Spyderco 2019 Reveal Volume 3 Per Knife Center
- curlyhairedboy
Re: Spyderco 2019 Reveal Volume 3 Per Knife Center
That's one reason why I like the Caribbean. Comp lock salt is very nice.
Can you name a lock that is safer and more reliable at keeping a knife closed?rabbitanarchy14 wrote: ↑Tue Sep 17, 2019 7:37 amIf you saw that then you would have also seen the delica 4 of which I had 2 and a manbug, plus my friends have tried.TkoK83Spy wrote: ↑Tue Sep 17, 2019 7:02 amHave you ever had a Spyderco backlock knife? You won't be disappointed if you tried. I see you have a lot of compression locks, give one a try.rabbitanarchy14 wrote: ↑Tue Sep 17, 2019 3:14 amI do have to admit the siren looks sweet. very functional and a good steel. why i wont get one is because of the lock and blade size.
if they make a siren 2 with a better lock (anything not backlock) and a 3" blade, i would own one and it would be absolutely incredible.
just one salt that is not a backlock or huge would be a great alternating to the overly saturated backlock only market in salts or the big Caribbean.
No I hate backlocks with passion. They bite when closing because of the spring, the lock takes more force, there is always a degree of lock rock, then there are the extra motions of a backlock, open/close. You also can't just fiddle with it like an axis or compression. The fact it takes much more force to flick open if you even can. No none of that says safety or reliability.
Not all backlocks have lock rock. They don't require extra motions. Press a lock release and they shut, pretty simple. https://streamable.com/2rzwf
