The PERFECT Double Bladed Folder?
Postby JD Spydo » Mon Jul 15, 2019 11:22 am
As many of you know I'm a really big fan of the C-44 Dyad model ( the big one). Oh yeah I also like the C-39 Dyad Jr. models too. For all of you newbies and people not aware the Dyad models were Spyderco's double bladed folders with one full PE blade and one full SE blade in the same folder. To have one really nice plain edge blade along with one full length Spyderedge blade is like a dream come true for me in a lot of ways and it makes a great folder for fishing, hunting and other outdoor activities.
Now what I am hoping will happen in the not so distant future would be for Spyderco to make a new, improved version of the C-44 Dyad. There have been some minor complaints as to how the first C-44 Dyad was designed so what would you all change if you could? Personally I would like to see any new Dyad design have a lanyard attachment. Because that is a folder that I like to take fishing with me and losing one overboard would put me in a bad state of depression for sure.
So what improvements or changes would you guys implement for a new Dyad model>> or what do you want Spyderco to focus on to make the Dyad better? Now this is for a double-bladed folder with one full PE and one full SE blade in the same folder. I would also like to see it to where the pocket clip could be attached on both sides. So what all changes would you all like to see if Sal were to revamp the C-44 Dyad model?
p_atrick
Re: The PERFECT Double Bladed Folder?
Postby p_atrick » Mon Jul 15, 2019 11:29 am
Benchmade has a model called the 365 Outlast. This is a two-bladed knife with a seat belt cutter. One blade is a drop point in S30V, while the other has a blunted tip for prying, a serrated edge, and is made of 3V. I'm not saying that Spyderco should copy this, but I do find it interesting that Benchmade went with two very different blades (steel, shape, and most likely heat treat). The greater the differentiation between the two blades, the more useful, I think, the knife would be.
JacksonKnives
Location: Formerly Alberta, now Orange County, California
Postby JacksonKnives » Mon Jul 15, 2019 11:50 am
How about a PE Dragonfly and an SE Cricket "glued together"? Linerlock would be my pick over a lockback, but both can work well on a Double-end design.
jdw
Postby jdw » Mon Jul 15, 2019 12:26 pm
I wouldn't make it at all honestly. IMO, JD it is one of the worst Spydies that I have ever owned. I had a full size version that felt like carrying a rock and fit about halfway into your pocket.
--Wovoka
bearfacedkiller
Postby bearfacedkiller » Mon Jul 15, 2019 12:51 pm
Ergonomics and clip position.
1) Make the serrated blade a two handed opener and bury it in the handle so the second hump isn’t an ergonomic nightmare.
2) Move the clip up closer to the end of the knife. I am not a fan of deep carry but that high ridin’ Clip position on the Dyad is a no go.
3) Maybe replace the serrated blade with a small saw.
Postby Doc Dan » Mon Jul 15, 2019 1:14 pm
I had suggested this knife as inspiration earlier. So I am in agreement with you that this would make a good design for them to draw from. This would fix a lot of the ergonomic problems but Spyderco double bladed knives typically have.
(Roy Rogers)
Postby Doc Dan » Mon Jul 15, 2019 1:15 pm
I would not mind seeing something like the dragonfly FRN with an extra blade. The light weight would definitely be compelling.
(Roy Rogers)
SF Native
Postby SF Native » Mon Jul 15, 2019 2:11 pm
Wondering is a double blade could be made similar to the Tusk. Frame lock for one blade and ball lock for the other. I would want it stretched out a little and recess the blades more for comfort. Maybe possible, maybe not.
PStone
Postby PStone » Mon Jul 15, 2019 7:30 pm
I have often imagined a scaled up version (3+inch blades)of the small stainless clipitool with a serrated secondary blade. Only with g10 or frn instead of stainless handles. I think the design is amazing for ergos and would scale up very nicely. Probably even to 4+ inch blades. Here is a picture I took from the SFO website:
The secondary blade is tucked away nicely with the main deployed. And when the main blade is closed, its spydie-hump also acts as a nice choil for aid in draw cuts with the serrated blade. Just an amazing design overall.
“In the book of life, the answers aren’t in the back.”
-Charlie Brown
Donut
Postby Donut » Mon Jul 15, 2019 7:45 pm
I was thinking about making a dyad with a frame lock, but no matter what if you put the lock on the outside, I think the lock would be wrong handed. Probably why the locking swiss army knives have the lock pushing towards the center.
Wouldn't the compression lock (or integral compression lock) work with this? Compression locks push towards the side you are opening with.
Maybe a hybrid of the Para 3 and the Cliptool like McGirt says with a concave spine on the SE blade to help Ergos. Do we need a lock on the SE blade?
-Brian
A distinguished lurker.
