Pm2 pocket clip screws - is there a trick?
JuPaul
Postby JuPaul » Tue Oct 29, 2019 11:32 am
So I decided last night to switch the pocket clip to right side tip up carry on my new k390 pm2 (I carry my only other pm2 tip down in my back pocket usually, so never changed the clip). Anyhow, all the screws broke free easily, but they will not catch the threading in the other side's holes! No matter what I did they would just spin freely. I finally got one of them to catch and tighten, but I loosened it to adjust the seating of the other two screws, and then it wouldn't catch again. I finally gave up and decided I'd put the clip back on tip down today at lunch. And now only one of them will catch the threads there! Wth is going on??? Is there a trick? Is this a common problem?
- Julia
attila
Re: Pm2 pocket clip screws - is there a trick?
Postby attila » Tue Oct 29, 2019 12:19 pm
I had a PM2 for which a few scale and liner holes weren't quite concentric, causing what sounds like the same issue. I couldn't get it threaded for a while, and when I finally did, the screws became damaged by the glass fiber of the G10 as the screw forced through it.
Check for concentricity of the holes, and don't force it.
Own: VG-10 Delica, Old S30V Native, modified Breeden Rescue, VG-10 Delica, HAP40 Endura, ZDP-189 Dragonfly, S110V Manix 2 LW,Pakkawood Delica, Cruwear Para 3, SE H1 Dragonfly, M4 Manix 2, HAP40 Caly 3, smooth G10 S90V Native, K390 Urban, Pakkawood Dragonfly, smooth G10 Cruwear PM2, SE Pacific Salt, HAP40 Jazzlica, Blurple Native, P.I.T.S., DLC Manix 2, REX 45 PM2, REX 45 Para 3, XHP Manix 2 LW, Superblue Caly 3, DLT 20CV PM2, Rhino, SB Calypso Jr., B70P, PMA11, K03, G10 ZDP-189 Stretch 2, Kapara, REX 45 Military, 154CM Manix 2 LW, KW 204p PM2, Swick, Supergold Delica, back lock Lil'Native, AEB-L Urban, HAP40 Stretch, smooth G10 Cruwear Manix 2, Cruwear Military, M390 PM2, Cruwear Delica, CPM 4V Lil'Native, Mantra 2, Cru-Carta Shaman, M390 Para 3 LW, M390 Manix 2, K390 Police 4, RexWood Shaman, DLC Cruwear Shaman.
Waiting for: K490, Swick 5, and something purple
anycal
Postby anycal » Tue Oct 29, 2019 12:31 pm
Put the screws in first, without the clip.
Peter
FK
Postby FK » Tue Oct 29, 2019 1:18 pm
I had the identical problem with one PM2 in my collection.
Agree with inserting the screws first without clip,, they will have a longer engagement and form up the interface between steel liners and G10 scales.
Regards,
FK
aaronkb
Postby aaronkb » Tue Oct 29, 2019 1:23 pm
I’ve had a similar problem with two different PM2s recently.
JuPaul
Postby JuPaul » Tue Oct 29, 2019 3:45 pm
I just tried to put in the screws without the pocket clip, and still only one will engage. So I partially disassembled the knife to get a better look at the liners, and that's definitely the issue: the screws just won't go into the liner holes, they're not aligned exactly. Guess this means a trip to the spydie ER??
- Julia
Bloke
Re: Pm2 pocket clip screws - is there a trick?ml
Postby Bloke » Tue Oct 29, 2019 4:37 pm
JP, if you’ve already disassembled the knife it won’t hurt to engage the screws from the liner (inside) all the way and and try again from the scale side, see if that may help. For what it’s worth it fixed my Lum which had the same issue. :)
JuPaul
Postby JuPaul » Tue Oct 29, 2019 8:19 pm
Just to clarify...you mean screw in the screws backwards, going from the inside through the liner first then into the g10? I think I'd have to remove the lanyard tube to do that (which I didn't do before, I just twisted the scale/liner around). Without taking the tube out, only two clip screw holes were accessible with enough clearance to get a screw in from the inside. Still, might be worth a shot before sending it off - any chance that'd damage anything? I don't want to void any warranty coverage this would have.
- Julia
Bloke
Postby Bloke » Tue Oct 29, 2019 8:41 pm
Yes, as you say! You can’t hurt anything unless you cross thread them of coarse. :eek:
Sometimes it could just be a little bit of dry thread locker on the screws that is stopping them from starting. Hopefully it works out for you as did for my Lum. :)
JuPaul
Postby JuPaul » Tue Oct 29, 2019 9:07 pm
Thanks! I'll give it a shot tomorrow.
And thanks to everyone else for your help, too!
- Julia
Cambertree
Postby Cambertree » Wed Oct 30, 2019 6:41 pm
Also, not sure if you already do it, but whenever threading any screw, turn the screws in reverse first until you hear and feel that click sound, then screw them in normally.
Prevents cross threading every time (as long as the threads aren’t damaged).
JuPaul
Postby JuPaul » Fri Nov 01, 2019 8:31 am
Good advice - thanks! After getting out my magnifying glass (my eyesight sucks) it's pretty clear that the bottom 1/4 of the threads on two of the screws are flattened. Imo, pretty crazy that this could happen after removing them once and rescrewing them once. I'm gentle, never force anything, and pretty careful not to crossthread, although I haven't used that trick before. Anyhow, spyderco is sending me new screws, so I'll be sure to use that trick with the new ones.
- Julia
jpm2
Postby jpm2 » Fri Nov 01, 2019 9:28 am
Valuable tips when dealing with anything threaded.
koenigsegg
Postby koenigsegg » Fri Nov 01, 2019 9:49 am
This happened with my Rex45. Took out the screw and it had no threads on it! Stripped bare from the factory
S30V, VG10, M4, XHP, BD1, Maxamet, 204P, H1, K390, A11, Rex45, LC200N, M390, 20CV, BD1N
W7H2O
Postby W7H2O » Fri Nov 01, 2019 6:17 pm
Cheap screws?
Spydergirl88
Postby Spydergirl88 » Fri Nov 01, 2019 6:43 pm
This thread is a good example of how great the forumites are 👏
Team Wire Clip
:spyder: :spyder: :spyder:
Users browsing this forum: ABX2011, Himark800, Johncjeff, koenigsegg, Majestic-12 [Bot], MSN [Bot] and 34 guests
