Pretty much completely agree with all of this.DOUBLE D wrote:I too am a firefighter, and I agree with this. (Pac salt serrated)Cycletroll wrote: ↑Sat Oct 19, 2019 4:47 pmI'm a firefighter and my most frequently carried Spyderco is a Pacific Salt, FWIW
It's thin, light in pocket, impervious to rust, easy to sharpen, tough, has a strong tip, easy to use ambidextrous with or without gloves, and not too expensive if I lose or destroy it while on duty.
The assist is certainly a nice purpose built knife, and if you think he wants something to put in his turnout gear to use only on emergencies, then maybe the assist is the best choice.
If however he would prefer something to carry on his uniform instead, then definitely go with something like the Pac salt serrated. Or maybe wartstein's serrated endela. I will say that everything gets wet on this job... Everything. Which is why a salt knife is so handy. But vg10 and stainless liners haven't caused me any issues yet.
I'd be cautious about any of the suggestions that include liner locks, compression locks, and even the cbbl. When your working hard, knives can open. I've cut myself before on a liner lock knife that opened in my turnout coat. I've since switched to a knife that locks in the closed position to put in my turnout coat. But the assist may have a strong enough closing bias to work in that role. I've never personally handled one. I used to like knives that had all the things the assist did like the glass breaker and belt cutter, but I realized I don't use those functions. (Honestly I rarely use the knife on a scene) Firefighters have every tool in the world between the truck and their turnouts.
No disrespect to any one else who commented, but definitely don't go with a Caribbean. I do like those knives a lot, but it has a very weak detent compared to some other compression lock knives (pm2, para 3), and will be much more likely to open up in his pocket while he's working. (Mine opened up in my jeans pocket and I wasn't doing very much when it did)
I do think your all around best choice is the Pac salt. Did I mention it has a wider spydi hole to work better with gloves than say the endura, endela etc... It has lots of positives for this type of work, and is the cheapest of all of them.
Also, look into the channelock rescue series of tools. They make a great multi purpose tool for firefighters. One tool the size of large pliers and it has cable cutters, pry bar, gas shutoff, and spanner wrench etc. That's a tool that will get used a lot, then you can get him the byrd rescue to go with it and you'll have spent under $100 total
(Off topic)
You have no idea how much I wish spyderco would make a manual opening salt series with a secondary safety that locked it closed, and could be disengaged and opened/closed and reengaged with one hand. In the future (not any time soon) ill make a post about this very thing and talk in more detail. I was a beach lifeguard and have carried salt series knives in pretty much the worst conditions. The exact type of conditions that will cause one to open. After tightening down pivots my other work around was to tie a hair tie through the lanyard hole just tight enough to where it can slip over the butt of the handle and the blade can be deployed. (This doesnt work on some knives depending on the profile of the spine of the blade to the butt of the handle in the closed postion, but it does work on many.) Its cheap, and replaceable, but it can still break and requires two hands to "disengage" the hair tie.
(On topic)
Agree on the caribbean. The detent is weak. Mine will ride on the drybag of the boat or get light edc. But I really wouldnt want to even go jogging with it.
Agree on avoiding pretty much everything thats not a backlock for a lot of reasons. But blade retention and self close bias are pretty much at the top of that list.
Agree that most people will find out in rescue type situations a knife is not commonly used or reached for. However its still way better to have one and not need it than the alternative.
My real recommendation would be something cheap that can be lost. If it has to be a spyderco though ill say assist salt, saver salt, atlantic salt, pacific salt, salt 2. Whichever you like.
