Why don't we see more clips like this?
It's a low ride clip and it's got countersunk screws that don't snag when you pocket it. This has been my issue with a lot of low ride clips. They use a rounded screw head that snags the seam of the pocket and makes it harder to draw the knife. I think this clip should be offered on more models.
Janisong clip and why we need more like it.
- youmakemehole
Re: Janisong clip and why we need more like it.
Like all things that are nicer they also cost more to produce all else held equal. Otherwise you are looking at a weaker design if you want it to cost the same, not to mention it presents more of a challenge to find a design that works with every knife. Just look at how wide the space is between the mounting holes! That clip will only work on the Janisong
"Sometimes I think that we're all little kids trying to act like grown ups, in our parents clothes. "
-sal
-sal
- curlyhairedboy
I've heard that the janisong clip only fully slips into deep carry on very slender material; perhaps an iteration would increase the radius of the bend?
Clearly you have never tried to put the Janisong clip on a pair of jeans. It sucks! The clip bend is not wide enough to accommodate jeans. If they fixed it, I agree it would be a fine quality deep carry clip.
Make time for the important things in life, and learn to enjoy the little things more.
I don't think the cost difference would be huge. I haven't been able to handle a janisong since I live in the USA and they weren't brought here by spyderco. I just think these changes should be applied to more models. I think it would be an easy conversion for most models to do something similar. It's not a milled ti clip or anything fancy. Just has the right touches for deep carry. I also think they could make the clip thinner to adapt it to other models. Just a thought.
- Larry_Mott
It's possible, but unnecessarily tight fit between clip and scale.
