Page 12 of 13
Re: Cru-wear Delica
Posted: Wed Aug 07, 2019 10:10 am
by Sharp Guy
FK wrote: ↑Wed Aug 07, 2019 9:38 am
How do we find how many remaining in stock at dealers ?
Add one to your cart and go to the check out screen. From there you can add a larger amount and update the cart. If they don't have enough to fill the order you'll get a message that says how many they have.
Re: Cru-wear Delica
Posted: Wed Aug 07, 2019 10:13 am
by Sharp Guy
I have my CruDelica in my pocket again today. I have several Delicas including some really nice ones. I think this one might become my favorite daily driver.
Re: Cru-wear Delica
Posted: Wed Aug 07, 2019 11:34 am
by Holland
Got one! Thanks for posting the links!
Re: Cru-wear Delica
Posted: Wed Aug 07, 2019 12:40 pm
by racerx454
15 left as of now at BHQ. I believe they are the last dealer for these, so get them while the getting's good!
Re: Cru-wear Delica
Posted: Wed Aug 07, 2019 12:51 pm
by steelcity16
racerx454 wrote: ↑Wed Aug 07, 2019 12:40 pm
I believe the 15 is just the max of what they show in stock and let you order. It has been sitting at 15 for hours. Based on the limited number that the other dealers had, and knowing that BHQ usually buys the most exclusives, I would suspect they had a decent chunk of these. I'd guess they bought half of the run. 300 out of 600. Just guessing at all of these numbers, but I don't think 15 is the real number in their current inventory. If you want one I would still grab one now and not take the chance because even if they have 200 left, they will be gone soon enough.
Re: Cru-wear Delica
Posted: Wed Aug 07, 2019 12:53 pm
by SC_PATRIOT
Yup not sure on their numbers either. I got one and called back to get another. Should show 3 left approx. Get em boys!
Re: Cru-wear Delica
Posted: Wed Aug 07, 2019 3:22 pm
by eddiebob
I got an order in for two from BladeHQ around 4PM CST. Went back to look at it 15 minutes later and it was sold out. Got my fingers crossed at this point.
Re: Cru-wear Delica
Posted: Wed Aug 07, 2019 3:58 pm
by Doeswhateveraspidercan
I just got my buddy to buy one at Blade H.Q. Roughly 5 PM Eastern time.
Re: Cru-wear Delica
Posted: Thu Aug 08, 2019 1:17 pm
by awa54
looks like I missed this one after all... the USPS lost track of mine after it was sent out for delivery and they look to have all sold through
Re: Cru-wear Delica
Posted: Thu Aug 08, 2019 2:02 pm
by JonLeBlanc
awa54 wrote: ↑Thu Aug 08, 2019 1:17 pm
Mmmm... Hearing this sort of thing makes my blood pressure spike. I have to deliberately set aside the thought of all the times carriers (esp. UPS and USPS) have failed for me. The biggest issue I have with it is that they just don't seem to care when a mistake happens. Things go wrong, sure, and I can accept that, but the response is blasé blasé. I'm sorry about your Delica man
Re: Cru-wear Delica
Posted: Fri Aug 09, 2019 6:30 am
by awa54
JonLeBlanc wrote: ↑Thu Aug 08, 2019 2:02 pm
Fortunately my local P.O. isn't like that, after a call to the Postmaster I feel confident that if it's at the sorting center it will be found and delivered and I know our carrier well enough to be certain that there's no foul play in delivery. On top of that KnivesPlus has told me that they'll make good on delivering me a CruWear Delica if it doesn't arrive eventually, which is above and beyond my normal customer service expectations these days!
Re: Cru-wear Delica
Posted: Fri Aug 09, 2019 3:06 pm
by JonLeBlanc
awa54 wrote: ↑Fri Aug 09, 2019 6:30 am
Well that's good
Re: Cru-wear Delica
Posted: Thu Aug 22, 2019 12:11 pm
by awa54
All's well that ends well, and my replacement CruLica arrived safe and sound!
Thanks again Knives Plus!
The only problem is that now I have to swap my Flytanium CF scales off the VG-10 damascus blade and on to the CruWear Delica... I suppose I'll survive the exertion
Re: Cru-wear Delica
Posted: Wed Sep 11, 2019 6:42 pm
Two night ago I screwed up, went to cut some plastic vegetation they put in aquariums with my Cruwear Delica.
Went to slice through it and the blade skipped it was late and I thought hmm tough plastic so choking up on the knife bore down and really dug in.
Aww crap!!! Hidden metal wire, looked at the blade and yep sure enough plastic deformation without chipping. I thought way to go dummy!
Tried evening it out on a brown Spyderco bench stone and realized this is a slow boat to China.
Broke out the Wicked Edge pro3 decided well now is a great time to profile this exactly with a digital angle cube.
Started with 600 grit diamond paddles and worked the grit procession to .5 Microns. Blade is now a true 15 degrees per side and wow does it slice!
Love how little time it takes to make Cruwear hair popping and tree topping sharp. Repair and reprofile a cinch! Fantastic steel in a fantastic design!
Re: Cru-wear Delica
Posted: Wed Sep 11, 2019 8:47 pm
by NWPilgrim
awa54 wrote: ↑Thu Aug 22, 2019 12:11 pm
That is amazing customer service from Knives Plus! Making good on a limited run knife the USPS lost. Impressive personal attitude.
Re: Cru-wear Delica
Posted: Wed Sep 11, 2019 9:47 pm
by JuPaul
Excellent! And thanks for sharing - always good to know who has great customer service. Good on Knives Plus!
Re: Cru-wear Delica
Posted: Mon Sep 30, 2019 9:16 pm
by Capt'n Boatsalot
I noticed that my Cruwear Delica is developing a patina quite a bit faster than any of my Golden Cruwear models are. Under basically the same conditions and care. I wonder if the heat treat protocol is is slightly different between Seki and Golden? Anyone else notice this?
Re: Cru-wear Delica
Posted: Mon Sep 30, 2019 9:34 pm
by JuPaul
Interesting. Neither my Cruwear Manix or my Cruwear delica have developed much of a patina, but I do keep a very light coat of mineral oil on them usually. As an aside...nice collection!
Re: Cru-wear Delica
Posted: Mon Sep 30, 2019 9:42 pm
by TkoK83Spy
Very surprising...though I do like that blue hue yours has developed.
Re: Cru-wear Delica
Posted: Mon Sep 30, 2019 9:43 pm
by tjsblade
Capt'n Boatsalot wrote: ↑Mon Sep 30, 2019 9:16 pm
Nice collection. Question: what did you do to create that finish on the pocket clips on the pm2 and para 3
