Page 9 of 13
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 12:41 pm
by Wartstein
FullFlatMind wrote: ↑Fri Aug 02, 2019 12:33 pm
Wartstein wrote: ↑Fri Aug 02, 2019 12:13 pm
FullFlatMind wrote: ↑Fri Aug 02, 2019 11:30 am
Maybe this has been mentioned already but the specs show a blade thickness of 2mm. Is that correct? The regular Delica is 2.5mm. If so, this thing will be slicey like a Chap but with Cruwear.
:eek: Not interested in this knife till right now, but if 2mm stock is true, I suddenly would be...
Right? GP, DLT, and Knives Plus all list the thickness as 0.098" or 2mm.
Man!! As said, I personally don't need Cruwear, but I'd love a 2mm Delica (and generally more 2mm blades that is).
So I am intersted in the STOCK, not the steel...
Honestly I'd take a 2mm VG10 Delica over a 2.5mm Cruwear Delica any day of the week. Even if the former would be MORE expensive...
Maybe somebody can confirm (or not) the 2mm blade when he or she receives the knife... ?!
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 12:43 pm
by PStone
The hap40 and vtoku versions have been ground thinner at .098 (2mm)as well.
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 12:48 pm
by Wartstein
DirtMcGirt wrote: ↑Fri Aug 02, 2019 12:43 pm
Are you sure? (I mean by that: Have you just read that or measured for yourself)?
I don't have a HAP40 Delica, but a HAP 40 Endura and Stretch, at least the Endura LOOKS a bit thinner than the 3mm VG10 version... but I never actually measured their stock...
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 12:50 pm
by steelcity16
Out of stock at DLT now. That was fast. I guess that just shows how much more known/trusted DLT is vs KnivesPlus. Still 15 in stock at KnivesPlus. Get 'em while you can.
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 12:52 pm
by Wartstein
Just checked: 0,098 converts to 2.5 anyway, NOT to 2.00...
Re: Cru-wear Delica
by DLTJordan
I took a measurement on one and it came out to 2.4mm thickness at spine on top of the hole. I have updated our spec sheet to reflect this. Looks like the initial 2mm spec was a conversion error.
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 12:58 pm
by Sharp Guy
Wartstein wrote: ↑Fri Aug 02, 2019 12:52 pm
As far as I remember, I never noticed any major difference in blade stock thickness on the HAP40 & V-Toku Delicas compared to other versions. I usually check these things. So maybe I just missed it or I'm not remembering correctly. Could certainly be either :)
I'll try to remember to check when I get home later
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 1:02 pm
by Wartstein
Sharp Guy wrote: ↑Fri Aug 02, 2019 12:58 pm
Thanks much! But I am pretty sure already that we have here just a conversion mistake from inches to mm, not a real life difference in thickness...
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 1:04 pm
by FullFlatMind
Duh! I should just done the math. Thanks for the correction.
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 1:30 pm
by Wright.88
Except 0.098" is 2.489 mm. And the regular Delica is listed at 0.093". I would be very excited if it was 2mm bit I am assuming it's going to be very close to 2.5mm.
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 1:37 pm
by ihped1
Already shipped from DLT. Didn't see the free handkerchief, but called in to add on an item and got it.
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 1:55 pm
by steelcity16
Went from 15 in stock to 37 at KnivesPlus? So they go more in, or cancelled orders of more than 1, or maybe had some declined cards or something? Weird.
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 2:30 pm
by PStone
I just measured both stnicks and vtoku. Both came out the same, .096, 2.44mm.
I just remember it being said that the Hap40 was ground thinner. I stand corrected.
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 3:19 pm
by FK
The blade proper is ground thinner, the stock material is the same.
Regards,
FK
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 3:34 pm
by Wartstein
DirtMcGirt wrote: ↑Fri Aug 02, 2019 2:30 pm
Thanx, appreciate you took the time!! :)
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 3:52 pm
by kwselke
Does CruWear bring anything to the Delica that the ZDP-189 version doesn't? It looks to me that CruWear is more rust prone and probably not as wear resistant as ZDP. This exclusive is cheaper than the stock ZDP model and it is tempting, but I have eight Delicas and my ZDP version was long ago paid for.
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 3:56 pm
by cycleguy
I got home from work mid afternoon and found my notice from DLT ... it said - extremely limited quantities limit of 1. Came here next and read that they were sold out. Just checked for myself and found the same.
CG
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 4:01 pm
by Wartstein
kwselke wrote: ↑Fri Aug 02, 2019 3:52 pm
You could ask that (and it has been asked in this thread already) even more so concerning the HAP 40 version...
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 4:13 pm
by awa54
Knives Plus still had some this morning... mine already shipped!
Re: Cru-wear Delica
Posted: Fri Aug 02, 2019 4:31 pm
by bearfacedkiller
Cruwear should be more durable and it should sharpen up a little better. If your ZDP has been durable enough, stainless enough and you like the way it sharpens then Cruwear may not offer you anything.
ZDP is great but Cruwear is a more balanced steel.
