K390 Hawkbill Dragonfly?
ZrowsN1s
Re: K390 Hawkbill Dragonfly?
Postby ZrowsN1s » Wed Nov 13, 2019 10:01 am
:D I do wear jeans at work, black though. Like I said I'd be happy with any handle material, I just want liners.
As for the SE H1 being the perfect knife for the job, that's what I've been carrying since Spyderco released it. And it does a fine job. If SE was all I wanted, I would say Spyderco already makes the knife I'm looking for.
PE cuts different, offers different control. PE K390 will perform differently than SE H1. You may like those differences you might not. I'm looking for something different than what I have.
Carrying 3 knives is perfectly normal :D
-Matt
steelcity16
Postby steelcity16 » Wed Nov 13, 2019 10:20 am
I'm with you here. I love my SE H1 Spyderhawk and wouldn't change a thing about it. But I can see the value in a small PE Dragonfly Hawkbill for certain things.
steelcity16
This is also reminding me that I should pick up a G10 Dragonfly.
ZrowsN1s
Postby ZrowsN1s » Wed Nov 13, 2019 11:07 am
steelcity16 wrote:
Wed Nov 13, 2019 8:26 am
Zip ties can do some edge damage, especially the thicker ones. And If you are doing pull cuts on thick zip ties with a high hardness blade, the outward pressure you are putting on the tip as you finish your cut could be enough to shear the tip off. Maybe not with H1, but K390 being a harder steel i would be a little concerned.
I've watched BBB stab a brick with his Police4 :D I'm not that worried about the tip.
-Matt
prndltech
Postby prndltech » Wed Nov 13, 2019 11:09 am
I’m all for more dragonfly’s
- Shannon
Baron Mind
Postby Baron Mind » Wed Nov 13, 2019 11:46 am
I don't think you'd have to be overly concerned about a hawkbill in k390 breaking. As far as high carbide volume steels go, k390 is probably THE toughest in that class, and you have to remember, with high hardness comes high strength. Still not a great candidate for lateral stresses light prying, but for compressive forces, like cutting downward, k390 is going to be a top performer.
Postby abbazaba » Wed Nov 13, 2019 11:52 am
Given the recent expansions of the Seki line up, it will be interesting to see what is included in the next Sprint Run. Though I don't think it was part of the initial HAP40 run, the Delica Wharnie did eventually get the treatment. With any luck, we will see a few new models included in the inevitable K390 run (Endela and P4 seem like a given, wharnies and hawkbills not as much so).
ZrowsN1s
Postby ZrowsN1s » Thu Nov 14, 2019 1:51 pm
...(Endela and P4 seem like a given, wharnies and hawkbills not as much so).
:( but those are what I want the most! Wharnies and Hawkbills are where it's at man :D actually a k390 P4 lightweight is pretty high on my list too.
-Matt
AwayFromMySpydieHole
Postby AwayFromMySpydieHole » Thu Nov 14, 2019 6:21 pm
I would literally buy 3 k390 dragonflys if they came in the regular blade shape.
For some reason I have fallen in love with the Dfly lately. Owned one for almost 8 years and never really paid it much attention. Now I love it for some reason and I want to get all the variants.
But a k390 plain edge in the regular blade, I’d buy multiples of.
Postby Evil D » Thu Nov 14, 2019 6:49 pm
I'd be interested, and while I would like to try a steel like this in SE, I would initially be more interested if it were PE and especially FFG.
Sumdumguy
Postby Sumdumguy » Thu Nov 14, 2019 7:04 pm
prndltech wrote:
Wed Nov 13, 2019 9:26 am
prndltech wrote:
Tue Nov 12, 2019 10:49 pm
No way plastics would be stronger than a steel knife blade.
Not gonna say it can’t happen, but I haven’t experienced it... I also don’t have a lot of experience with super high hardness steels. I sure would be dissatisfied and disappointed if my knife couldn’t cut a zip tie.
S110V + zip ties = :.(
I still have nightmares.
prndltech
Postby prndltech » Thu Nov 14, 2019 8:58 pm
Never had a desire to try s110v. S90v is as high as I climbed in those steels.
- Shannon
Postby Evil D » Fri Nov 15, 2019 6:08 am
I've heard about these zip tie horrors but I haven't experienced them myself. In fact when the S110V Manix 2 LW came out I did some testing with heavy zip ties (the kind the police hog tie people with) and some banding straps and didn't experience any chipping at all. I wonder if some people are cutting zip ties against a harder surface and that surface is what damages their edge? When I did my testing I just folded the zip tie over the edge and pulled through it several times. I used to do videos about this stuff but I got sick of all the wise guy comments.
Tims
Postby Tims » Fri Nov 15, 2019 6:42 am
I reckon it might be the way some people are cutting zip ties that’s causing chipping rather than the material itself.
Sliding the blade under a zip tie and then torquing the edge up. That sort of lateral stress can be catastrophic for an edge, especially at low edge angles.
Postby Evil D » Fri Nov 15, 2019 6:50 am
I should correct myself, I definitely have had edge damage from zip ties but not with S110V. When I made the video my point was that I was surprised that I didn't see any chipping.
Postby Doc Dan » Fri Nov 15, 2019 8:59 am
ZrowsN1s wrote:
Tue Nov 12, 2019 4:47 pm
For my work in IT removal/installation, besides opening tons of boxes and packaging... cutting zip ties off of bundles of wire and removing tape from bundles of wires without cutting the wires is one of my most common tasks. Small hawkbills are almost the only suitable tool for the job.
It's also worth mentioning a lot of job sites I work at frown on, or do not allow, large knives. A delica would be too big. Making a Dragonfly the ideal work knife.
Even opening the boxes and packaging. Being able to make shallow pull cuts makes the job easier, and insurers you won't cut any of the package or box contents. For boxes, packaging, and zipties there is nothing better in my opinion.
A K390 Hawkbill Dragonfly, plain edge with liners would be a dream work knife for me. G-10, Carbon Fiber, Micarta, heck wood... that doesn't matter to me, I just want it to have liners and PE K390.
So how about it? Any takers?
There you go, spending my money. :eek: :D
I’d like a K390 Dragonfly. I love that little knife.
(Roy Rogers)
ZrowsN1s
Postby ZrowsN1s » Fri Nov 15, 2019 3:04 pm
...... I would initially be more interested if it were PE and especially FFG.
Doc Dan wrote:...
:D One of Sal's best designs IMHO
-Matt
Postby AwayFromMySpydieHole » Fri Nov 15, 2019 7:48 pm
Yessss.
In any color. Don’t care.
crazywednesday
Postby crazywednesday » Fri Nov 15, 2019 8:26 pm
I'm in for one or two. This should be a poll.
Justin
The Mastiff
Postby The Mastiff » Fri Nov 15, 2019 9:01 pm
Yes, absolutely.
I'm always going to be wary of high carbon/high carbide steels when it comes to SE blades . It didn't take much to lightly damage my ZDP SE blade in comparison to my SE blades in ATS 55 and Gin 1/G2. The damage was never great but it was noticeable even without a loupe. The S60V/440V knives were run at pretty low hardness for the same reason. I still have a couple 440V SE knives but I never gave those the same workout for whatever reasons.
I really like the K390 P4 and mule and I'll buy pretty much any backlock they make in it but I'd hold off on a SE blade in that steel until it was more proven in SE's.
Users browsing this forum: Bing [Bot], captnvegtble, Google [Bot], Granoo Fink, JD Spydo, Larrin, mb1, TkoK83Spy, Woodpuppy and 49 guests
