Paramilitary 2 - CTS-204p Question
Accutronman
Postby Accutronman » Wed Jan 22, 2020 3:04 pm
This is for anyone owning a PM2 CTS-204p. I was recently going through my collection examining and cleaning each knife. When I got to my two PM2s in CTS-204p, I noticed an interesting thing on both knives. On the spydie logo side of the blade, underneath almost the center of the spydie hole is a pronounced vertical line that at first examination I thought was perhaps a striation line in the steel. On closer examination, it looks almost like a crack line running from the spydie hole to the blade edge. It appears on both knives in roughly the same place.
Before I query Warranty and Repair, have any other owners of this model seen the same thing? Thanks!
Re: Paramilitary 2 - CTS-204p Question
Postby TkoK83Spy » Wed Jan 22, 2020 3:07 pm
Can you take some pics?? I don't have the PM2 of this knife, but I have the Military. (I'm assuming you're talking about the KnifeWorks exclusive model?) I'm going to check mine when I get home tonight, you've got me curious.
Currently have 18 :spyder:'s in 11 different steels. Constantly adding and purging!
Peacedivision
Postby Peacedivision » Wed Jan 22, 2020 3:17 pm
I checked my sample and I'm not seeing anything beyond the normal machining and grind marks.
blues
Postby blues » Wed Jan 22, 2020 3:34 pm
Nothing amiss on mine. (Neither the PM2 nor the Military.)
- No FOMO -
Accutronman
Postby Accutronman » Wed Jan 22, 2020 3:46 pm
Chumango
Postby Chumango » Wed Jan 22, 2020 4:10 pm
The pictures are out of focus, so a real opinion is not possible, but it looks like a grind line.
PayneTrain
Postby PayneTrain » Wed Jan 22, 2020 4:29 pm
Yeah, I think what you have there is a grind line. What most likely happened there is a deeper-than-normal scratch was made by the coarse belt, and the subsequent finer grits failed to mute it. It's not by any means a defect, and certainly nothing to worry about. They are all over my knives, certainly the ones I've made but definitely the ones I've bought too. Some are more pronounced than others, and there's no clear pattern other than the harder steels tend to have less perfect finishes and 204P, while fine-grained in Spyderco models, is a very wear-resistant steel so it is subject to finish "imperfections" much more than steels like VG-10 which are usually finished super smooth in my experience. Sounds like you bought two knives ground on the same belt with the same abnormally large grain of abrasive. Twinsies!
"Be the person your dog thinks you are."
The Meat man
Postby The Meat man » Wed Jan 22, 2020 4:36 pm
I don't know. Hard to tell from the photos.
At least you have two of them, so if you decide to have Spyderco take a look you'll still have one to carry and use. :)
- Connor
"You live and learn. At any rate, you live."
Postby TkoK83Spy » Wed Jan 22, 2020 5:26 pm
Nothing on my Military. I agree, looks like a grind line. I have a few knives with those. No big deal
Accutronman
Postby Accutronman » Wed Jan 22, 2020 5:49 pm
Many thanks to all for the insights!
Donut
Postby Donut » Wed Jan 22, 2020 5:54 pm
On most holes, there is something of note. When they use a laser or a plasma cutter to cut the blade out (of a large sheet of steel) and to cut the hole out, there has to be a starting point.
Usually the whole outside of the blade is finished, so you won't notice the starting point of the outside of the blade.
I think Taiwan will grind the inside of the hole flat, so it will look satin like the rest of the blade, but some factories don't finish the inside of the hole.
I'll get mine out a little later and give it a good examining. Where exactly did you say it is? First you say vertically down the Spyder Logo, then you say from the Hole to the Edge. I think I see something in your pictures, but it just looks like a grind line in your picture.
-Brian
A distinguished lurker.
Waiting on a Squeak, Pingo, and Cliptools with a Split Spring!
The Meat man
Postby The Meat man » Wed Jan 22, 2020 6:24 pm
Usually there will be a small lead-in from the initial pierce, and depending where the lead-in is placed you might not be able to see anything at all.
- Connor
Azilla21
Postby Azilla21 » Thu Jan 23, 2020 5:39 am
I had the same thing happen to my exact PM2. It was a fine crack in the blade and I had to send it in. I’m not sure why it’s happened to this run of 204p PM2’s.
AlexRus
Postby AlexRus » Thu Jan 23, 2020 10:04 am
Read this https://m.facebook.com/story/graphql_pe ... NDQ4Mjg%3D
TomAiello
Postby TomAiello » Thu Jan 23, 2020 10:41 am
This thread has inspired me to carry my trusty and well worn 204p military today. :)
AlexRus
Postby AlexRus » Thu Jan 23, 2020 10:44 am
I like Millie 204p, have 3 of them :)
Users browsing this forum: Bing [Bot], buckleys, Doc Dan, Google [Bot], Spydergirl88, w3tnz and 23 guests
