knife.
This is the first day I got it and I cut some canvas that had some dried glue in it on top of a wood surface. This took off a small piece of the tip, small enough to be sharpened out. Later I cut through that packaging that's cardboard and plastic molded around the product (that evil stuff). I cut in a downward motion and didn't touch anything that wasn't packaging. This left a small chip on the blade. Again, small enough that it can be sharpened.
Is this a factory edge problem that will go away with sharpening? Or should I be worried that I got a bad one? I can post zoomed in pictures if anybody wants.
- VooDooChild
Re: Manix rex 45 chips
Im thinking/hoping factory edge should be the issue. Considering how much people have beat on other rex 45 spydercos, as well as hap40 and other stuff, then it seems like it shouldnt be chipping like that.
I used the **** out of my REX PM2 factory edge last year with no issues
Sure sounds like a factory edge issue. It's my understanding that rex45 has pretty great edge stability. Fingers crossed because I bought that knife, too!
- Julia
My Rex 45 shaman chipped pretty bad on staple in one of those plastic double sided clam shells. I sharpened out some of it before giving up, figured it's a user anyways.
Just kind of waiting to see as I bought 2 of the pakawood rex 45 shaman and scored a orange manix. I have a love hate relationship with my toku-v (awesome edge yet scratched to ****).
So upon looking at it further, the part of the blade that chipped has quite an uneven grind, one bevel is almost half the size of the other. I'll update when its re profiled if I can do it.
I've used my Para3 Rex45 really hard, harder than any other Para3 I own, and I have been using the TreeRex pretty heavily since I got it, I have never seen or actually heard of what you're describing with Rex45 -- I certainly haven't experienced it with the old run or new run of Rex45, I have a Manix2 in Rex45 coming today (fingers crossed) or Monday, I will certainly keep an eye out for what you're describing. Can you capture it in a picture by chance?
I cant figure out how to upload images directly, but here's an imgur album. Hopefully that's ok.JMM wrote: ↑Sat Feb 29, 2020 3:23 pmI've used my Para3 Rex45 really hard, harder than any other Para3 I own, and I have been using the TreeRex pretty heavily since I got it, I have never seen or actually heard of what you're describing with Rex45 -- I certainly haven't experienced it with the old run or new run of Rex45, I have a Manix2 in Rex45 coming today (fingers crossed) or Monday, I will certainly keep an eye out for what you're describing. Can you capture it in a picture by chance?
http://imgur.com/gallery/KXoXmFE
They're quite small, but from what I have seen, I dont think it should be acting like this. Notice between the first and second picture, the factory bevel is pretty uneven. Maybe that's causing issues?
I am betting after a couple complete sharpenings you won’t have this problem anymore.
My Shaman came with a little burr, which I removed with a couple passes on a coarse DMT stone and some strops, before using the knife. Since then, I've used the edge to scrape rust off a part, prying staples out of cardboard(which tested the edge further) and the edge has come into contact with multiple solid objects, with enough velocity to chip or roll most other steels. So far, no edge damage.
This is why I always give a brand new knife some edge love before using it.
Usually a burr or wire edge is the culprit. Hopefully you get it figured out and can enjoy your knife.
I've learned to never, ever judge a knife steel from its factory sharpened edge.
It doesn't surprise me that little bit of tip broke off.
I think that chip was caused by something the rest of the blade did not come in contact with.
The rest of the edge still looks pretty ragged.
With continued sharpening and use, I bet it holds up much better, that's been my experience anyway.
I didn't see a wire edge, but of course I only paid attention after it was used. Tomorrow I will be reprofiling and sharpening it, then I will test it again on similar cutting tasks and update you guys. Hoping it's just a factory edge goof.
I'm happy to update everyone that after removing 1.5 - 2 full sharpenings worth of material, the edge and tip are both holding up to semi abusive tests. I stuck the very tip in wood and tried to flick up chunks of wood and the tip is still micro pointy. Cut some hard wood and tried to pry the edge to try to snap it, and it's still shaving hair. I even put a pretty ugly edge on the thing as I'm new to freehand sharpening.
Thanks for the input guys! It seems like they did well with this sprint run other than my factory edge.
My Rex45 Manix2 arrived yesterday and it needed a bit of love out of the box, but after a couple minutes with the brown, then white on the ol' sharpmaker, it's absolutely on point. Wooooohooo!
Cheers,
John
Cheers,
John
Very good to hear! Thanks for reporting back.Npm wrote: ↑Tue Mar 03, 2020 12:22 pmI'm happy to update everyone that after removing 1.5 - 2 full sharpenings worth of material, the edge and tip are both holding up to semi abusive tests. I stuck the very tip in wood and tried to flick up chunks of wood and the tip is still micro pointy. Cut some hard wood and tried to pry the edge to try to snap it, and it's still shaving hair. I even put a pretty ugly edge on the thing as I'm new to freehand sharpening.
- Julia
