Sal, how about a Chaparral with 2.5mm blade thickness?
nativeleek
Postby nativeleek » Mon Nov 18, 2019 6:54 am
Hi Sal.
Chaparral is pretty much a perfect EDC folder for gentlemen's carry or for people with small to medium sized hands. The only thing that possibly needs to improve is the thin lock-bar, which may become a hot-spot when being pressed.
A simple way to solve this problem is to make the blade a little thicker, let's say from 2mm to 2.5mm. This will make the lock bar a lot more comfortable to press and also make the blade a little bit stronger, with absolutely no impact on the carriability.
If there is a plan for Chaparral 2, is it possible to make this change happen? Every other thing about Chaparral needs no change. Just make the blade a little thicker and keep everything else the same as the present Chaparral.
Thanks!
Delica 4, Dragonfly 2, Native 5, Sage 5, Chaparral, Techno 2, Positron, SpydieChef, Para 3, Lil' Native lockback
Re: Sal, how about a Chaparral with 2.5mm blade thickness?
Postby Evil D » Mon Nov 18, 2019 8:26 am
I think most will say go thinner and or if you want thicker get a Sage or Native 5.
How you carry yourself is just as important as what you carry.
Postby Wartstein » Mon Nov 18, 2019 8:38 am
Welcome to the forum, nativeleek!
Concerning your idea: I have to be honest, please NO!
Maybe the greatest thing on the Chap is its thin and slicey blade, rather unique even in Spydercos lineup.
A thicker blade and lockbar would also make the handle and the overall closed package thicker.
If you find the lockbar hard to press: Just let the knife break in, or do the easy mod that makes the lockbar less stiff (relocate the spring 2 or 3 mm)
/ And let me say: The Chap is great also for larger hands, it is somehow the "XL hands DFly" imho... ;)
Postby Doc Dan » Mon Nov 18, 2019 8:41 am
Sounds like you want a Sage.
https://www.facebook.com/fallplanet Author page
Telegram Channel: https://t.me/dandocthomas
Postby The Deacon » Mon Nov 18, 2019 8:43 am
Depends on whether you're using it as a tool or a toy. I'm 74 and have issues with joint pain in my fingers, yet closing a Chaparral two or three times a day, at odd intervals, after using it, doesn't really bother my hand. OTON, I'll admit it's not the knife I'd want to sit opening and closing repeatedly for a half hour while watching TV. But then autos, and especially DA OTF autos, are more fun for that anyway. :D
Evil D wrote: I think most will say go thinner and or if you want thicker get a Sage or Native 5.
Or even a Delica. :)
Albatross
Postby Albatross » Mon Nov 18, 2019 8:56 am
What about a Boye dent?
sal wrote:
Fri Nov 09, 2018 3:01 pm
...But in general, I'm all about high performance, Ergos, safety. That's why I've been accused of "deigning in the dark"...
nativeleek
Postby nativeleek » Mon Nov 18, 2019 9:23 am
Native 5 is actually one of my favorites, which you can tell from my ID. :)
For my hand size, Chaparral is actually a better choice than Native 5 in some way. I prefer a folding knife with a handle that accommodates all four fingers but does not stick out from my pinky in saber grip because in my eyes this is the smallest necessary closed length for maximum carriability.
Chaparral's extreme thinness does make it an extreme cutting machine, which I do love a lot. However, a handle with such a thin profile does sometimes bother me. Have you ever found that when you hold the knife for closing, sometimes the handle may have a tendency to rotate? If it's a little bit thicker, just a little bit, it will be much easier to hold the handle securely with your thumb on top and pointing finger on bottom.
nativeleek
Postby nativeleek » Mon Nov 18, 2019 9:33 am
Thanks, Wartstein.
Chaparral is definitely one of a kind in Spyderco's lineup. The thin blade not only slices like a champion but also has a very strong tip. I once reversely gripped a Chaparral and thrusted the blade into a hard piece of wood with at least 70% of my arm force. Surprisingly there was no damage to the tip at all. I have always been confident in Spyderco lockbacks and steels they choose, especially premium ones like this CTS-XHP.
nativeleek
Postby nativeleek » Mon Nov 18, 2019 9:41 am
Thank you, sir.
