N690 vs N690Co on roadie
Posted: Sat Feb 15, 2020 6:12 am
Are they the same exact thing? What does the “Co” stand for on the roadie?
Why does spyderco add the Co if I may ask? From what I can find I don’t see it anywhere else other than N690. Only on my roadie do I see the “Co” added and was curious why this was since the makeup of the metal is the same.
Spyderco is definitely not the only company using the N690Co designation. Fox, Steel Will, Brisa/EnZo, and some other European manufacturers also use it.Holocene Extinction wrote: ↑Sat Feb 15, 2020 2:37 pmWhy does spyderco add the Co if I may ask? From what I can find I don’t see it anywhere else other than N690. Only on my roadie do I see the “Co” added and was curious why this was since the makeup of the metal is the same.
There was once a steel called Vanadis 4. It was redesigned and replaced so it was named Vanadis 4 Extra. So it is actually extra.Pancake wrote: ↑Sun Feb 16, 2020 12:45 amI have no idea to be honest. N690Co and N690 are the same, and a lot more companies are marking them as N690 or N690Co.......I have no explanation why. Maybe the variant with Co sounds cooler? Like why name your steel Vanadis 4E, when you can name it Vanadis 4 Extra (!!!!! +20 % moar cool!)
Urban is also marked as N690 Co......
