Good Morning All.
I would sure like to know if any hardware for my Original Lum is interchangeable with another model? Screws and pocket clip are the main thing. Mine has titanium scales and if a beautiful blank canvas. Thank You. M2M
LUM China Folder Hardware
Re: LUM China Folder Hardware
Welcome ManToMonster.
You might have some luck calling Spyderco to ask.
The sword the body wounds, sharp words the mind.
- Menander :spyder:
- Menander :spyder:
- The Deacon
Not familiar with the titanium version, but if it uses the same clip as the almite coated aluminum ones shown below, there are going to be few, if any, other models that used it. Swapping screws, with the possible exception of clip screws, between models will also be problematic.
Hi Paul, Do you know if the clips you have on your Lums are available and do they fit the large Lum? I'd like to buy a polished stainless one for my large Pink Lum. :)The Deacon wrote: ↑Mon Jan 20, 2020 1:23 pmNot familiar with the titanium version, but if it uses the same clip as the almite coated aluminum ones shown below, there are going to be few, if any, other models that used it. Swapping screws, with the possible exception of clip screws, between models will also be problematic.
- RadioactiveSpyder
Hi Bloke, the large Lum Chinese folders use the standard 3-hole screw pattern of the Delica, Endura, etc. You can just swap a silver one right on!
Given that standard hole pattern, aftermarket clips (Lynch, MXG Gear) also fit the large ones just fine. :)
Last edited by RadioactiveSpyder on Mon Jan 20, 2020 5:05 pm, edited 1 time in total.
- RadioactiveSpyder
Hi there, unfortunately the Lum clips are specific to that model and not interchangeable with other models. The only exception to that is the newest HAP40 natural G10 sprint model. I have seen Ti Lums with standard 3-hole pattern clips on them, however new clip holes had to be drilled and tapped in the standard 3-hole pattern. Hope that helps!ManToMonster wrote: ↑Sat Jan 04, 2020 9:35 amGood Morning All.
Many Thanks, Spyder! :cool:RadioactiveSpyder wrote: ↑Mon Jan 20, 2020 4:58 pmHi Bloke, the large Lum Chinese folders use the standard 3-hole screw pattern of the Delica, Endura, etc. You can just swap a silver one right on!
The black clip looks like a fly in the ointment so I paint stripped it. It’s ended up a matt gunmetal colour and now that I know the “Half Moon” clips won’t fit I’ll just polish it up on a buffing wheel and a little polish on a bench grinder.
Thanks again! :)