It sounds very reasonable. Possibly unlike most people, I prefer lockback to any other locking mechanism from Spyderco. I have about twenty spyderco folders and more than half are lockbacks. Delica 4, Dragonfly 2, Native 5, Lil' Native lockback, Chaparral, they serve both as a tool and as a toy. :)
TomAiello
Postby TomAiello » Mon Nov 18, 2019 10:47 am
I love the 2mm blade of the Chap, and I believe it's the thinnest blade available in Spyderco's catalog.
I say leave it as it is. And maybe add some more 2mm blades to the line up.
While I'm dreaming, I'd take a 2mm Chap in K390. :)
Postby The Deacon » Mon Nov 18, 2019 11:04 am
As with most things in life, YMMV, but I've found that the two edges of a flat lockbar hurt my thumb joint far less than the four sharp corners on a Boye dent.
GarageBoy
Postby GarageBoy » Mon Nov 18, 2019 1:09 pm
Leave it alone!
It's why new BMW cars have gotten softer - people like the idea of the performance, but don't actually like the rawness
Larry_Mott
Postby Larry_Mott » Mon Nov 18, 2019 1:11 pm
It's ok to laugh - but.. Wouldn't it be possible to fit a "cobra hood" ...ish thing on the lockbar release? Same width as the handle, or slightly thinner?
//Eva Mott R.I.P.
Postby Wartstein » Mon Nov 18, 2019 1:34 pm
:p
But seriously: As I said, maybe when the knife is new, the combination of both thin and rather stiff lockbar might be a bit uncomfortable for some fingers (I admit, mine certainly have some callus from climbing and playing guitar). But when the Chap is broken in, I don´t think that should be an issue anymore.
And IF: There´s alyways the "placing the spring more forward mod", which makes the lockbar a lot softer to press (at least that´s what people say, I myself feel no need to do the mod on my particular Chap FRN)
Albatross
Postby Albatross » Mon Nov 18, 2019 1:41 pm
My experiences with the Boye dent have been more pleasant. Every knife I've held, that had a Boye dent, felt smooth and comfortable, which actually meant I could press harder(if necessary) without any discomfort. As you said, YMMV. We aren't all the same afterall.
Postby Wartstein » Mon Nov 18, 2019 1:44 pm
Added to my post above:
To the OP (Nativeleek): Just to be clear, I think your idea and question shows that you really think about knives and how they could be even improved, and that´s a very good thing!
But I also think: If you really like everything on the Chap (so also the thin, slicey blade) but solely not the for you uncomfortable lockbar, then making it easier to press the bar is probably the better solution compared to making the whole blade and the whole knife thicker and by that giving up a bit of what makes the Chap so different and great in performance.
Here is a link to a post where you can see how the mod (relocating the spring in order to make the lock "softer") is to be done:
viewtopic.php?t=80687#p1253309
araneae
Postby araneae » Mon Nov 18, 2019 7:07 pm
You won't find many in favor of fattening up the Chap. I've got 4 and never saw the lock bar as an issue, but I've seen a couple posts mentioning it, and some find the above mentioned spring tweak remedies that scenario.
-Nick
Just got: Zcarta Shaman
Tgmr05
Postby Tgmr05 » Mon Nov 18, 2019 8:00 pm
I prefer the thin blade of the chaparral, and would prefer not adding any thickness to the overall package. For something with an easier to operate lockbar, a couple good options are the slightly shorter g10 dragonfly or the slightly longer native.
Halfneck
Postby Halfneck » Mon Nov 18, 2019 10:07 pm
Is the lock on my Chaparral LW harder to operate than my Delica - yes. Is it so hard that I feel the need to make the blade thicker - NO.
Yes I would like it if it was easier to operate my Chaparral LW's lock, but not at the expense of losing the thin blade.
And to further clarify - this is coming from a man who has no use in his left arm/hand and opens/closes all his knives 1-handed.
Postby Sharp Guy » Mon Nov 18, 2019 10:25 pm
It definitely works. You don't have to move it much to make a noticeable difference either
No thicker blade for me please. That thin blade is one of the features that makes the Chaparral what it is.
Users browsing this forum: Bing [Bot], eventhorizon, Google [Bot], Granoo Fink, JSumm, nerdlock, p_atrick, rhaug, sgtcole69, shaztec, The Meat man and 46 guests