Waiting on a Squeak, Pingo, and Cliptools with a Split Spring!
Postby Evil D » Mon Jul 15, 2019 8:18 pm
It needs to either feel the same ergonomically when gripped at either end, or the second blade needs to have no thumb ramp at all so it folds into the handle completely flush do it doesn't interrupt the ergonomics. Or, both blades need to fold completely into the handle with no thumb ramps.
If you took a very basic shape like the Nilakka, where there aren't any finger grooves that would feel awkward when gripped in the opposite end, and where the blade folds completely into the handle, you could give it a second blade and it would feel the same at either end.
Postby JD Spydo » Mon Jul 15, 2019 8:31 pm
It's been so long that I"m embarrassed to say that I just don't remember the name of the model>> but Benchmade had another double bladed knife back around 2008-2009 I think it was. It had one full sized blade and then a smaller blade that folded out from the opposite side. And I believe it was one of their first S30V knives if I remember correctly. I'll have to take a look at this newer double bladed model they have. I doubt I would break my allegiance to Spyderco but it does have my interest just to look it over if nothing else.
I wish I could remember that one double-bladed model they had about a decade ago>> It was on their main line up when the RUKUS model was really popular.
Postby JD Spydo » Mon Jul 15, 2019 8:37 pm
That's a really interesting idea>> because for all intent and purposes the TUSK model really comes close to fitting the definition of a double-bladed folder. I actually wish they could make the TUSK with two knife blades and still keep the MarlinSpike.
They need to either make the TUSK a two bladed model or if nothing else at least starting offering it in Spyderedge. Just about any Mariner, Fisherman or longshoreman would prefer a serrated edge I'm sure of it. And why they wouldn't offer a Marine type folder in SE still has me shaking my head.
SF Native
Postby SF Native » Mon Jul 15, 2019 11:38 pm
Oh that would be cool. Especially if that serrated blade was a hawkbill. Don’t know how you would fit all that in there, but it would be cool if you could.
spyderwolf
Postby spyderwolf » Tue Jul 16, 2019 3:12 am
For me a double bladed folder is like a car with manual and automatic gearbox.Eiher will work by itself,but put together they will ruin the car.
Whenever there is any doubt, there is no doubt.
Sumdumguy
Postby Sumdumguy » Tue Jul 16, 2019 4:09 am
The perfect double bladed knife would be a C44 with compression locks.
As far as BMs, keep them in the toilet and off of these forums ;)
jdw
Postby jdw » Tue Jul 16, 2019 7:40 am
Really the perfect double bladed folder to me is some Old Timer, Case, Uncle Henry, Camillus, etc. with carbon blades and has been around a few decades. It's hard to reinvent the wheel.
--Wovoka
Postby PeaceInOurTime » Tue Jul 16, 2019 10:32 pm
I've not owned any of the Dyads, but I'm very interested in the idea of double bladed knives. It's already been said, ergonomics are important. The past Dyads have not appeared at all comfortable in hand (one of a few reasons why I haven't purchased one of the new clipitools). I hope Spyderco can find a way to make it work well.
In the past, I've had the idea of a larger knife with a smaller (ladybug size?) blade that folds out from the back of the handle. Different shapes, steels, edges? I'm sure that has been brought up here before. I love all the different ideas presented so far.
+ Wanna see knives in use? Visit my YouTube channel: https://www.youtube.com/channel/UC3z6R5 ... hrIn41j14A
+ I'm currently participating in a serrated edge only challenge for 2020: viewtopic.php?f=2&t=85560
+ "Wouldn't it be tight if everyone was chill to each other?" -Gryzzl (Parks and Recreation)
+ "Don't ever, for any reason, do anything, to anyone, for any reason, ever, no matter what, no matter where, or who, or who you are with, or where you are going, or where you've been, ever, for any reason whatsoever." -Michael Scott (The Office US)
Pelagic
Postby Pelagic » Wed Jul 17, 2019 5:02 am
My perfect double bladed folder would be one with a Military blade, a sheepsfoot SE blade (byrd rescue 2), and a 4 inch marlin spike on the other side, all 3 backlocks, all LC200N (including liners).
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
Postby JD Spydo » Wed Jul 17, 2019 7:27 am
Oh yeah that would make perfect sense. That would be an ultimate "Mariner's Knife" and I bet Spyderco would sell a ton of those at specialty stores for sailboat enthusiasts as well as guys in the fishing industry. And keep the MarlinSpike>> because the MarlinSpike is a really handy tool for a lot of everyday chores as well as being handy for sailors and mariners.
Users browsing this forum: Albatross, Buddafucco, Doeswhateveraspidercan, jdw, Majestic-12 [Bot], MSN [Bot], TkoK83Spy and 25 guests
