Page 1 of 2
CBN vs Daimond SM rods?
Posted: Wed Feb 12, 2020 9:35 am
by mpgtsm
I have two S30V blades I use every day. Occasionally they need more than just touching up. Which rods are better as an upgrade.
Thanks, and my apology if this is an old subject.
Re: CBN vs Daimond SM rods?
Posted: Wed Feb 12, 2020 9:37 am
by SG89
I have both and use both with no detectable difference (to me) on my knives. My edc is s30v
Posted: Wed Feb 12, 2020 9:45 am
by Wartstein
I never had diamond-, but have CBN rods and all I can say is that they work perfectly well.
Here is another thread concerning your question, including a post of Sal on it:
viewtopic.php?t=78443#p1219379
Posted: Wed Feb 12, 2020 9:46 am
by mpgtsm
Great. Thank you both
Posted: Thu Feb 13, 2020 2:44 pm
by emanuel
Had both. CBN seems to cut "finer" than the diamonds, while both remove metal just as fast, if that makes any sense. I use the CBN exclusively since I like the edge finish more/get the knife to a more consistent sharpness. Can't go wrong with both, but I recommend the CBN based on my experience.
Posted: Thu Feb 13, 2020 3:13 pm
by Evil D
I can't really compare them because my diamond rods are wore down a good bit, but I don't remember them cutting as aggressively as the CBN do so I have to lean a little towards them. Seems like I read on here somewhere that diamond cuts better but CBN doesn't tear off the rods as easily..? I'll tell ya this much, when they say to use a light touch, they mean it. If you ham fist on either of these rods you'll ruin them.
Posted: Thu Feb 13, 2020 4:48 pm
by soc_monki
I enjoy my diamond rods. They work deceptively fast, and leave a pretty good finish. You can always polish up the edge with the medium, fine and ultrafine if you want. I usually just leave the diamond finish, but sometimes do hit it on the brown rods depending on how I feel.
Posted: Fri Feb 14, 2020 7:33 am
by pantagana23
Guys, if I buy the standard Sharpmaker set, do I need additional rods to take to get the knife to sharp?
I mean those CBN/diamonds and ultra fine.
Also, is the honing board with compounds needed additional to previous?
I need to get a good sharpener, as I have 30+ folders in different steels and only a diamond/ceramic stone, and can't get any knife even close to factory level.
I wan't to get a normally priced sharpener (WE and Tormek go too high IMO), and maybe this would be the solution.
From my current steels, I have AUS-8, VG-10, LC200N, CTS-XHP, CPM154, N690Co, H1, 440C, 12C27 and Victorinox steel (whatever alloy that is)
Please advise.
Posted: Fri Feb 14, 2020 8:33 am
by TkoK83Spy
pantagana23 wrote: ↑Fri Feb 14, 2020 7:33 am
Please advise.
Sharpmaker would be perfect for you! Since you already have a diamond stone for reprofiling or removes chips, though the CBN/Diamond rods wouldn't be a bad idea...that way you could maintain the same angle with all the stones instead of free handing with the diamond you already have. Depends on your skill level with your free hand sharpening I suppose! It's a big leap in grit going from diamond to be the brown rods, so it will take some patience but it can be done. I've done it myself plenty of times now from the CBN to the browns.
Depending how much of an edge junky you are, finishing on the standard fine rods should be fine in most cases. You should easily be able to cut through receipt paper, shave arm hair off the white stones if sharpened correctly.
Posted: Fri Feb 14, 2020 9:08 am
by Woodpuppy
The only sharpening “system” I have is the Sharpmaker. I have a set of cbn rods, but only ever use them to reprofile an edge to 30* included, or fix a battered edge. Then I rely on the brown & white rods for regular maintenance sharpening. Often I only need the white/fine rods. Some folks do well with a light touch with just the brown/mediums, but I like the white. I also made myself a leather strop; the suede side is loaded with green compound and the reverse is just smooth cowhide. I don’t think I’ve achieved “arm hair tree topping” level, I usually stop when I reach easy arm hair shaving with no razor burn. I also like the Spyderco Doublestuff2 stone. Both of mine have come apart, unfortunately I epoxied my first one back together without thinking. I should have stuck two white stones together! They outlast the cbn. I’d really like a doublestuff “3” with white & brown stones in the same shape as the DS2.
