Who else wants a SE Lil'Matriarch Salt in H1 ?!
Pancake
Re: Who else wants a SE Lil'Matriarch Salt in H1 ?!
#61
Post by Pancake »
ZMW wrote:
Sat Dec 14, 2019 12:25 am
Where is Larrin with toughness data on H1 vs LC?? Like everyone else, I am really curious. I don’t recall seeing H1 on his previous toughness charts
Larrin has tested LC200N but I think it was under name Z-finit. For stainless steel, it has superb toughness.
H1 is a different animal and you can't test it the same way. You can't get it outside Japan and you can't heat treated it - it just not work that way. There are no bars of H1 available for knife making. And for toughness testing you need to have speciment with specific dimensions.
ZMW
#62
Post by ZMW »
Thank you! I didn’t know z finit is the same as lc200n.
Pancake wrote:
Sat Dec 14, 2019 3:07 am
Surfingringo
#63
Post by Surfingringo »
BUMP
curlyhairedboy
#64
Post by curlyhairedboy »
Would like one of these with an Emerson opener....
Surfingringo
#65
curlyhairedboy wrote:
Wed Dec 25, 2019 9:56 pm
I don’t need any of the “fast opening” attributes but I have often used the spydiehole on a Pacific Salt to lever a hook out of a fishes mouth. An Emerson opener would probably make a nice little pry-claw.
#66
I may have missed the discussion, but does the reverse "s" provide any particular benefit over a normal hawkbill?
#67
PeaceInOurTime wrote:
Thu Dec 26, 2019 3:25 pm
Maybe some situations where that little bit of belly gives you a reach advantage, like if you were trying to cut on a cutting board or something. Otherwise they seem to have a less dramatic hook shape overall which may have some advantage somewhere depending on how you're using it. I'm really not for or against either one, the pros and cons seem less significant to me than the model/steel/etc.
TomH
#68
Post by TomH »
I would like this, too.
Surfingringo
#69
Whittling type cuts. Cutting objects on the corner of a flat surface. Cuts where you hold something against the side of the blade with your thumb to make a cut (like cutting fishing line or string). Basically, the reverse S gives you a section of blade at the heel that is in line/parallel with the handle. This doesn’t sound like a big difference but in my experience it makes a big difference in how useful the knife is for average “EDC” type tasks. I also feel like the down sweep at the tip is less severe on some reverse S shapes so a pull cut using just the tip is more fluid. (This type of “scoring” cut is one of the most common cuts I do with these types of blades)
#70
Surfingringo wrote:
Fri Dec 27, 2019 8:51 am
That makes sense and I think I see the merit. Thanks for the reply!
bbturbodad
#71
Post by bbturbodad »
Fri Dec 27, 2019 2:42 pm
I find the angle of approach more natural for "EDC" tasks with the mild reverse S on the LM vs a full hawkbill like the Tasman. For me the rear portion of a hawkbill goes unused whereas with the LM I tend to use the whole blade.
-Turbo
#72
bbturbodad wrote:
Fri Dec 27, 2019 10:37 pm
Interesting. This makes me wonder about how a blade with several consecutive mild re-curves/waves would perform (in SE). Granted, it would likely need to be much longer than the LM. I'm not aware of any similar existing blades.
Sumdumguy
#73
Post by Sumdumguy »
Fri Dec 27, 2019 11:21 pm
The only one is the Kris, but it was only made in PE.
-Thomas Jefferson
Pancake
#74
Post by Pancake »
If it comes without that Lil in the name, it could be very interesting.
Like a Pacific Salt 2 with reverse S blade.... yeah (but hawkbill could be also good).
#75
Seems like it would only really be beneficial if you're cutting something wide enough to get each wave of the blade over what you're cutting, unless you're pulling the blade over something like a sawing motion. I'm sure it would be a strong cutter but I'm not sure it would have many advantages over just one. I'd definitely try one out though.
Actually now that I think about it there is/was a kitchen knife with sort of a similar pattern, at least in the serrations themselves. It wasn't really a full on "Kris" style blade but there's a definite wave to the edge.
#76
^^^ that's sort of the same idea. Maybe someday the Police handle will be mated with a reverse "s" (or multiple waves) blade. There certainly has been alot of talk this year about the reverse "s" in all sizes.
Sorry if I'm a bit off topic. Back to the LM salt, I don't know that I would buy one, but it does seem like it would make more sense to have that model as a salt. It would seem beneficial to have your defensive tool (as it was designed to be) able to handle wet, salty conditions.
Dazen
#77
Post by Dazen »
This would be the icing on the cake for this knife!
Dane
ZrowsN1s
#78
Post by ZrowsN1s »
Sounds good to me👍
bbturbodad
#79
Bump!!!
-Turbo
kerrcobra
#80
Post by kerrcobra »
This would be awesome!
--Jeremy
