SE for cutting CPVC
SE for cutting CPVC
Hi everyone, new to the forum, somewhat new to Spyderco.
I deal with a lot of CPVC piping for work, I service fire protection sprinkler systems. My usual tool for cutting this pipe is a hackzall, but pipe hidden in ceilings sometimes doesn't have space for me to fit the hackzall in. There's also the issue with water getting into my hackzall (r.i.p) that's become a bother.
With that being said, I'm looking at a small knife with a SE that can handle cutting up to 2" cpvc in emergency circumstances. My initial thoughts was a dragonfly 2 salt, but I don't know if it's enough knife to get the job done. Any ideas?
Just a quick synopsis of what I'm looking for in this particular application
-edc
-salt
-full SE
-strong enough to cut through CPVC
Thank you!
-edc
-salt
-full SE
Thank you!
Re: SE for cutting CPVC
Hi CalRob,
Welcome to our forum.
While I don't have any personal experience in cutting plastic pipe, I don't think that a serrated edge would work for your needs. I think they could eventually get through a pipe, but because they do not remove material, I think it would be very slow. I'm curious to see what the folks here have to say or have experienced.
I agree with Sal. I think a small folding saw would suit your needs better.
Welcome to the forum!
- Connor
Thank you for the warm welcome.
I suppose a part of me just wants an excuse to buy another Spyderco!
I've been using a smaller hacksaw in a pinch, but I still find it slightly cumbersome, and I have to go to my toolbag every time I need it. It'd be nice to have something light in my pocket that could theoretically handle the situation in a pinch.
I'll continue looking for options, and might get the Dragonfly 2 SE salt just to have. Or maybe I'll take one for the team and see how it works in practice and report back.
Part of my occupation is working on irrigation for turf, golf courses to be specific. I would use smaller hack saws or even a PVC Pipe Cable Saw. Not a serrated knife. We make use of the cable saws alot on our PVC for our golf course irrigation and they are a life saver for tight areas or extremely rocky soils. Less time removing soil/rock to fit a shovel or hacksaw is important. I could see how cable saws could benefit your occupation as well. I hope this helps you! I personally would only be using a knife for de-burring the open end of a cut on the PVC. Hacksaws and cable saws generally have very small serrated teeth for a reason as well they will be much faster as Sal has stated.CalRob wrote: ↑Mon Feb 17, 2020 9:54 amHi everyone, new to the forum, somewhat new to Spyderco.
-edc
-salt
-full SE
Thank you!
I'll look into some pipe cable saws! Didn't even know a tool like that existed. Thank you for recommendation.
Like the other guys said, a serrated knife just gets wedged instead of cutting. A saw is what you need so you can remove material.
- steelcity16
FreeGolf wrote: ↑Mon Feb 17, 2020 10:23 amPart of my occupation is working on irrigation for turf, golf courses to be specific. I would use smaller hack saws or even a PVC Pipe Cable Saw. Not a serrated knife. We make use of the cable saws alot on our PVC for our golf course irrigation and they are a life saver for tight areas or extremely rocky soils. Less time removing soil/rock to fit a shovel or hacksaw is important. I could see how cable saws could benefit your occupation as well. I hope this helps you! I personally would only be using a knife for de-burring the open end of a cut on the PVC. Hacksaws and cable saws generally have very small serrated teeth for a reason as well they will be much faster as Sal has stated.CalRob wrote: ↑Mon Feb 17, 2020 9:54 amHi everyone, new to the forum, somewhat new to Spyderco.
-edc
-salt
-full SE
Thank you!
What he said. Cable saws for the win on installed pipe. I use a miter saw new pipe. A sharp FFG PE Delica is great for de-burring as you said.
- steelcity16
Cable saws are awesome! So cheap and simple, yet there is nothing better in tight areas.
Nylon string can also be used in a pinch. I've cut through 4 inch pvc conduit with it before. Not the best but if you have nothing else...
Spyderco : Resilience, Tenacious, Persistence, Manix 2 G10, Para 3 G10, Para 3 LW, Paramilitary 2,
- VooDooChild
Could get a pvc pipecutter as well. Its a big ratcheted plain edge wedge that sort of works like shears.
I think SE may be able to do it but it's FAR from a good tool for the job (any pocket knife for that matter). I would look into some of Victorinox's Swiss Army Knives and or multitools, they use little saws that cut very aggressively and are small enough to get into tight places while still having enough length to cut probably about a 2 inch pipe if needed. Their saws are unmatched IMO.
I own a pair, but my hand operated ones struggle on anything bigger than 1" CPVC. I can use them on 1 1/2", but they struggle, and no chance (for me anyways) of using my pair to cut 2".VooDooChild wrote: ↑Mon Feb 17, 2020 11:05 amCould get a pvc pipecutter as well. Its a big ratcheted plain edge wedge that sort of works like shears.
Milwaukee does make a battery operated pair, that can cut 2", but I still run the issue of getting water into my tool.
Came in to say the same thing. Some of the Swisstools have both a wood saw and a metal saw. Plus so many other useful tools too!Evil D wrote: ↑Mon Feb 17, 2020 11:09 amI think SE may be able to do it but it's FAR from a good tool for the job (any pocket knife for that matter). I would look into some of Victorinox's Swiss Army Knives and or multitools, they use little saws that cut very aggressively and are small enough to get into tight places while still having enough length to cut probably about a 2 inch pipe if needed. Their saws are unmatched IMO.
- PeaceInOurTime
Lots of different multitools have good saws. The Leatherman Surge has a T-shank blade receiver that allows you to use any blade with a T-shank end (jig saw blades).
Use the proper tool
Also - Milwaukee makes a folding saw that takes sawzall blades
- ChrisinHove
The larger Delemont made Victorinox Rangergrip SAKS have the longest of these ferocious sawblades.
There was a farmer guy on the forum a while back that posted pictures of what type of work he does. I remember he posted pictures of cutting some relatively large plastic tubing. If I can remember right, I think he used a plain edge Military.
There was a guy worked as a residential Electrician and he posted a review of the Rock Lobster and how he used it to strip some heavy gauge wire. The last time I looked up the thread, the pictures were dead. I think it was the photobucket mess up. Somehow I found a way to get them and rehosted and posted them... somewhere. I should have gone back to the original thread and reposted them there (which I might have done).
*edit* I think this was the post with someone cutting pipe, it was a Manix 2. Photobucket is the devil. :P
https://forum.spyderco.com/viewtopic.ph ... 07#p792207
He also cuts some plastic tubing in this video around 2:40. https://youtu.be/iQ890ZXob7Q
-Brian
A distinguished lurker.
Welcome to the Forum, CalRob! :)
I think you may like to look at the Opinel Saws. They come in two sizes, they’re light as, fold and from memory they cut on both the push and pull stroke.
