Why put liners in the Delica?
tangent
Post by tangent »
This is a serious question...and I know we all have our preferences. I admit that I am biased because I prefer the linerless Salt 2 scales over the lined Delica 4 scales. But my preference isn't based on feel alone. The linerless handles are very slightly thicker for added rigidity and therefore fill my hand just a little better. But other than that, it just seems that the linerless design is simpler and more rust resistant...plus, they must be slightly cheaper to make.
So, other than the additional heft that you feel with the weight of the liners, what's the purpose? I imagine that it adds strength, but the amount of strength added doesn't seem to be a huge selling point in a folding pocket knife. But the weight reduction, simplicity and increase in corrosion resistance are all pluses in my book.
What do you all say?
Re: Why have liners in the Delica?
I think in the Pakkawood model, they add a classy touch that goes well with the full length backspacer.
tangent
Post by tangent »
I should clarify that I am only talking about the FRN models. No argument against the steel liners in wood scales.
ugaarguy
Re: Why put liners in the Delica?
Post by ugaarguy »
The Native LW and G10 S30V both went liner-less. I agree with switching the FRN Delica and Endura to liner-less. I've never had good results with getting clips tight on Spydies where the clip screws mount into the thin metal liners. I love molded in thread inserts on anything that doesn't have a metal scale or thick metal liner.
Bill1170
Post by Bill1170 »
The liners were added in the Delica 4 revision to facilitate four-way clip mounting. The Delica 3 barrel bolt setup only permitted tip-up clip mounting. My guess is that there was wide sentiment for four-way clips before they were available on the Delica/Endura.
I have nothing against going linerless, even would prefer it in many knives.
But not so in the Delica/Endura/(Endela)-family.
First these are such iconic models and changes should be just very subtle imho, for mainly "historic and traditional" reasons. (EDIT:Learned just right now (thanks, Bill) that the liners are not a "traditional" feature, but D3 had NO liners. So I was wrong on that).
Then the Delica feels just perfectly balanced and very sturdy as it is.
And while for example the linerless, delicashaped Salt 2 is 15% lighter than the SABREGRIND Delica (since the Salt is slso sg, that's a better comparison than to the ffg Delica), I am not sure if this is really that much noticeable
in reality (btw., the linerless Native lw (sure a different knife with thicker bladestock) is almost 20% HEAVIER than the linered ffg Delica).
If at all or how much more flex there would be in a linerless Delica I can't tell. Never had a salt 2, just Native 5 lw and Manix 2 lw. THESE two felt very solid though, but are different knives and FRCP, not FRN...
Bill1170 wrote:
Mon May 20, 2019 12:03 am
So Delica 3 was linerless?? Did not know that!!
Bill1170
Post by Bill1170 »
Mon May 20, 2019 12:07 am
Yes it was. The handle molds for the D3 and E3 were re-used in the Salt line.
Bill1170 wrote:
Mon May 20, 2019 12:14 am
Thanks!! I was aware of that the Salt handles are shaped after D3 and E3, but thought the latter HAD liners while the Salt models do not.
Bill1170
Post by Bill1170 »
In many ways the barrel bolt clip fastening method is (my opinion) more elegant than three screws and 12 tapped holes. However, the tip-down carry proponents are surely appreciative of being accommodated.
spyderwolf
Post by spyderwolf »
The rigidity added by the liners is just as ''important'' as the weight spared by taking them off.To each it's own,but i don't understand this anti-liner movement.Maybe it's a wish to relive times gone by,when we where young,and linerless?
Whenever there is any doubt, there is no doubt.
Jazz
Post by Jazz »
It used to bug me that they threw liners in there, but I think it gives them the perfect amount of heft, not too heavy or light. Less chance of stripping the D holes out when fiddling around on them also. I do like the Salt knives' feather weight, though. I'm not a fan of all the ribbing inside the Salts and Natives, however. I wish they were solid FRN.
- best wishes, Jazz.
cycleguy
Post by cycleguy »
Guess I like that it is available both ways. Should make those that prefer them and those that don't prefer them content. A better approach than all linerless may be keeping things as they are and adding a LC200N Salt 2 version.
CG
tangent
Post by tangent »
cycleguy wrote:
Mon May 20, 2019 7:31 am
CG
Yes except that we can’t get FFG in the Salt 2 scales.
cycleguy
Post by cycleguy »
tangent wrote:
Mon May 20, 2019 7:34 am
CG
I see. Can Delica 4 blades be swapped with Salt 2 blades if someone was interested?
CG
tangent
Post by tangent »
cycleguy wrote:
Mon May 20, 2019 7:46 am
CG
CG
Yes. In fact, this is what I have done. It would be nice to not have to buy two knives for every one I’d like to use.
cycleguy
Post by cycleguy »
tangent wrote:
Mon May 20, 2019 8:26 am
CG
CG
I completely understand; a ffg Salt 2 offering along with the other two offerings does seem to have its place. Maybe someday!
CG
tangent
Post by tangent »
cycleguy wrote:
Mon May 20, 2019 8:59 am
CG
CG
Yep. I’m hoping for a Salt 2 Wharnie in LC200N with black scales. Too specific? :)
cycleguy
Post by cycleguy »
tangent wrote:
Tue May 21, 2019 12:29 am
CG
CG
Not at all. We all have our things that we like... just hope Spyderco keeps pumping out the choices vs whittling back!
CG
ferider
Post by ferider »
spyderwolf wrote:
Mon May 20, 2019 6:08 am
I'm with you. Except for Salt models, I completely fail to understand why the little additional weight matters for practical carry, while liners sure give more overall toughness (and add material value, too). For example, for liner-less Native 5 vs liner'ed Native 5, the liners just add 17g (e.g., C41GM45 comes in at 88g, while the C41GDBL5 is 105g). Anything less than 110g total, I can't feel in my pocket anyways, and I can loose more than 17g just by skipping dinner once :) And then, people love clips on liner-less tiny knives, which add ~10g by themselves. Somebody explain me this.
In fact this trend of going liner-less for most new releases pushes me away from Spyderco. In my example above, a fully liner'ed M4 Native 5 would have been the bee's knees, but like that, oh well ....