Posted: Fri Feb 14, 2020 10:44 am
by soc_monki
I hardly ever use my fine and ultrafine rods anymore. Finish bevel on diamonds, microbevel withe the browns. Pops hair off the arm and slices paper no problem. I prefer the tooth you get from that progression.
All the stones are good to have though. Some steels work great at the high polishes of the fine and ultrafine. It's good to have variety!
Posted: Fri Feb 14, 2020 1:32 pm
by TkoK83Spy
soc_monki wrote: ↑Fri Feb 14, 2020 10:44 am
That's how I finished off my M390 Para 3 a couple weeks ago. I actually plan on using it all next week at work to see how I like it and how it holds up.
Posted: Fri Feb 14, 2020 4:37 pm
by soc_monki
TkoK83Spy wrote: ↑Fri Feb 14, 2020 1:32 pm
It really works great. Polishing the bevel works really well for some things, but when there is a toothy finish I find the edge grabs and slices much better. Going through paper it is not as smooth and whisper quiet, but I find I like the aggressive nature of the teeth better!
Posted: Wed Feb 19, 2020 10:11 am
by mpgtsm
Please advise.
Unless you really want the mirrored edge, the brown rods will maintain an edge really well, and with almost no time or effort. This thread details it fairly well:
https://forum.spyderco.com/viewtopic.php?f=2&t=84636
I bought a nice strop, but have not seen it make a difference. A very light touch on the SM, and my blades are as sharp as I've ever imagined they could be.
Posted: Wed Feb 19, 2020 10:26 am
by prndltech
Can’t go wrong. I think I bought the CBN? Don’t even remember. Reprofiled s90v with it pretty easily.
Posted: Wed Feb 19, 2020 10:29 am
by kodai78
I have several sharpening devices but I only use the Sharpmaker now since I bought it. Perhaps it’s most important characteristic is ease of use. I don’t have the ability to freehand on a stone and get good results in a short time. With the Sharpmaker I can. I have the Diamond stones and medium, fine and ultra-fine. I have a strop and use it after finishing up on the Sharpmaker but it’s hard to tell much difference. I don’t always use all 4 grades of stones. The Diamond is really for an edge in poor condition in my opinion. Use of the brown and white stones is all you need for maintaining a good cutting edge. Of course there are some edge wizards on the forum who need a polished edge and laser like cutting from their knives. More power to them, but the Sharpmaker alone will sharpen pretty much everything in your kitchen and workshop and all your knives very well. There are many other options in the market for sharpening knives but the Sharpmaker hits the sweet spot price and utility wise for me.
Posted: Wed Feb 19, 2020 11:05 am
by pantagana23
kodai78 wrote: ↑Wed Feb 19, 2020 10:29 am
So basically I buy Sharpmaker set, which comes with medium and fine, buy diamond and ultrafine additionally for a full set?
How long do these rods last?
Posted: Wed Feb 19, 2020 11:19 am
by mpgtsm
Diamond or CBN and UF are accessories, if you have a need for them. I'm sure the life of the stones, depends on how often and how you use them. They are easy to clean though.
Posted: Wed Feb 19, 2020 11:44 am
by kodai78
You can add the additional stones later. You don’t have to have them. The stones that are in the Sharpmaker are sufficient for most uses. If you need to repair or reprofile you would add Diamond or CBN. The rods will last a long time if you use light pressure. Maybe decades but many years certainly. Get the Sharpmaker, watch the videos (YouTube) and practice. Then you will learn if you need the other stones. I keep an old Yellow pages and test the edges on that paper after sharpening and the ultra fine stones are nice but not necessary. Many people do not finish an edge with even the fine stones.
Posted: Wed Feb 19, 2020 11:52 am
by kodai78
Please advise.
I should have quoted you earlier in my first reply but I have sharpened most of these steels with the Sharpmaker without problems, with good results and without needing Diamond or CBN. (Not sure I have any 12C27, or have sharpened any 440 C in a long time but they should be fine). I hope this helps. You will be able to achieve “factory level” or better with the Sharpmaker after very little practice. Use light pressure!
