Blade tip repair
mpgtsm
Blade tip repair
Postby mpgtsm » Fri Oct 25, 2019 11:44 am
I bought a second hand multitool online. The tip of the s30v blade is dull. It’s not real obvious visually but it is very dull. I wonder if it’s worth trying my sharpmaker, or a flat stone? I don’t have much experience re-profiling. Any advice? I’ll probably order a new blade if I can find one. I guess it can’t hurt to try at this point.
A.S.O.K.A
Re: Blade tip repair
Postby A.S.O.K.A » Fri Oct 25, 2019 11:58 am
Check out this video from BamaKnifeGuy heres the link
https://youtu.be/mvbq-lfBlSs
He shows how he repaired a socom elite with major damage. If your tip damage is as small as I think, you definitely dont need to waste money on another blade. Good luck.
Every Steel Has Its Appeal :cool:
A.S.O.K.A Edge on Youtube
bearfacedkiller
Postby bearfacedkiller » Fri Oct 25, 2019 12:23 pm
Tape a piece of sandpaper to a counter or work bench and grind the spine down until your tip is pointy again. I’ve done it many, many times.
aaronkb
Postby aaronkb » Fri Oct 25, 2019 4:50 pm
I was gonna suggest doing this on a stone (I’ve done it a whole bunch), but I like the idea of using sandpaper since it’s more disposable and you won’t have to worry about wear.
Basically any time a tip is super messed up I turn it into a ‘reverse tanto.’
Postby sal » Fri Oct 25, 2019 7:54 pm
Hi Mpgtsm,
Your Sharpmaker will do just fine.
mpgtsm
Postby mpgtsm » Sat Oct 26, 2019 5:08 am
Hi Mpgtsm,
Thanks sir. I’m sure it will. I started on it last night. It’s almost “there”. I want near perfection of course. I love the SM. It’s saved me a lot of money and produced the sharpest edges I’ve ever seen in person.
Users browsing this forum: archangel, bearfacedkiller, buckleys, Cscottsss, DTPrime, elena86, FullFlatMind, Google [Bot], JacksonKnives, MSN [Bot], Mushroom, Surfingringo, The Meat man and 22 guests
