Sharpmaker Rods
FLHTK
Sharpmaker Rods
Post by FLHTK »
Can anyone tell me what the micron equivalent is for the triangular rods i.e., CBN, Medium, Fine, Ultra Fine.
Re: Sharpmaker Rods
Hi FLHTK,
Welcome to our forum
Your request is a bit more complicated than it might seem. The Alumina particles, as I understand, used on the rods are generally 15 -20 microns. The different grits for fine and medium are attained by firing processes, not micron size. The CBN and diamonds used are 400 mesh. The ultra fines are made by tumbling the fine grits.
FLHTK
Re: Sharpmaker Rods
Post by FLHTK »
Thanks Sal. Just wondering as compared to my water stones.
Ric
Re: Sharpmaker Rods
Post by Ric »
Hi.
You can use these as a rough reference.
There are also many other threads about that topic. (Search for Micron)
diamond= 68 micron, 400 grit, sandpaper 220
medium = 20 micron, 600 grit, sandpaper 800
fine= 6micron ,1200 grit,sandpaper 2000
ultrafine: 3 micron
mattman
Re: Sharpmaker Rods
Post by mattman »
Check out the "Grand Unified Grit Chart" over at blade forums. The supporting thread had a pretty in-depth discussion about where to place the ceramics, based on scratch-pattern comparisons.
