Best way of restoring dyed FRCP scales
npad69
Postby npad69 » Wed May 08, 2019 2:04 am
Hello guys, I just recently won an unused albeit 'personalized' native5-salt from a raffle. I have no issues so far about it except I wanted the stock hi-viz yellow scales back instead of the indigo coating. Is there a safe way of removing this dye/paint? tia
Re: Best way of restoring dyed FRCP scales
Postby The Deacon » Wed May 08, 2019 3:53 am
If it's dyed with RIT dye, they make a "color remover" that might work. If it's paint, brake fluid might work, or you might have to sandblast it off.
Postby Evil D » Wed May 08, 2019 5:42 am
Apparently the dye remover is pretty effective, there was just a post here a while ago showing pics. This is one reason I haven't dyed my Caribbean, but if you go with black at least you can dye it back to black again and not worry about changing the shade.
npad69
Postby npad69 » Wed May 08, 2019 8:03 am
Thank you Paul and David for the suggestions.
Does it mean if I strip it off using the dye remover from RIT will it restore it to the original scale color?
What if I dye it again to yellow without removing the existing coat?
Mm1313
Postby Mm1313 » Wed May 08, 2019 8:12 am
Try the dye remover, should take off the rit dye and not the stock color. At worst it may lighten the stock yellow it a bit. I've used the color remover before and it works fantastic, but make sure u have some very good ventilation because it stinks to high hell.
lowcountry
Postby lowcountry » Wed May 08, 2019 9:28 am
Going from purple to yellow probably won’t work. Try the rot remover. You do it the same way you would for dying a knife. Just soak it until it goes back to yellow.
Postby Evil D » Wed May 08, 2019 10:01 am
From what I've seen it should get very close, maybe not quite as vibrant as it is when new but mostly. I'd like to see when you're done actually.
PStone
Postby PStone » Wed May 08, 2019 10:14 am
Forum member attila posted his process not too long ago. He started with acetone, and that got most of it. Then moved on to the dye remover. I think it turned out very, very nice.
http://forum.spyderco.com/viewtopic.php ... t#p1312846
“In the book of life, the answers aren’t in the back.”
-Charlie Brown
npad69
Postby npad69 » Thu May 09, 2019 12:24 am
Thank you for pointing me out to attila's thread. Btw, does it mean I have to disassemble my knife just to dye the scales? What if I just dye without disassembling?
lowcountry
Postby lowcountry » Thu May 09, 2019 5:08 am
Since yours is a Salt, no need to disassemble.
Users browsing this forum: Ankerson, Cscottsss, JuPaul, Larrin, mattman, MSN [Bot], PeaceInOurTime, The Meat man and 28 guests
