Thanks for reporting back! Great, that you're finally really using your Manix at work!Cao87 wrote: ↑Tue May 14, 2019 4:47 pmMay 14 2019 Update on my manix 2 I brought it to work for the first time and it is great. It is still stiff but I am still getting used it. It is razor sharp so I don’t have to put much pressure on the shrink wrap to cut it. It looks like it will slice through cardboard. Also since I wear gloves my thumb isn’t irritated much. I just have to see if will cut through the strapping, last thing it is really easy to open with one hand, I just have to get used to closing with one hand
As for "... just have to see if it will cut through...": If a properly sharp Manix won't, probably no other folder will either...
