Liner Lock Failure??
jdw
Postby jdw » Mon Dec 30, 2019 10:12 am
I am kind of wondering who has had a Spyderco liner lock fail on them without intentional abuse/misuse? I have used a Military and a GB1 pretty heavily without any kind of stress that I felt would even kind of cause lock failure. I don't use a liner lock if I am doing something that is obviously going to gunk up the lock and cause failure, but that's just kind of common sense. The lock is not going to fail from just sheer stress. Grab a fixed blade or a pry tool if you really want to torque on something.
EDIT: In response to Sal's Casual Bombshell thread.
--Wovoka
The Mastiff
Re: Liner Lock Failure??
Postby The Mastiff » Mon Dec 30, 2019 10:36 am
My guess is that wasn't about failure as much as weak detent/loose pivots causing the blade to open while in the pocket. It happened to me with another brand liner lock and caused a bad slice to my hand when I reached into my pocket at a gas station. In my case keeping the pivot tighter would have prevented that but I still will not carry a liner lock in my pocket as a matter of policy and habit.
Joe
Notsurewhy
Postby Notsurewhy » Mon Dec 30, 2019 11:14 am
I think some people go a little overboard worrying about lock strength. I have never had an issue with a liner lock or any other lock failing on a knife from a quality brand without intentional abuse (anecdote <> data, I know). The closest was a broken spring on an axis lock, but it still worked fine with only one spring until I sent it in for repair.
They are not my favorite lock type, but I prefer liner locks to frame locks and in some cases I prefer one over a compression lock e.g. flippers or on a narrow knife like the kapara.
Postby Wartstein » Mon Dec 30, 2019 11:39 am
Don´t / didn´t carry linerlocks a lot (for quite some time now exclusivly backlocks tbh), but never had any problems whatsoever.
Only knife that opened in my pocket and cut me (twice) was an axxis-lock one.
Like Notsurewhy I prefer a well executed linerlock over a comp.lock (generally, not just in some cases)
Postby ladybug93 » Mon Dec 30, 2019 11:44 am
i've never had any lock fail on me ever, even from cheap knives. i've also never had a slip joint close on me. i don't know what people are doing with their knives.
Notsurewhy
Postby Notsurewhy » Mon Dec 30, 2019 12:04 pm
I did some really ill advised things with some flea market/gas station quality knives in my mispent yewt. :o
Still had issues more like "lock won't engage unless you push the bar" than coming unlocked. I don't ever remember one folding up while cutting anything. Maybe while hitting it with a piece of wood...
James Y
Postby James Y » Mon Dec 30, 2019 12:09 pm
I’ve never had a liner lock (or any other lock) fail in me or close while using it. I did have a couple older Emerson CQC-7s whose liner locks would sort of “pop off” the blade tang if I used light-to-moderate hand pressure to the back of the blades, but they never came completely,Evelyn unlocked. Then again, I stopped carrying them long ago.
For me, the Spyderco Military is the best-made liner lock out there.
I’ve also never had a slip joint pocketknife...”traditional” or SAK...close on me during use, ever. And I’ve been carrying and using slip joints since the ‘70s and SAKs for going on 40 years now. I tend to view blade locks as an additional safety feature that isn’t foolproof, but is there to supplement careful handling. I have acccidentally cut myself while using knives, and it’s always because my attention lapsed, and/or I temporarily took it for granted and forgot to respect the knife.
Although in some uses, accidental closures can happen. I have heard of a hunter who was field dressing a deer and had his Buck 110 close on his hand, injuring him badly. Failures can occur, for a variety of reasons not necessarily related to abuse.
prndltech
Postby prndltech » Mon Dec 30, 2019 12:23 pm
I’ve done some stupid things with a military... twisting, prying, broke the blade, lock never budged.
The planter, the farmer, the mechanic, and the laborer... form the great body of the people of the United States, they are the bone and sinew of the country men who love liberty and desire nothing but equal rights and equal laws. - Andrew Jackson
curlyhairedboy
Postby curlyhairedboy » Mon Dec 30, 2019 12:32 pm
I've never seen a spyderco liner lock fail in the locked position, but I prefer the related compression lock because of the superior physical arrangement.
