Manbug Salt/ Ladybug Hawkbill Salt comparison
Enactive
Re: Manbug Salt/ Ladybug Hawkbill Salt comparison
Postby Enactive » Sun Oct 27, 2019 5:11 pm
Thanks for this, 40mm! Both knives are interesting to me, but I'd only like one, not both. I also have the sense I would prefer the non-existent Manbug hawk.
40mm
Postby 40mm » Sun Oct 27, 2019 7:59 pm
The Ladybug hawkbill is ground thinner than the Dragonfly though right?
Evil D wrote:
Sun Oct 27, 2019 4:54 pm
If I could only have one of these I'd probably go for the Ladybug, but I'd definitely choose the Dragonfly Salt over either. These two (especially the Manbug) are ground so thick that they don't slice near as well as the Dragonfly. I originally bought the Ladyhawk hoping it would be a decent box knife but it binds up like crazy.
DOUBLE D
Postby DOUBLE D » Sun Oct 27, 2019 8:04 pm
You might try hitting the serrations with the sharpmaker corners to soften the points and peaks of the individual serrations. This should make it not bind. I disliked SE at first because of the binding, but it's better now after knocking those parts down a bit. I'm still a plain edge guy though.
40mm
Postby 40mm » Sun Oct 27, 2019 8:07 pm
The Ladybug hawkbill is ground thinner than the Dragonfly though right? The Manbug salt is definitely quite a bit thicker than the Ladybug.
ImageUntitled by Six Pound Cat, on Flickr
Postby Evil D » Mon Oct 28, 2019 4:02 am
The problem is the low hollow grind. Even though the Ladybug is a thinner blade, the grind ramps up to max thickness much sharper than the Dragonfly.
DOUBLE D
Postby DOUBLE D » Mon Oct 28, 2019 7:00 am
Ah, I see that now. Thanks for pointing that out
Postby Evil D » Mon Oct 28, 2019 7:21 am
It may also be a perception issue since I can get a much better grip on a Dragonfly, so the Ladybug may just feel like it binds more because I've only got 2 fingers on it vs 3.5 on a Dfly. Then again there's a noticeable difference between my standard Dragonfly Salt and the hawkbill version, and the hawkbill is ground much lower than the standard version.
40mm
Postby 40mm » Fri Nov 01, 2019 5:57 pm
Well one week in and the hawkbill Ladybug taken over my pocket. Manbug has been ignored completely. Trying out a little lanyard for right now. I like it so far. Something special about this little knife. ImageUntitled by Six Pound Cat, on FlickrImageUntitled by Six Pound Cat, on Flickr
Users browsing this forum: Bing [Bot], BornIn1500, Doc Dan, Google [Bot], Mini2white, MSN [Bot], pushcut, Wright.88 and 18 guests
