New Steel – Crucible S45VN
Larrin
Postby Larrin » Fri Nov 01, 2019 9:04 am
Crucible and Niagara have just announced a new stainless powder metallurgy steel – S45VN. I was able to get a bar of it early to do a range of experiments on it including hardness, corrosion resistance, and toughness. I have a recommendation on how to best heat treat it too. How does it compare to the existing stainless knife steels? https://knifesteelnerds.com/2019/11/01/ ... 5vn-steel/
rabbitanarchy14
Re: New Steel – Crucible S45VN
Postby rabbitanarchy14 » Fri Nov 01, 2019 9:59 am
Is spyderco trying it out?
In-Possession - Para 3 S35VN, Para 3 G10 M390 Red, Dice XHP, Lil Native S30V comp, Lil Native Rex 45 comp, Manix 2 M390 G10 BR, PM 2 M390 DLC BL, PM 2 K390 RG, MKM Voxnaes Isonzo N690, Benchmade 555HGBlu, Ontario Rat 2 Gr G10
On-Deck - Manix 2 DLC ?, Brouwer
Loved Steels - M390/20CV, S35VN, BD1N, XHP, S30V, N690, K390
James Y
Postby James Y » Fri Nov 01, 2019 10:10 am
Wow, great info, Larrin!
I suspect if any knife manufacturers decide to use S45VN, Spyderco will probably be the first.
bearfacedkiller
Postby bearfacedkiller » Fri Nov 01, 2019 10:37 am
I have found S30V to be a little corrosion prone for a stainless steel so this may be a welcome improvement.
I have seen quite a few people on the internet incorrectly state that S35VN has nitrogen. I guess they just assume the N is nitrogen? Maybe this S45VN will clear that up.
I expect to see knife knuts turning their collective nose up at S35VN like they did with S30V. Out with the old and in with the new.
When is the Mule coming out? :D
Larrin
Postby Larrin » Fri Nov 01, 2019 10:40 am
Yes it's kind of confusing. S30V has a nitrogen additions, while S35VN does not. The "N" in S35VN stands for niobium. But S45VN has both nitrogen and niobium. So it's a double "N" steel. I have a feeling no one is going to keep this straight.
Postby abbazaba » Fri Nov 01, 2019 10:52 am
Good read as always, thank you!
curlyhairedboy
Postby curlyhairedboy » Fri Nov 01, 2019 11:02 am
Larrin, well written!
EDC Rotation: PITS, Shaman, CF S90v Shaman, Ikuchi, Amalgam, CruCarta Shaman, Lil Native, Sage 5 LW, 4V Shaman, Watu, Rex 45 Shaman, Rex 45 Lil Native, S30v Endura, Swayback
Always in Pocket: Hawkbill Dragonfly 2 H1
Special and Sentimental: Southard, Smallfly G10, Squarehead LW, Ouroboros, Calendar Para 3 LW, 40th Anniversary Native
Would like to own again: Sheepsfoot Caribbean
Wishlist: CQI Kapara, Tanto PM2, Shaman Sprints!
emanuel
Postby emanuel » Fri Nov 01, 2019 11:18 am
Thanks for the article Larrin, it's always a joy reading about new steels. My question now is, why would I chose S45VN over M390? Seems to be slightly worse at everything, from toughness, wear resistance, to edge retention and corrosion resistance. If it costs the same as S30V/S35VN I could see a use for it, if its 10-20% more expensive, than we're in the price range of 20CV/M390.
Larrin
Postby Larrin » Fri Nov 01, 2019 12:19 pm
Here is the answer I gave in another forum:
"The reason that the somewhat better toughness result for 20CV and M390 is puzzling is because of the significantly coarser carbide structure. The finer structure of S45VN would be expected to lead to better ease in machining and sharpening and better resistance to chipping when compared with 20CV. So it could be that another effect (like RA) is what led to a good toughness result in 20CV and would not necessarily show up in the end knife, or would not translate to thin edges."
