Ouroboros G10 polished and contoured
Postby Evil D » Sat Jun 22, 2019 6:00 pm
I have had this planned since I first saw this knife (in truth, I wanna do the same thing to a Sliverax but since it's laminated CF/G10 I have to get custom scales first). I know I preach a lot about the whole polished and contoured thing, but a knife like this that has strong enough ergonomics to lock your hand into place really doesn't benefit from grippy G10, and it fits in better as a gent's knife than a tactical EDC anyway so it just makes sense. I will admit though, it's far easier to unlock the grippy G10, as this thing is slick. I use the clip as a leverage point to keep the knife from slipping out of my hand.
Aaaanyway ya'll probably didn't even read that and are looking at pics anyway so here ya go.
Nate
Re: Ouroboros G10 polished and contoured
Postby Nate » Sat Jun 22, 2019 7:03 pm
That looks excellent D, thanks for the pics.
What kind of grit progression did you use? Looks like a finish similar to your Kiwi 4 iirc.
:spyder:
Enactive
Postby Enactive » Sat Jun 22, 2019 7:08 pm
Was thinking the same RE: Kiwi. Also curious about the grit progression. Nice work, D.
Postby Evil D » Sat Jun 22, 2019 7:18 pm
I roughed out the basic shape with a Dremel and a 120 grit sanding barrel. After that it was sandpaper in 220/320/400/600/800/1000/1500/2000/3000 and then red rouge on a bench grinder/buffing wheel and then Flitz on a rag.
I may go back and do a bit more heavy sanding. What bothers me about this is the layers of G10, there are those dull layers that aren't glossy, and the very top layer (which happens to be the largest) is right in that dull layer. I think if I sand the very top/center down a bit more it'll eventually get into the shiny resin layer.
zhyla
Postby zhyla » Sat Jun 22, 2019 7:45 pm
That turned out really cool. Is the Sliverax nested? If not it would be simple to make you’re own scales just by tracing it.
Postby Evil D » Sat Jun 22, 2019 7:48 pm
Unfortunately yeah. I haven't even looked into it yet but I'm sure someone is making scales for them. I've got another Sliverax mod in the works coming first though if I can get around to it.
Nate
Postby Nate » Sat Jun 22, 2019 7:58 pm
Thanks for the info. I've done a fair amount of hand-sanding on various handles, but nothing quite that dramatic.
I'd guess the trick is to to go slow, but how is the Dremel work with the sanding barrel? Is is fairly forgiving to use?
:spyder:
Postby Evil D » Sat Jun 22, 2019 8:15 pm
It kinda depends on you. I do a lot of artsy fartsy stuff so carving and such sort of relates to that. I just go really slow and gently and watch the grain. As you sand you'll start seeing the grain come out and if you go too deep or not deep enough you'll see it in how the grain starts to curve. The more I do it the more I appreciate some of the fixed blade handles I've seen, there really is an art to getting the shape right and symmetrical. You could do it all by hand with just sandpaper but I just about wore off my thumb print today so the Dremel really makes it easier and faster. If you wanna try it you might wanna get a blank slab if G10 to practice on first.
Freediver
Postby Freediver » Sat Jun 22, 2019 8:22 pm
Wow looks great. Good job.
Liquid Cobra
Postby Liquid Cobra » Sat Jun 22, 2019 8:28 pm
Looks fantastic. Impressive that you didn’t end up with screws sticking out due to the curves. I need to learn how to do that.
I made some custom scales for my ouroboros but the handles couldn’t be more different from yours. Blocky and pointy and orange. Maybe next time I’ll try contouring and polishing like you did.
Most recently acquired: Native Chief, Shaman S90V, Para 3 LW, Ikuchi, UKPK, Smock, SUBVERT, Amalgam, Para 3 CTS-XHP, Kapara, Paramilitary 2 M390
@liquid_cobra
Postby Evil D » Sat Jun 22, 2019 8:34 pm
Saw those on IG. If you can make your own scales, I would start with making them extra thick and then you could really round them off and get a lot of grain showing. On the factory scales you can only go so far before you either grind through to a liner or to the pins that seat into the inside of the scales. I did get into the screw holes a bit, if you look at the back screw on the front side I even sanded the head of the screw down a little because I didn't fully tape apart the handle to do it and I left those two screws in. This was the major risk in doing the Kiwi 4, if you go too far and sand down the scale pins too car they'll pop apart and your knife is ruined unless you have the tools to repin it.
curlyhairedboy
Postby curlyhairedboy » Sat Jun 22, 2019 11:01 pm
This looks very nice!
EDC Rotation: PITS, Shaman, CF S90v Shaman, Ikuchi, Amalgam, CruCarta Shaman, Lil Native, Sage 5 LW
Always in Pocket: Hawkbill Dragonfly 2 H1
Special and Sentimental: Southard, Smallfly G10, Squarehead LW, Calendar Para 3 LW, 40th Anniversary Native
Would like to own again: Sheepsfoot Caribbean
Wishlist: CQI Kapara, Watu, Tanto PM2, Shaman Sprints!
ZrowsN1s
Postby ZrowsN1s » Sat Jun 22, 2019 11:17 pm
That looks good. 👍
Carrying 3 knives is perfectly normal :D
-Matt
Cambertree
Postby Cambertree » Sun Jun 23, 2019 12:32 am
That looks outstanding D. Very fine work, and perfectly suited to the graceful design curves of the Ouroboros too.
If the original version had been contoured like that, it probably would have tipped the scales for me to get one.
Igi964
Postby Igi964 » Sun Jun 23, 2019 2:25 am
Very nice. Native Chief would be great with contoured G10.
Tims
Postby Tims » Sun Jun 23, 2019 4:45 am
I couldn’t agree more about the polished and contoured g10. It would add a whole new level of class and comfort.
Regarding the Ouroboros and ergos. How does she feel in a pinch grip? Do you find yourself pinching the forward part of the scale or the blade on or in front of the spyder hole?
bearfacedkiller
Postby bearfacedkiller » Sun Jun 23, 2019 5:04 am
Very nice!
Postby Evil D » Sun Jun 23, 2019 5:47 am
I haven't used it a lot yet but I like it in saber grip and Filipino.
Postby Doc Dan » Sun Jun 23, 2019 6:08 am
David, that knife looks great, now. How long did it take to do? G10 can be worrisome because of the dust. How did you keep from breathing it in?
(Roy Rogers)
Postby Evil D » Sun Jun 23, 2019 6:47 am
Took about 5 hours total. I wear a dust mask but I was thinking I should probably invest in a better one if I'm going to do this more often. Most of the sanding was done wet but the initial shaping with the Dremel does make a lot of dust.
Users browsing this forum: Bing [Bot], FullScaler, MSN [Bot], tyd450 and 23 guests
