Bottom of pocket/clipless carry ?
bbturbodad
Re: Bottom of pocket/clipless carry ?
Post by bbturbodad »
I'll throw just about anything loose into my pocket. I've got a Stretch and a McBee both floating around in my right front pocket as I type this.
-Turbo
BOHAWG
Post by BOHAWG »
I carry a Solo in a pouch or a Dragonfly floating in the bottom of my pocket from time to time
Tgmr05
Post by Tgmr05 »
I rarely use the clip most days.. I actually take them off each/every dragonfly and chaparral I carry. I prefer them simply loose in the pocket. I tend to primarily use the clip on larger/heavier knives. The delica/salt2/native that get carried are about 50/50 clip free, as they are more borderline size/weight for bottom of pocket carry.
Post by The Deacon »
When I discovered Spyderco back in '03, I'd been carrying a knife in my left back pocket for 50 years. Didn't see any need to change that, so I've removed clips and carried my Spydercos that way ever since. Almost always a Stretch these days, but I've carried a Native, Delica, Rescue, Schempp Persian, R, Manix 83mm, Sage 4, or Kiwi 4 that way in the past and still occasionally carry an Atlantic Salt, Centofante Memory, or Chaparral that way.
standy99
Post by standy99 »
Delica wharncliffe had the clip removed the minute I looked at it.
Parra 3 50/50 clip on or off
Other 10-20 Spyderco’s clip on
Pelagic
Post by Pelagic »
I'm starting to like carrying ANY knife loose in the pocket if I'm on the water, lol.
But generally, spyderco's are the last ones I choose to carry loose. I just think they have the best pocket clips.
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
I just can't do it. Maybe with a Ladybug or something really small but it was pocket clips that really brought me into real everyday carry. When I was a kid and all I had was Case and Buck 110's I hated having a knife flopping around in my pocket. I even carry my Ouroboros clipped onto my pocket in a suit and dress pants.
Jazz
Post by Jazz »
The Deacon wrote:
Mon Nov 11, 2019 4:47 am
I always wonder, isn't that uncomfortable to sit on? Does it lay horizontal at the pocket's bottom?
- best wishes, Jazz.
prndltech
Post by prndltech »
Jazz wrote:
Mon Nov 11, 2019 7:57 am
I thought the same when people said the carried a military in the right back pocket.
- Shannon
MNOSD 0006
Post by JD Spydo »
Even all the way back to my teenage years I can't tell you all how many small folders I lost because of not having them secured. The Spyderco Pocket Clip changed the entire knife carrying regimen for me ever since I discovered it in the mid 90s. Actually I think it was around the early 90s when I got my first folder with a Pocket Clip. But I've never looked back since>> nor do I want to.
If I were to take the option of bottom of the pocket carry I'm not sure which model I would go for. I really just don't want to go back in time.
prndltech wrote:
Mon Nov 11, 2019 8:10 am
For me when I carry like that my Military is clipped next to my wallet, and my butt already has a dead spot from a lifetime of sitting on a wallet so I don't notice the knife.
Jazz
#32
Post by Jazz »
I always have a large folder in my right back pocket, but being clipped and upright, it doesn't bug me.
#33
Post by Doc Dan »
I carry a clip less Delica, Lil Native, Chaparral, Dragonfly, or Urban LW.
prndltech
#34
Post by prndltech »
Evil D wrote:
Mon Nov 11, 2019 8:19 am
I’ve always carried the minimum, tiny wallet in front pocket. No pick pocket for me!
Did this mainly because my dad developed some issues from sitting all day on a fat wallet in his back pocket. Doctor told him to get another one, split the stuff and put one in each back pocket if he was going to do that.
So I’m not use to having anything in my back pockets.
- Shannon
MNOSD 0006
#35
prndltech wrote:
Mon Nov 11, 2019 8:40 am
I guess it depends on where you clip the knife but in most of my pants I clip on the outside of the pocket and I really don't sit on the knife. For work I carry a flashlight clipped in the same pocket and it's really more on my hip than under my butt. I can usually slide my wallet over to the side too so I don't always sit on either one.
Actually now that I'm looking at it my flashlight is almost directly overtop of my Caribbean, it's only just slightly around towards my back and is almost on my hip just like my knife.
Mini2white
#36
Post by Mini2white »
Sometimes a Dragonfly if needing to be discrete.
#37
No, not any more so than the wallet in my right back pocket. Perhaps because I generally have a bandana folded up in the same pocket behind the knife as I've never had much in the way of natural padding back there (GF use to call me "the man with no ***") (I know TMI). :D And yes, I carry them horizontally at the bottom of the pocket, which is why I don't carry anything that's much bigger than 4.75" closed.
JonLeBlanc
#38
Post by JonLeBlanc »
For some reason (which I can't really remember) I took the clip off my S90V Millie and never put it back on. And I found right away that it was actually not bad at all to carry in the front pocket of blue jeans. I don't really feel it at all, and it doesn't float around since my blue jeans fit well. Makes for a nicely concealed large blade!
#39
The Deacon wrote:
Mon Nov 11, 2019 12:45 pm
I also suffer from Noassatall disease. I'm thinking about starting a support group.
prndltech
#40
Post by prndltech »
Evil D wrote:
Mon Nov 11, 2019 1:46 pm
I too suffer from this... I found a support group. They’re called belts :D
- Shannon
MNOSD 0006
