Questionable Techno 2 Lockup
DBarrier
Post by DBarrier »
Looks like only the very tip of the lockbar on my new Techno 2 is making contact with the blade Tang. Just wondering if this is normal? The knife currently has no play in any direction, but I am wondering if this will be an issue down the road. The pictures included should highlight the contact gap and wear on the tang of the knife. Any response is appreciated!
Squawk
Re: Questionable Techno 2 Lockup
Post by Squawk »
Not sure what you mean exactly, but it looks like perfect lockup to me! :-)
awa54
Post by awa54 »
I can see what you're talking about, I'd expect that the lock would be safe as long as there is sufficient engagement depth and that it might eventually wear in to fitting better. However, I'd also say that it's an important clearance and that it's out of spec by a fair amount, so a return for adjustment or replacement isn't an unreasonable request.
I'm also guessing that the stop pin is what's out of spec and creating the misalignment between tang and lockbar, the fix might be as simple as loosening the knife up, spinning the stop pin until the engagement is better and re-tightening... if you're not already comfortable with doing your own work though I'd let Spyderco do that (or whatever remedy they figure out).
-David
DBarrier
Post by DBarrier »
awa54 wrote:
Fri Aug 09, 2019 11:41 am
I appreciate the response and I totally agree. Unfortunately I live in Canada so our knife laws make it almost impossible to ship the knife back to Spyderco for warranty service and have it arrive back in Canada without being seized at the border. Good news is I'm no stranger to taking apart Spydies, so I'll probably just wait untill it is in need of a clean and see what I can do while I've got it apart.
I would return that to spyderco
Spydergirl88
3 Nats, 1 Chap, 1 Sham, 1 Urb
jpm2
Post by jpm2 »
Squawk wrote:
Fri Aug 09, 2019 11:01 am
There is something questionable here, for sure.
awa54
Post by awa54 »
huh... trolls be trollin' ?
seemed legit, unless it was a zombie/clone thread
-David
DBarrier
Post by DBarrier »
Not sure what happened but I can't see the opening paragraph or photos on the thread anymore. Is it just me?
DBarrier
Post by DBarrier »
Well, looks like my paragraph and pictures magically disappeared. Cool.
Well that was weird
Spydergirl88
Squawk
Post by Squawk »
jpm2 wrote:
Fri Aug 09, 2019 12:45 pm
Seems like i missed something on the pictures...
What happened to OP?
DBarrier
Post by DBarrier »
Not sure why my replies aren't going through. I'll try to get to the bottom of it.
OP, I can see your pictures and posts again
Spydergirl88
Enactive
Post by Enactive »
My guess on the 'delayed posts'- there was a new post moderation issue for a newly registered member?
DBarrier
Post by DBarrier »
Enactive wrote:
Mon Aug 12, 2019 7:31 am
Makes sense. At least whatever it was seems to be fixed.
ABX2011
Post by ABX2011 »
That lockup is normal. That's how liner/frame locks are supposed to engage. Otherwise there's lock rock.
DBarrier
Post by DBarrier »
ABX2011 wrote:
Mon Aug 12, 2019 9:53 am
I can see that for sure. Was just questioning it, as my Spyderco Chubby and Sage 2 both lockup with full contact on the blade tang.