EDC Rotation: PITS, Shaman, CF S90v Shaman, Ikuchi, Amalgam, CruCarta Shaman, Lil Native, Sage 5 LW, Ouroboros
Always in Pocket: Hawkbill Dragonfly 2 H1
Special and Sentimental: Southard, Smallfly G10, Squarehead LW, Calendar Para 3 LW, 40th Anniversary Native
Would like to own again: Sheepsfoot Caribbean
Wishlist: CQI Kapara, Watu, Tanto PM2, Shaman Sprints!
Postby The Deacon » Mon Dec 30, 2019 12:51 pm
If this thread is a response to the post I think it is, then you're asking the wrong question. Pretty sure the poster there was commenting on the questionable ability of the ball detent in liner locks to keep the knife closed completely 100% of the time when carried loose in the pocket. While I think the risk of a knife like the Bradley Air that has a small lightweight blade partial opening while in the pocket is highly unlikely, at least for anyone not practicing Parkour while carrying it, I'd suggest that criticism would apply to any type of lock that relies on a small ball detent to keep the knife closed unless carried clipped, tip down, with the blade against the back of your pocket.
cbrstar
Postby cbrstar » Mon Dec 30, 2019 3:09 pm
The only liner locks that have opened on me in the pocket were all flippers! The back pocket + tip up + flipper = Bad idea.
The Meat man
Postby The Meat man » Mon Dec 30, 2019 3:40 pm
Never had a liner lock fail on me, Spyderco or otherwise.
- Connor
"You live and learn. At any rate, you live."
Albatross
Postby Albatross » Mon Dec 30, 2019 4:07 pm
Honestly, it's not a great idea to carry a knife loose in the pocket, unless it's a slip joint, back lock, or CBBL knife. Even then, in my opinion, it's not the safest of ideas, but if you can do it safely, keep on keeping on.
sal wrote:
Fri Nov 09, 2018 3:01 pm
...But in general, I'm all about high performance, Ergos, safety. That's why I've been accused of "deigning in the dark"...
Postby Wartstein » Mon Dec 30, 2019 5:04 pm
May I ask: What do you mean by that?
Imho other than that "fingers never in the blade path" - thing (rather irrelevant for a bit experienced knife users in my opionion), a liner lock offers a more secure and natural grip of the knife while operation ((closing) compared to a comp.lock.
Halfneck
Postby Halfneck » Mon Dec 30, 2019 5:21 pm
I've had one liner-lock fail on me (not a Spyderco).
I was sawing through some heavy duty cardboard & when the blade became wedged in I yanked up hard. I felt the blade pop loose & begin to fold so I ceased all movement. Luckily I did not get cut. Checking the knife out later I found I could replicate what happened with a light spine whack. Let me put an emphasis on *Light Spine Whack* as I think the people that all out hammer a liner lock in a spine whack are being excessive.
I have 2 other liner-lock knives from that same company & both lock up vault tight. That particular knife is just a lemon, but I will admit it has deteriorated my trust in liner-locks some.
Postby Evil D » Mon Dec 30, 2019 5:42 pm
I've beat the crap out of my Militaries without any failures. I usually don't pry doors off hinges or baton through car doors though so maybe my hard use is just not hard enough.
redhawk44357
Postby redhawk44357 » Mon Dec 30, 2019 5:53 pm
Liner lock, nope......flipper (not spiderco) oh yeah!
rangefinder
Postby rangefinder » Mon Dec 30, 2019 6:15 pm
He may be referring to the fact that with a compression lock, the lock bar is held between the blade and the stop pin, so for the lock to fail the entire knife basically has to come apart. Unlike a liner lock, where the lock bar can just fold out of the way and the knife will close.
Michael Janich explains the difference using cutaway models of knives in several videos. Here's one I had bookmarked (evolution of the Yojimbo) -- the explanation of the locks starts at the 9:25 mark:
https://youtu.be/1ddOdONCCqU
James Y
Postby James Y » Mon Dec 30, 2019 6:57 pm
Thanks for posting that. I always enjoy and learn a lot from Michael Janich’s posts and his videos.
curlyhairedboy
Postby curlyhairedboy » Mon Dec 30, 2019 8:52 pm
yeah, my concerns about liner locks have to do with the geometry - a thin, long, liner under lengthwise compression is much more vulnerable to buckling than a much shorter tab.
Users browsing this forum: Accutron, Burton Knut, Holland, JMM, Molle Ninja, MSN [Bot], Mushroom, Notsurewhy, Tabo, timlara, Wartstein and 20 guests
