Can I run my Catcherman through the dishwasher?
We were previously discussing the X Cut and how to get into a restaurant to be used as a steak knife. I've been thwarted trying to find a roll-up, sheath, case or other carry option. Then I considered my Catcherman (forum knife, toxic green with H1 and black blade). It seems like I could keep all the steak and juice off the handle and wash the blade easily in the Men's room. If it did get dirty could I run it through the dish washer our would a hand washing be more appropriate?
That toxic green handle may draw unwanted attention if I were to be walking around with the blade deployed.
- steelcity16
Re: Can I run my Catcherman through the dishwasher?
I've run all my Salts through the dishwasher with no I'll effects. And I have a Bosch dishwasher that gets very hot. I'd think the Catcherman should be ok, but I can't say with 100% certainty.
I'm with you on the folding steak knife thing too. The Pacific Salt has been ok in this role for me, but if they designed a new FFG LC200N PE Folding Steak Knife from the ground up it would be awesome.
I think you could and be all right. But why do need to clean your Catcherman in the dishwasher :confused: ? I have a rule to where I hand clean every one of my knives ( even the cheap ones I bought at thrift stores).
If your dryer element got hot enough to warp the handle it would be too late then. Because I would be doubtful if GOLDEN has any replacement handles for that model.
Now I have had occasion to soak several of my food prep knives in the "Overnight Dawn Dish Soap". And then I will use a soft bristle toothbrush or something similar. For me personally I just don't like the idea of exposing my knives to high heat or those really caustic auto dishwashing detergents.
I sure would hate to see you damage or ruin a nice knife like the Catcherman. I have 6 of them and I wouldn't risk any of them. Good Luck :)
- araneae
I thought this was a joke...
-Nick
Last in: N5 Magnacut
-Nick
I don’t wash anything I value in the dishwasher.
You can. However you may not!
I don't either. I wash all the good stuff by hand. It only takes a minute or two
- bearfacedkiller
It isn’t the heat I worry about. I worry about things banging into each other and more importantly I worry about the detergent. Dish soap and dishwashing detergent are very different. One is just soap and one is a caustic chemical. You are asking something to clean your dirty dishes without actually touching them. How does that work? Strong chemicals.
I would say that you can but that I wouldn’t. I don’t ever put any knife in the dishwasher except butter knives.
Those are all good points BFK :) Where I'm living at this time I could have had an automatic dishwasher of my choice. For a lot of the reasons you've cited I have really no use for one at all. The chemicals in that dishwasher detergent are very harsh. I clean all of my knives with one of the "DAWN" dishwashing soaps and carefully clean them by hand. The variant of DAWN I like the best is that one called " DAWN 4X, Platinum Overnight". I've never failed to do a really great cleaning job using DAWN dish soap. And I don't use Scotch-Brite pads or anything else with abrasive.bearfacedkiller wrote: ↑Fri Jan 10, 2020 12:13 pmIt isn’t the heat I worry about. I worry about things banging into each other and more importantly I worry about the detergent. Dish soap and dishwashing detergent are very different. One is just soap and one is a caustic chemical. You are asking something to clean your dirty dishes without actually touching them. How does that work? Strong chemicals.
With the high heat and the caustic chemicals in dishwasher soap I can't see where it's worth risking the damage of a great knife.
Thanks guys! I really appreciate your wisdom!!!!
