Page 1 of 2
Brouwer Clip Placement - 2020 Catalog
Posted: Fri Jan 03, 2020 3:07 pm
by hovan2yourknives
I just noticed in the new catalog that it seems like the pocket clip placement has been adjusted to provide a deeper carry. However, it is only adjusted on the lock-bar side for right-hand carry which is a little curious (if the photo is accurate). If these images are accurate...I will finally get one!
Can anyone confirm or deny that this is a CQI adjustment?
Posted: Fri Jan 03, 2020 3:18 pm
by Mushroom
Yes, I can confirm the Brouwer clip placement definitely went through a CQI change.
When I was in the SFO this past November I directly compared both versions and in my opinion, the clip placement after CQI is definitely an improvement.
Re:
Posted: Fri Jan 03, 2020 4:36 pm
by hovan2yourknives
Mushroom wrote: ↑Fri Jan 03, 2020 3:18 pm
Thanks!
Re: Brouwer Clip Placement - 2020 Catalog
Posted: Fri Jan 03, 2020 7:18 pm
by ABX2011
Good eye! That's a welcome change.
Posted: Sat Jan 04, 2020 3:41 am
by Larry_Mott
I don't have a problem with the clip as is.. Oh well :)
On a side note - how do you pronounce Brouwer? Brow, like eyebrow or Brew, like coffee?
Posted: Sat Jan 04, 2020 9:17 am
by The Meat man
Larry_Mott wrote: ↑Sat Jan 04, 2020 3:41 am
I've always heard it pronounced the former. (Brow as in eyebrow)
Posted: Sat Jan 04, 2020 10:07 am
by Marulaghost
Brouwer is a Dutch designer.
So Brou would be like eyebrow.
But the W should be a sharp F like Field
So it would be "Browfer"
Posted: Sat Jan 04, 2020 11:42 am
by Larry_Mott
Marulaghost wrote: ↑Sat Jan 04, 2020 10:07 am
I thought it was the 'V' that was pronounced 'F', not the W oh well :)
Posted: Sat Jan 04, 2020 1:40 pm
by G_shark
Larry_Mott wrote: ↑Sat Jan 04, 2020 11:42 am
You are correct.
Source: me, born and raised speaking Dutch.
Posted: Sat Jan 04, 2020 3:57 pm
by Larry_Mott
G_shark wrote: ↑Sat Jan 04, 2020 1:40 pm
You are correct.
I have vague memories of someone telling me how to pronounce Cornelis Vreeswijk's name right decades ago :)
Posted: Sat Jan 04, 2020 4:39 pm
by Surfingringo
You are correct.
I would assume that the W is pronounced as V as in German?
Posted: Sat Jan 04, 2020 5:01 pm
by Larry_Mott
Surfingringo wrote: ↑Sat Jan 04, 2020 4:39 pm
You are correct.
Volkswagen is pronounced Folkswagen. (In Germany and Sweden at least :) )
Posted: Sat Jan 04, 2020 5:10 pm
by Wartstein
Larry_Mott wrote: ↑Sat Jan 04, 2020 5:01 pm
You are correct.
Same in Austria
Posted: Sat Jan 04, 2020 8:37 pm
by Marulaghost
You guys are completely correct. I had a brain fart
Posted: Sun Jan 05, 2020 3:40 pm
by G_shark
You are correct.
Well, no
Posted: Sun Jan 05, 2020 3:56 pm
by gull wing
The clip movement is an improvement, but the MXG short clip is better. The standard clip is still too long.
Posted: Sun Jan 05, 2020 7:22 pm
by Mushroom
As part of the CQI, the standard clip was also downsized on the new version of the Brouwer. Just something I forgot to mention in my other post. :spyder:
Posted: Sun Jan 05, 2020 8:13 pm
by Notsurewhy
gull wing wrote: ↑Sun Jan 05, 2020 3:56 pm
Which clip hole pattern does the browser have? Didn't see it in the clip thread.
Posted: Mon Jan 06, 2020 7:32 am
by Cscottsss
I want to get one of these but I really just can't get past the green scale color.
Posted: Mon Jan 06, 2020 10:21 am
by soulspy
Cscottsss wrote: ↑Mon Jan 06, 2020 7:32 am
There is a flytanium copper and a Ti scale that replaces the green side.
