Note to self - only let the GF carry stainless knives...
aaronkb
Postby aaronkb » Thu Oct 17, 2019 11:19 pm
Because she just put my 940 through the wash. Thank god it’s in 20cv 😂
Slightly bitter that even my washing machine couldn’t remove the cardboard box adhesive I’ve been struggling to get off...
Re: Note to self - only let the GF carry stainless knives...
Postby Doc Dan » Fri Oct 18, 2019 2:26 am
Some of her fingernail polish remover will likely take it off.
Both my wife an I have accidentally washed knives.
(Roy Rogers)
standy99
Postby standy99 » Fri Oct 18, 2019 3:26 am
I washed the air conditioning remote the other day trying to help our. Bundled the quilt cover and sheets all up, it must have been lying on the bed :(
redhawk44357
Postby redhawk44357 » Fri Oct 18, 2019 3:58 am
Try goo-be-gone It removes all the sticky stuff
ronT2
Postby ronT2 » Fri Oct 18, 2019 4:16 am
Brake cleaner works pretty well for me.
My EDC rotation: Kapara, Chaparral CF, Mantra, Sage 1, Sage 5, Dice, Domino, Gayle Bradley 2, PakkaDelica, Native CFF
Woodpuppy
Postby Woodpuppy » Fri Oct 18, 2019 5:20 am
Brake cleaner is way harsh! A stone and denatured alcohol should handle the adhesive.
:spyder: My other blade is a Kelly Perfect :spyder:
Woodpuppy
Postby Woodpuppy » Fri Oct 18, 2019 5:23 am
Last girlfriend I let carry a Spyderco lost my Q :mad:
No more girlfriends for me!!!! That and I married one... and she has her own Squeak :cool:
bearfacedkiller
Postby bearfacedkiller » Fri Oct 18, 2019 5:44 am
Any solvent will remove tape glue.
I sometimes deliberately clip a knife to the pocket of my cargo shorts and send it through the wash. They come out squeaky clean. I dont let them go through the dryer though.
I carry my cap lifter clipitool in my watch pocket and it has been through the wash more times than I can count. I always forget to check that little pocket.
Postby Doc Dan » Fri Oct 18, 2019 5:51 am
There is a lot to be desired in a knife with H1 or LC200n or N680 steel it seems. We all run our knives through the washer and some more often than others. Hahaha! :D
(Roy Rogers)
ronT2
Postby ronT2 » Fri Oct 18, 2019 7:11 am
A stone is less harsh than brake cleaner??? I must be missing something??? :confused: The next time I need to sharpen or reprofile a knife i'll try some brake cleaner.
bearfacedkiller
Postby bearfacedkiller » Fri Oct 18, 2019 7:35 am
I wouldn’t use brake cleaner. Toxic stuff. Stick with a light solvent like alcohol, mineral spirits or paint thinner. If that doesn’t work try nail polish remover (acetone). If acetone won’t take it off then nothing will. Just avoid any prolonged contact between acetone and composite materials like G10, CF or micarta.
Marulaghost
Postby Marulaghost » Fri Oct 18, 2019 7:43 am
I use rubbing alcohol
Ez556
Postby Ez556 » Fri Oct 18, 2019 7:56 am
I use brake cleaner to clean the crud off my work knife all the time, brake cleaner is good for everything! The stuff I use is non-chlorinated though and is pretty much plastic safe.
Likes FRN
sal wrote:
Sun Aug 04, 2019 7:28 am
But in reality, there is nothing quite like a gun. And it has been said, "The only way to stop a bad guy with a gun is a good guy with a gun".
Sumdumguy wrote:
Tue Oct 08, 2019 4:35 am
Does that complexity decrease the simplicity? Not at all.
Postby Evil D » Fri Oct 18, 2019 8:16 am
I've ran my Dragonfly Salt through the wash more times than I care to admit. I think there's something subconscious about that knife where I just don't care if it gets washed because it doesn't effect it. It comes out squeaky clean lol.
rabbitanarchy14
Postby rabbitanarchy14 » Fri Oct 18, 2019 8:27 am
I have washed my para 3 s a few times. Off topic question. Has anyone had a knife open in the wash?
In-Possession - Para 3 S35VN, Para 3 G10 M390 Red, Dice XHP, Lil Native S30V comp B, Manix 2 M390 G10 BR, PM 2 M390 DLC BL, PM 2 K390 RG, MKM Voxnaes Isonzo N690, Benchmade 555HGBlu, Ontario Rat 2 Gr G10
On-Deck - Manix 2 DLC ?, Brouwer, Lil Native compression 20CV/M390
Loved Steels - M390/20CV, S35VN, BD1N, XHP, S30V, N690, K390
Doeswhateveraspidercan
Postby Doeswhateveraspidercan » Fri Oct 18, 2019 8:40 am
Lol gave mine a PM2 in S110V!!
Just use rubbing alcohol takes the sticky crap right off.
aaronkb
Postby aaronkb » Fri Oct 18, 2019 11:28 am
Honestly this adhesive is on some kind of steroids, rubbing alcohol is my go-to and it hasn’t worked at all for this! Thanks for the suggestions, I’ll give acetone a try.
carrot
Postby carrot » Fri Oct 18, 2019 11:36 am
Lighter fluid (it's the napatha) is my go-to. Instantly dissolves any adhesive.
legOFwhat?
Postby legOFwhat? » Fri Oct 18, 2019 11:49 am
Rubbing alcohol and a cotton ball works very well. Just lay the blade down flat on a surface so the edge doesn't get you and rub away.
-Larry
Postby Doeswhateveraspidercan » Fri Oct 18, 2019 11:52 am
Excellent suggestion.
Users browsing this forum: austrian_spyder_fan, Bing [Bot], Enactive, eRoc, fixall, Freediver, Giygas, Granoo Fink, JD Spydo, Karl_H, legOFwhat?, Majestic-12 [Bot], mjcarp, root, Sumdumguy, Wartstein, wheats and 37 guests
