The delica is definitely not a dragonfly XL. One has a 50/50 choil, and the other does not. Dragonfly XL would be more like a Chap or Native than a Delica.
Maybe you should go back and read the post about it being like a modified Delica again, I think you missed the "modified" bit.
I was responding to the following:
Re: What would you want a Dragonfly XL to look like?
by bdblue » 13 Feb 2019 19:18
I think it would look like a Delica.
I don't see anything there about modifications.
For me, the Delica and Dragonfly have completely different ergonomics. Saying "the Dragonfly XL would just be a Delica" missed the point of preserving the ergonomics of the Dragonfly. If you eliminated the 50/50 choil, you'd no longer have anything close to a Dragonfly.
the dragonfly has a forward choil and a surprisingly full grip. the manix 2 lw has the same choil and better ergonomics i would expect from a larger dragonfly. it also has a leaf shaped blade. it also has a wire clip. it also has the same texturing in the grip. it also has a thumb ramp, though it is slightly less pronounced since the grip is bigger. it also shares a similar blade angle.
clearly it’s not the same knife, but it shares a lot of traits that make them both great. don’t be so dismissive.
The Dragonfly, Chaparral, Native, Manix 2 and Manix 2 XL have always seemed to me to be very close to the same ergonomics, just in increasing size. I've identified them because that's my preferred set of ergonomics. There are variations in length and thickness, but they all have the "like a glove" feeling in my hand (except maybe the M2 XL, because my hands are too small for it).
You did not specify who you were replying to in your original post and the first post after the OP was about it looking like a modified Delica...
Anyways, I would like to see an XL Dragonfly, however it looks.
All of those knives, except the dragonfly, get a convex swell in the handle where the ring finger goes. The concave, scooped out handle of the dragonfly is one of the main reasons the ergos never worked for me:
The area that I circled always felt way too narrow for my grip, even conpared to relatively thin handle designs like the Caly Jr. I gifted my last Dragonfly to a family member, its been serving them well.
Ok so while waiting for Farcry New Dawn to download I decided to pull out the ol' light table and whip up a really poor sketch. Believe it or not I am something of an artist and I even took mechanical drafting once (Mr. Shinkle if you're reading this I am so sorry for this line quality) but this should get the point across.
As I said before, change as little as possible, just make it longer where it counts and don't lose the basic ergonomic feeling and flavor of the design. I added a half inch to the blade and handle, and tried my best to mimic the curves of the blade edge/spine and even copied the same shape at the butt of the handle, I just dragged them outwards a half inch and filled in the space between. Interestingly enough this got rid of the little point on the bottom butt end of the handle and make it much more round, sort of like a larger Lava handle where it gives you a nice ball shape to grab onto.
In the top sketch I did the best I could to copy the actual size of the Dragonfly 2, though it is just slightly larger (maybe 1/16 inch larger overall). The red shows where I added, the bottom is the finished product. I tried to keep the point in the same general area so as not to change the blade angle any.
I really feel like this has serious potential. For example, Vivi's problem with the cramped area of the handle is basically solved by this, since your hand will just follow the curve of the grip around to the butt and would no longer be locked in by that little point. It also looks like it would provide most average sized hands close to a full grip behind the choil (and definitely give a full grip when on the choil). The larger butt end would fill your palm better and prevent the knife from slipping out of your hand during pull cuts.
My well sharpened Dfly blade measures in at 2 3/16 inch and was likely closer to 2 1/4 inch when new. My sketch measures out to about 2 3/4 inch blade length with 2 3/8 inch cutting edge. That puts it just a bit smaller than a Delica, so I'd still consider it to be a small knife, it would just be a bit more versatile in XL form.
Oh and according to Wikipedia, the largest species of dragonfly is the Megaloprepus caerulatus, so I think "Megalfly" or just simpley "Megafly" would suffice but we can go with Dragonfly XL too :D
Being a very ergonomic handle as it is in the standard grip I found the only real issue is the first hump when using the choil so a little work did away with that and left the back a little thicker and bam. Feels great
I noted that when using the choil one of the humps got in the way just a little so it makes sense I guess that a more dragonflyish handle would suit it.
I did leave it a little straighter however as the handle isn’t small like that of the dfly so there isn’t a need to add that hollow and as the handle increases in thickness it actually fills the hand quite well when the hand shifts up to use the choil.
" Megafly " .... cool :cool:
Marius
( Rabindranath Tagore ) Proud member of the old school spyderedge nation
That looks great!! The blade dimensions would be quite similar to the Chap; If your model existed, I really would not know if I´d decide for that one or the Chap for my smallest / IWB carry knife... Chap beeing thinner / slimmer and probably a better slicer due to the thin stock, DF XL beeing lighter (linerless) and having a sturdier blade; The relation "cutting edge to closed lenght" would still be better in the Chap as far as I can see.
As stated previously, when I had to decide between Chap FRN and DF, the Chap mainly won due to the longer edge; the existing DF is not much shorter when closed, but the edge is significantly shorter than the one of the Chap; so much, that the Chap is really more usefull for my personal needs.
With YOUR DF XL that would be a whole different story...
So cool, I love it. It seems to be very similar to the Caly 3, perhaps they've already realized this and decided they would be too similar / they already have created a Dragonfly XL, and and it is know as the Caly we have now.
"Sometimes I think that we're all little kids trying to act like grown ups, in our parents clothes. "
It does seem a lot like a Caly 3 now I think about it. For that matter the FRN UKPK is just a tiny bit smaller and also linerless so aside from the lock it's pretty close too.
