https://i.postimg.cc/fywBnT1Z/20201113-023435-HDR.jpg
For sure do your practice on a knife that isn't so important. I tell everyone when they get their first 204 Sharpmaker to do their learning and practice on for at least the first month or so to use a boring kitchen knife or just some old Boy Scout knife they've had for years. Please don't start out with a $200 to $300 Spyderco or other high end knife.jpm2 wrote: ↑Thu Nov 12, 2020 9:23 pmI suggest a cheap paring knife, and have at it.Chieforman wrote: ↑Wed Nov 11, 2020 5:24 pmSomeone needs to start a Spyderco sharpening class in N. Ca. because beyond using the Sharpmaker I can guarantee everyone I will destroy every knife I love learning to use a stone
Put this edge on November 5th. It's the 14th and it still glides through soft, ripe tomatoes with ease.vivi wrote: ↑Thu Nov 05, 2020 10:49 pm
So a while ago I tried these diamond plates from Harbor Freight out. Wasn't impressed. Didn't get good edges off of them holding them in my left hand and the knife in my right.
Today I decided to add some rubber feet to the bottom and try the 180 grit again. Reset the bevel on my chef knife I use at work. Here's a photo of the edge straight off the stone:
Very coarse edge. This stone reprofiles faster than any stone I've tried, second only to my powered equipment.
Despite the large crusty burr visible in that picture the knife could scrape shave right off this stone
I followed up with 5 passes per side on the sharpmaker at 15 degrees with brown rods, then finished with 3 passes per side on a 7 micrin diamond compound loaded strop.
I can run my nail down the edge and it feels very coarse, like its fresh off the 180 grit stone, but it sends arm hairs flying with a light touch. Excited to take it in to work tomorrow. It should push cut with ease, and once I've dulled it some it should still slice ripe tomatoes easily with the toothiness left on the apex.
I’ve reprofiled my Tenacious in 8cr13mov on the sharpmaker brown rods to 15 degrees, and it took ages. I estimate 2 hours spread over multiple sessions. In my limited experience sharping friends’ VG-10 knives, it would take at least that long in your situation. There are definitely others with more experience who could give you a better ball parkpantagana23 wrote: ↑Sun Nov 15, 2020 2:50 amPeople,
Have any on you tried reprofiling a VG10 Delica to 15 dps with standard Sharpmaker stones (medium, fine)?
From info I got, standard factory angle is cca 17dps.
Looking whether to do it or not, depending on how long it would take.
Also, would it make sense to sticky this thread?
I haven’t done it myself.pantagana23 wrote: ↑Sun Nov 15, 2020 2:50 amPeople,
Nice work Turbo.bbturbodad wrote: ↑Fri Nov 13, 2020 10:33 pmReprofiled the Dragonfly on a Galley V.
I used 80 grit sandpaper wrapped around the ceramic rods to hog off the steel and then finished with 400 grit paper. I'm tempted to pick up a set of CBN rods but I don't think they'll last very long when taking off this much steel. I think the Galley V is supposed to be 10° but my angle cube was measuring ~11.5° either way it's more acute than the Sharpmaker.
I'll second this entire post.Cambertree wrote: ↑Tue Nov 17, 2020 7:41 pmI haven’t done it myself.pantagana23 wrote: ↑Sun Nov 15, 2020 2:50 amPeople,
It’s possible, but the brown Sharpmaker rods are not really the tool for the job. They load up fairly quickly in that type of work, and have a fairly limited contact area.
You could use the diamond/CBN rods, or as JakeXman mentioned, clip coarse sandpaper to the flats of the rods.
You’d probably want to use that ‘scrubbing’ motion if you use the Sharpmaker.
A coarse stone like the Norton Crystolon, the Gritomatic SiC benchstones, or the Harbor Freight four sided diamond setup Vivi has been using are inexpensive and far better suited to reprofiling edges.
My approach would be to use a coarse benchstone to thin out the edge at about 9-11 dps, then apply a 15 dps microbevel with the Sharpmaker.
VG10 can take quite thin, acute edges.
