Sharpening angles
redhawk44357
Sharpening angles
Postby redhawk44357 » Fri Nov 22, 2019 6:27 pm
I have mostly endura and delicas spyderco knives. My question is there a standard factory angle that these are sharpened to? I want to dress them up as needed and don't want to do anything crazy . Factory specs are good enough for me. My smith adjustable sharpener lists 20 degrees as the setting . Is this correct?
AccountDeletedUserRequest
Re: Sharpening angles
Postby AccountDeletedUserRequest » Fri Nov 22, 2019 6:31 pm
They are usually ground a bit under 20 degrees, so using the 20 degrees setting should let you sharpen them up quickly.
If you want to be sure, color in the edge with a sharpie, then try a few strokes at 20 degrees. Looking at where the sharpie got rubbed off is an easy way to see where you're sharpening.
redhawk44357
Postby redhawk44357 » Fri Nov 22, 2019 6:54 pm
Thanks Vivi
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot], Stuart Ackerman, Woodpuppy and 22 guests
