Spyderco Shaman - Front Flipper?
bagsnatcher
Postby bagsnatcher » Thu Mar 21, 2019 7:14 pm
@sal
By design, or sheer coincidence, it appears the Shaman is a legitimate front flipper.
This is a very good thing:
https://photos.app.goo.gl/JYE6ARyJVEqtbbGx5
Re: Spyderco Shaman - Front Flipper?
Postby TkoK83Spy » Thu Mar 21, 2019 7:20 pm
You could do the same thing with many models. It's kind of awkward though.
Currently have 20 :spyder: 's in 14 different steels.
bagsnatcher
Postby bagsnatcher » Thu Mar 21, 2019 7:25 pm
Not so sure about that.
Here it is against a legit front flipper:
https://photos.app.goo.gl/LZjDUBf8uQiFrCtx6
Postby TkoK83Spy » Thu Mar 21, 2019 7:32 pm
I dunno man, I honestly don't see much of a difference. The thumb hole with various ways to open it seems just fine. A "flipper" is better suited for a flipper tab. But whatever floats your boat. If that's how you want to open it, more power to ya. Just doesn't seem very practical.
bagsnatcher
Postby bagsnatcher » Thu Mar 21, 2019 7:35 pm
Totally not practical, with the hole there. A middle finger flick is way faster.
I'm just excited that it legitimately works as a front flipper too (if you're inclined to open it that way).
Liquid Cobra
Postby Liquid Cobra » Thu Mar 21, 2019 7:38 pm
It doesn’t work very well as a front flipper. Not saying it can’t be done but it’s painful and not reliable.
Most recently acquired: DLC Yojimbo 2, Native Chief, Shaman S90V, Para 3 LW, Ikuchi, UKPK, Smock, SUBVERT, Amalgam, Para 3 CTS-XHP, Kapara, Paramilitary 2 M390
@liquid_cobra
curlyhairedboy
Postby curlyhairedboy » Fri Mar 22, 2019 6:23 am
if the top thumb ramp was a little longer past the pivot it would work a little better, but it definitely does work.
EDC Rotation: PITS, Shaman, CF S90v Shaman, Ikuchi, Amalgam, CruCarta Shaman, Lil Native, Sage 5 LW, Ouroboros
Always in Pocket: Hawkbill Dragonfly 2 H1
Special and Sentimental: Southard, Smallfly G10, Squarehead LW, Calendar Para 3 LW, 40th Anniversary Native
Would like to own again: Sheepsfoot Caribbean
Wishlist: CQI Kapara, Watu, Tanto PM2, Shaman Sprints!
bearfacedkiller
Postby bearfacedkiller » Fri Mar 22, 2019 7:12 am
You can put your boot in the oven but that doesn't make it a biscuit.
Postby Evil D » Fri Mar 22, 2019 7:15 am
Really seems like a super unnatural motion vs the thumb hole.
I do wonder if the front lip of the choil could be made bigger into a flipper tab, if it would then have good flipping geometry, especially since that part of the choil already comes into the lock area when closed.
Literally laughing at this.
But with enough butter...🤔
fanglekai
Postby fanglekai » Fri Mar 22, 2019 9:48 pm
Thumb in the Spyderhole makes more sense.
JacksonKnives
Location: Formerly Alberta, now Orange County, California
Postby JacksonKnives » Sat Mar 23, 2019 12:05 am
...wonder if the front lip of the choil could be made bigger into a flipper tab...
I've glued dowel pieces to a few compression lock knives, and it works pretty well. With a small enough tap you could make a bolt-on piece.
The funny thing about re-purposing a Spyderco into a flipper or front flipper is that you start to realize how much better the hole is.
The only advantage the front or lip flipper has is the possibility of a narrower blade profile. Since the Shaman or Yojimbo or whatever else you think about modding already has the wide blade for the hole, there's not much to be gained unless you really want to grind down the spine of the blade.
dj moonbat
Postby dj moonbat » Sat Mar 23, 2019 8:43 am
The thing that makes the hole so good is that your hand can go from opening the knife to the cutting grip all while maintaining a reasonably solid grip on the handle. A flipper tab may get the blade open faster, but it's a separate motion to get your grip around the handle. By the time that motion's done, you haven't really gained any time.
Users browsing this forum: bearfacedkiller, Bing [Bot], cwoods, Google [Bot], JuPaul, kennethsime, marshy, MSN [Bot], prndltech, Spydergirl88, Stoney, Tabo and 21 guests
cron