So I think more testing is required.
Ez556
Postby Ez556 » Fri Nov 01, 2019 12:32 pm
An increase in corrosion resistance is definitely nice.
Likes FRN
sal wrote:
Sun Aug 04, 2019 7:28 am
But in reality, there is nothing quite like a gun. And it has been said, "The only way to stop a bad guy with a gun is a good guy with a gun".
Sumdumguy wrote:
Tue Oct 08, 2019 4:35 am
Does that complexity decrease the simplicity? Not at all.
Pelagic
Postby Pelagic » Fri Nov 01, 2019 1:06 pm
Your article is amazing, thank you. The steel seems ok. Unless it has a really nice sharpening response I'll probably avoid it. I have a feeling it could see a surge of popularity in the market, yielding prices that don't exactly correspond with performance. Looks like another s##v steel.
That picture of Vanax's grain structure really puts things into perspective.
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
Larrin
Postby Larrin » Fri Nov 01, 2019 1:42 pm
Vanax is an interesting one. Its high corrosion resistance somewhat limits its max hardness (60-61 Rc), though that is enough for many knives. It has a nice fine carbide/nitride structure which likely helps with fine edge abilities. The high content of carbide/nitride still limits its toughness to being no better than something like S35VN though. It demonstrates some very intriguing R&D.
Postby JD Spydo » Fri Nov 01, 2019 3:44 pm
Say Larrin you've done another excellent thread and I now look forward to all the excellent blade steel threads you take the time to share with us.
I have one question about this new Crucible S45VN? Of all of Crucible's great blade steels which one do you think it resembles the most? Also which other high end blade steels of Crucible's competitor's that Sal has spoiled us on do you think it comes close to in overall performance?
Again Larrin we can't thank you enough for all this great information you take the time to share with us.
Larrin
Postby Larrin » Fri Nov 01, 2019 4:10 pm
It is closest to S30V, S35VN, and Elmax.
ugaarguy
Postby ugaarguy » Fri Nov 01, 2019 5:01 pm
Larrin, thanks for the article. I'll have to re-read it when I'm more mentally fresh.
The Mastiff
Postby The Mastiff » Fri Nov 01, 2019 7:03 pm
Larrin, thanks for getting this stuff to us as quickly as you did. As usual you cover the questions about performance we like to ask.
After thinking about it other than the sexiness of it being a new steel it seems to not really break any new grounds nor is it really filling any needs not already being filled. It should be a competent and fine performing knife steel. Right in the S30V to M390 range where so many other steels are already being used. Hopefully it's cheap enough to make it worth changing.
Joe
Postby Doc Dan » Fri Nov 01, 2019 8:31 pm
It seems to have better edge retention and corrosion resistance than S35VN, which is it bad at all. I note it is only marginally less tough than S35VN. Will it out perform S30V in edge retention? What about machinability?
Anyway, thanks for another good article.
(Roy Rogers)
steelcity16
Postby steelcity16 » Fri Nov 01, 2019 8:56 pm
Call me when when they improve upon Cruwear! :D
Postby sal » Fri Nov 01, 2019 10:13 pm
Hi Steelcity,
Cruwear was improved when Crucible decided to powder the material. Better than it had ever been. When I first learned about Cruwear, it was called Vascowear and Gerber made a Folding hunter with it. I liked the steel so I talked with Crucible about making some for us and they took upon themselves to improve it. Bravo to them.
S45VN is a steel that was developed by one of their metallurgists (Frank) as an improvement to S35VN. More incremental than revolutionary, but it did test well and we're working with it.
Baron Mind
Postby Baron Mind » Fri Nov 01, 2019 10:58 pm
So improved corrosion resistance, and toughness and edge retention in between s30v and s35vn. But what I find interesting is the higher possible working hardness. Run it around 63 and it may be worth the fuss, no?
Users browsing this forum: Bing [Bot], Google [Bot], Spydergirl88, Superfool, tbdoc4kids and 39 guests
