Spyderhole corrosion
I think the spyderhole is the best in regards for deploying a knife but mine has orange rust specks in it (vg10) is this normal?
Re: Spyderhole corrosion
I would not call it normal, but VG10 can rust as pretty much any steel but H1 can... have you tried "Bar Keepers Friend"?
If I buy used, I find the Spyderhole is the first place to corrode. If there is any corrosion on a blade, 9/10 it seems that it will be found in the Spyderhole as well. I think it’s the lack of polish, but even then, I have seen polished Spyderholes (Taichung models for example) that have rust or oxidation.
Maybe the hole is prone to trapping moisture while in the pocket?
I think that the person I got it from on eBay sold it as new but it could have been used as it didn’t come with the oil on the blade like the one I got from a trustworthy seller. It seems to have corroded in the liners and spyderhole whilst my other delica has not had a speck of rust. I’ll try bar keepers friend thanks.
- The Deacon
Are you sure it's rust? Sometimes the heat from the laser causes orange/brown discoloration on the inside of the Spyderhole.
Take a bit of mineral oil and rub it on it, it should come right off.Fright_Fox wrote: ↑Tue Feb 18, 2020 11:04 pmI think the spyderhole is the best in regards for deploying a knife but mine has orange rust specks in it (vg10) is this normal?
-Thomas Jefferson
-Thomas Jefferson
It's an easy place for it to form, being rough it'll collect crud and moisture. I always clean mine up with a Dremel anyway because I like the edge of the hole to be sharp.
- araneae
A qtip and powder cleanser will take care of whatever it is.
-Nick
Last in: N5 Magnacut
-Nick
Normal. The inside of the hole isn't finished as well as the rest of the knife so is more likely to rust. Comes off easy as others have said.
