Ikuchi
rivy
Re: Ikuchi
Postby rivy » Wed Nov 20, 2019 4:16 pm
Also been waiting on an Ikuchi and glad to hear about the CQI changes. Didn't the flipper area have a hard corner or something that would also sometimes catch people? Hopefully that's fixed as well.
paulwa
Re: Ikuchi
Postby paulwa » Fri Nov 22, 2019 6:00 am
Halfneck wrote:
Tue Nov 19, 2019 8:17 pm
Do we know that the Ikuchi showing up have these new CQI changes?
Stock at the larger dealers should all be the CQI version at this date.
I have a few CQI Ikuchis inbound from Spyderco, and will post some impressions on improvements once I get a chance to fiddle with them.
- Paul
JuPaul
Re: Ikuchi
Postby JuPaul » Fri Nov 22, 2019 3:42 pm
Anyone else have issues with flipping these open? I decided to try one, and it arrived today. The blade drops shut, so the pivot seems to be dialed in correctly, but I find it very difficult to flip open. I actually have given myself a blister on the pad of my pointer finger from the jimping on the flipper. I love the design, so I hate to part with this one if there's an easy fix - any tips for adjusting, or for a better technique to using the flipper "wheel"? Finger repositioning, etc?
Edit: nevermind, I think I've got the trick of it now. Just have to position your finger higher - almost on top of the flipper. The jimping still feels a bit ouchy for my taste, though. I wonder if grinding that down a bit might help, or if that'd make it harder to deploy again. Will have to keep playing...once my finger heals. ;)
- Julia
Doeswhateveraspidercan
Re: Ikuchi
Postby Doeswhateveraspidercan » Fri Nov 22, 2019 3:49 pm
Would you mind showing us a picture of the flipper wheel?
How is the tip of the blade is it recessed enough not to catch the tip of your finger.
Thanks
DSH007
Re: Ikuchi
Postby DSH007 » Fri Nov 22, 2019 4:10 pm
Try flipping with your thumb, like you would a bic lighter. Sounds counterintuitive at first, but it works quite well for me. I have a much tougher time flipping mine open using my index finger.
I have the pre-CQI model and find the action on mine to be excellent.. I find the blade shape to be quite useful and the knife is very ergonomic for its seemingly odd handle shape and bizarre opening method.. Definitely took some getting used to though. I think once you get the hang of it, you will really like it! :)
Rick H.
JuPaul
Re: Ikuchi
Postby JuPaul » Fri Nov 22, 2019 4:10 pm
Thanks
Here's the wheel. If I really push my finger into the scales, I can still catch the blade tip. But just running my finger along the scales, even with a little pressure, it does not catch the blade tip.
Btw, I edited my post above...think I've got the flip down now. I'll have to try the bic lighter flip, too.
- Julia
Spydergirl88
Re: Ikuchi
Postby Spydergirl88 » Fri Nov 22, 2019 4:17 pm
When I had an Ikuchi I liked the bic lighter flip and flipping it by releasing the lock tab and flicking my wrist.
Team Wire Clip
:spyder: :spyder: :spyder:
Spydergirl88
Re: Ikuchi
Postby Spydergirl88 » Fri Nov 22, 2019 4:18 pm
Is yours pre or post CQI?
Team Wire Clip
JuPaul
Re: Ikuchi
Postby JuPaul » Fri Nov 22, 2019 4:26 pm
Post CQI. It's from the most recent batch at DLT. Has the PB washers and drops shut. Now thst I've got the trick of the flip, I think I'm really going to enjoy this one.
- Julia
anycal
Re: Ikuchi
Postby anycal » Fri Nov 22, 2019 4:37 pm
Pre-CQI had PB washers, and mine dropped shut. The only way to know (other than marking on box, which I am not sure if there is a difference) is if it has a pivot bushing. Pre-CQI did not; new one is supposed to have it.
Peter
JuPaul
Re: Ikuchi
Postby JuPaul » Fri Nov 22, 2019 4:49 pm
Oh gotcha, was confused about that. Date stamp is KS.
- Julia
JuPaul
Re: Ikuchi
Postby JuPaul » Fri Nov 22, 2019 5:24 pm
Yes, mine has a pivot bushing.
- Julia
anycal
Re: Ikuchi
Postby anycal » Fri Nov 22, 2019 5:36 pm
Love it! Taking a brand new knife apart, whether to learn, examine, fine tune, mod, all good.
Peter
JuPaul
Re: Ikuchi
Postby JuPaul » Fri Nov 22, 2019 6:30 pm
Ha! Well you got me curious about that bushing! :p
- Julia
Re: Ikuchi
Postby TkoK83Spy » Fri Nov 22, 2019 6:59 pm
Haha, that was me when I first got my Smock on the first release. Had to figure out what was going on in there!! Amazes me when people are scared to take their knives apart, especially when they make actually need to do so.
Currently have 20 :spyder: 's in 14 different steels.
JuPaul
Re: Ikuchi
Postby JuPaul » Fri Nov 22, 2019 7:50 pm
Agree the smock is a neat knife to take apart! I'll admit, though, I still have yet to take apart a delica, even though I have like 6 of them. I've just heard it's such a pain...
- Julia
Spydergirl88
Re: Ikuchi
Postby Spydergirl88 » Fri Nov 22, 2019 7:58 pm
It is... Just when you almost have it lined up... Nope not good enough the pin won't drop in. Anytime I disassemble a Delica or other backlock Seki spydie I cuss so much, although it has gotten easier over time.. But not as much as the dreaded red loctite era gray g10 cruwear pm2... That was not fun
Team Wire Clip
Re: Ikuchi
Postby Doeswhateveraspidercan » Fri Nov 22, 2019 8:11 pm
Thank you so much, really appreciate the effort you put into this thread.
Thank you.
Dazen
Re: Ikuchi
Postby Dazen » Fri Nov 22, 2019 8:35 pm
Dazen wrote:
Tue Nov 19, 2019 2:03 pm
Saw that they are in at the SFO as well. I would buy one if it wasn’t for the CF/G10 scales, this beauty needs smooth CF scales!
Well...I gave in and have one on the way. Does anyone know if the scales are the same for the CQI model? I say this because if they recessed the tip does that not move the Spydie-hole slightly as well thus moving the hole in the scale?
JuPaul
Re: Ikuchi
Postby JuPaul » Fri Nov 22, 2019 9:11 pm
Thank you.
No problem! It was fun, and I was curious, too. :D
- Julia
Users browsing this forum: Google [Bot], jacala, MSN [Bot], Sumdumguy and 21 guests