I use a hybrid sharpening technique,like some others,of using a coarse hone to grind the relief angle and finish with the Sharpmaker.I realize some are hesitant about freehanding the relief but your not trying to get an exact angle but just thinning.With a coarse hone it should take less then a half hour even with thick edges.JakeXman wrote: ↑Tue Nov 17, 2020 11:10 amI’ve reprofiled my Tenacious in 8cr13mov on the sharpmaker brown rods to 15 degrees, and it took ages. I estimate 2 hours spread over multiple sessions. In my limited experience sharping friends’ VG-10 knives, it would take at least that long in your situation. There are definitely others with more experience who could give you a better ball parkpantagana23 wrote: ↑Sun Nov 15, 2020 2:50 amPeople,
Also, would it make sense to sticky this thread?![]()
Prior to Sharpmaker, I used Fallkniven diamond/carbon stone for sharpening, where I would follow the existing bevel of the blade.Cambertree wrote: ↑Tue Nov 17, 2020 7:41 pmI haven’t done it myself.pantagana23 wrote: ↑Sun Nov 15, 2020 2:50 amPeople,
You don't need to stress over angles so much when setting the bevel. I reprofile all of mine free hand and shoot for roughly 10 degrees per side. Maybe my M4 Manix is 8 degrees on the bevel, maybe 10, maybe 12 degrees....either way it outcuts the factory edge easily.pantagana23 wrote: ↑Wed Nov 18, 2020 9:43 amPrior to Sharpmaker, I used Fallkniven diamond/carbon stone for sharpening, where I would follow the existing bevel of the blade.Cambertree wrote: ↑Tue Nov 17, 2020 7:41 pmI haven’t done it myself.pantagana23 wrote: ↑Sun Nov 15, 2020 2:50 amPeople,
This would, however, end up as convex secondary bevel, or to be more truthful, the edge was all around the place.
The only steel that ended up great on the stone was LC200N.
It was when I started using Sharpmaker, that I finally found that the secondary bevel always has to be at 90 degrees to the stone (previously I would swipe it at maybe 45-90 degrees, making the edge on the root of the blade always the sharpest, and the tip was spoon-sharp.
I cannot reprofile to 15 dps on the stone, because I have no idea where the 15 degrees is. I used the phone once on the flat part of the blade to try to figure out where 15 is, but that was a joke: you cannot sharpen with your phone leaned to the blade, and as soon as you take it off, the angle continuously changes by little.
I think I'll just get diamond rods for Sharpmaker, or get KME.
Am I getting you correctly: I could start on diamond stone on a lesser angle than factory.vivi wrote: ↑Wed Nov 18, 2020 9:49 am
As long as the freehand bevel ends up wider than the factory one and I can hit the apex of the new edge using the sharpmaker at 15 degrees I'm happy.
Yep, that's exactly what I do. The stone I use is only $12 too....much cheaper than a KMEpantagana23 wrote: ↑Wed Nov 18, 2020 10:00 amAm I getting you correctly: I could start on diamond stone on a lesser angle than factory.vivi wrote: ↑Wed Nov 18, 2020 9:49 am
Hmm, this way I could get it to the Sharpmaker afterwards on 30.
Now I just have to find a sacrificial knife for the test![]()
Yes, as Vivi and Robert Ptacek said, don’t worry about the exact edge angle when thinning out the factory edge.pantagana23 wrote: ↑Wed Nov 18, 2020 9:43 amPrior to Sharpmaker, I used Fallkniven diamond/carbon stone for sharpening, where I would follow the existing bevel of the blade.
For anyone questioning which goniometer this is, found it's Gritomatic Laser Edge Goniometer Lite 2.0Cambertree wrote: ↑Wed Nov 18, 2020 6:30 pm
The only reason I quote 9-11 dps for my reprofiled edges is because I recently acquired a goniometer, so I know exactly what angle they are. They’re actually more acute than I thought.
There’s plenty of inexpensive knives with decent steel and proper heat treatments that you can use to practice with.
Users browsing this forum: AHarbuck, Google [Bot], negative d, PeaceInOurTime, ramasipsc, skeeg11, Sumdumguy and 33 guests
