An Ambitious Design
BG-ThatsMe
An Ambitious Design
Postby BG-ThatsMe » Wed Sep 25, 2019 9:06 am
Can anyone shed some light on the positioning of the plunge grind on the Ambitious?
It lies covered up within the liners/finger guard area on mine.
I think it's intentional, because the stock photos hint at that positioning.
Regardless, it looks like you can't really get all the blade when sharpening even if you work with it unlocked.
There appears to be enough meat in the guard area to grind down, but wondering why the factory didn't do this...
It's a solid knife otherwise; One that I have enjoyed using.
Any thoughts?
A.S.O.K.A
Re: An Ambitious Design
Postby A.S.O.K.A » Wed Sep 25, 2019 12:00 pm
I would suggest taking the knife apart and grind a sharpening choil in the blade
Every Steel Has Its Appeal :cool:
A.S.O.K.A Edge on Youtube
Ez556
Postby Ez556 » Wed Sep 25, 2019 12:06 pm
That’s one way to have a longer edge length than blade length.
Likes FRN
sal wrote:
Sun Aug 04, 2019 7:28 am
But in reality, there is nothing quite like a gun. And it has been said, "The only way to stop a bad guy with a gun is a good guy with a gun".
Sumdumguy wrote:
Tue Oct 08, 2019 4:35 am
Does that complexity decrease the simplicity? Not at all.
zhyla
Postby zhyla » Wed Sep 25, 2019 3:08 pm
I think it's just a super compact design and they didn't want to give up 1/8" to have the plunge farther out. I don't remember having an issue sharpening but even if it was sticking out more that last bit is tough to sharpen with the plunge anyway.
AccountDeletedUserRequest
Postby AccountDeletedUserRequest » Wed Sep 25, 2019 3:24 pm
If you do that then you will be sharpening even less of the cutting edge, as there will be less cutting edge total, and things can get caught up in that notch when cutting them.
I know it bugs you OP, but I wouldn't worry about it.
BG-ThatsMe
Postby BG-ThatsMe » Wed Sep 25, 2019 3:43 pm
I hear you. It looks peculiar, but it does cut through materials fine with edge all the way to the handle.
Postby Evil D » Wed Sep 25, 2019 5:03 pm
If it were me I'd take the whole knife apart, put the two liners and scales together, and grind down the front of the handle until the plunge line and edge are exposed.
knivesandbooks
Postby knivesandbooks » Wed Sep 25, 2019 6:13 pm
If it were me, I wouldn't worry about it on this one.
I own an assisted knife and am embarrassed to admit I enjoy it.
koenigsegg
Postby koenigsegg » Wed Sep 25, 2019 8:09 pm
My Sliverax is also a pain to sharpen
S30V, VG10, M4, XHP, BD1, Maxamet, 204P, H1, K390, A11, Rex45, LC200N, M390, 20CV, BD1N, S45VN
BG-ThatsMe
Postby BG-ThatsMe » Thu Sep 26, 2019 10:44 am
That makes sense to do, but it does seem odd that this appears to be the way the knife was designed versus being out of spec.
There looks to be plenty of liner steel to grind away (even with everything going on around the pivot/clip area). Also looks like the back of the blade when closed will still sit within the liners.
Good advice. Thanks
Users browsing this forum: gdwtvb, JD Spydo, Majestic-12 [Bot], mikey177, Zachreed1 and 29 guests
