Brouwer Clip Placement - 2020 Catalog
hovan2yourknives
Postby hovan2yourknives » Fri Jan 03, 2020 3:07 pm
I just noticed in the new catalog that it seems like the pocket clip placement has been adjusted to provide a deeper carry. However, it is only adjusted on the lock-bar side for right-hand carry which is a little curious (if the photo is accurate). If these images are accurate...I will finally get one!
Can anyone confirm or deny that this is a CQI adjustment?
Postby Mushroom » Fri Jan 03, 2020 3:18 pm
Yes, I can confirm the Brouwer clip placement definitely went through a CQI change.
When I was in the SFO this past November I directly compared both versions and in my opinion, the clip placement after CQI is definitely an improvement.
- Nick
:spyder:
hovan2yourknives
Re:
Postby hovan2yourknives » Fri Jan 03, 2020 4:36 pm
Thanks!
ABX2011
Re: Brouwer Clip Placement - 2020 Catalog
Postby ABX2011 » Fri Jan 03, 2020 7:18 pm
Good eye! That's a welcome change.
Larry_Mott
Postby Larry_Mott » Sat Jan 04, 2020 3:41 am
I don't have a problem with the clip as is.. Oh well :)
On a side note - how do you pronounce Brouwer? Brow, like eyebrow or Brew, like coffee?
//Eva Mott R.I.P.
The Meat man
Postby The Meat man » Sat Jan 04, 2020 9:17 am
I've always heard it pronounced the former. (Brow as in eyebrow)
- Connor
"You live and learn. At any rate, you live."
Marulaghost
Postby Marulaghost » Sat Jan 04, 2020 10:07 am
Brouwer is a Dutch designer.
So Brou would be like eyebrow.
But the W should be a sharp F like Field
So it would be "Browfer"
Larry_Mott
Postby Larry_Mott » Sat Jan 04, 2020 11:42 am
I thought it was the 'V' that was pronounced 'F', not the W oh well :)
//Eva Mott R.I.P.
G_shark
Postby G_shark » Sat Jan 04, 2020 1:40 pm
You are correct.
Source: me, born and raised speaking Dutch.
Larry_Mott
Postby Larry_Mott » Sat Jan 04, 2020 3:57 pm
You are correct.
I have vague memories of someone telling me how to pronounce Cornelis Vreeswijk's name right decades ago :)
//Eva Mott R.I.P.
Surfingringo
Postby Surfingringo » Sat Jan 04, 2020 4:39 pm
You are correct.
I would assume that the W is pronounced as V as in German?
Larry_Mott
Postby Larry_Mott » Sat Jan 04, 2020 5:01 pm
You are correct.
Volkswagen is pronounced Folkswagen. (In Germany and Sweden at least :) )
//Eva Mott R.I.P.
Postby Wartstein » Sat Jan 04, 2020 5:10 pm
You are correct.
Same in Austria ;)
Marulaghost
Postby Marulaghost » Sat Jan 04, 2020 8:37 pm
You guys are completely correct. I had a brain fart
G_shark
Postby G_shark » Sun Jan 05, 2020 3:40 pm
You are correct.
Well, no 😁
gull wing
Postby gull wing » Sun Jan 05, 2020 3:56 pm
The clip movement is an improvement, but the MXG short clip is better. The standard clip is still too long.
SCARAMOUCHE! :spyder:
Postby Mushroom » Sun Jan 05, 2020 7:22 pm
[img] https://i.imgur.com/tvLc36F.jpg [img]
As part of the CQI, the standard clip was also downsized on the new version of the Brouwer. Just something I forgot to mention in my other post. :spyder:
- Nick
:spyder:
Notsurewhy
Postby Notsurewhy » Sun Jan 05, 2020 8:13 pm
Which clip hole pattern does the browser have? Didn't see it in the clip thread.
Cscottsss
Postby Cscottsss » Mon Jan 06, 2020 7:32 am
I want to get one of these but I really just can't get past the green scale color.
soulspy
Postby soulspy » Mon Jan 06, 2020 10:21 am
There is a flytanium copper and a Ti scale that replaces the green side.
Users browsing this forum: 5-by-5, ABX2011, Baron Mind, Buddafucco, JMM, Johncjeff, Majestic-12 [Bot], MSN [Bot], spambait11 and 29 guests
