Two things that today cannot be done.
steeljustice
Postby steeljustice » Wed Jan 23, 2019 10:58 am
One: improve the Spyderco Pm2.
Two: Exceed the speed of light.
bearfacedkiller
Re: Two things that today cannot be done.
Postby bearfacedkiller » Wed Jan 23, 2019 11:15 am
Contoured scales?
Fluted Titanium with integral compression lock?
curlyhairedboy
Postby curlyhairedboy » Wed Jan 23, 2019 11:27 am
Correct, because tomorrow may bring the tanto PM2 ;)
EDC Rotation: PITS, Shaman, CF S90v Shaman, Ikuchi, Amalgam, CruCarta Shaman, DLC Lil Native, Sage 5 LW, 4V Shaman, Rex 45 Shaman, Rex 45 Lil Native, Serrated Caribbean Sheepsfoot CQI, Tanto PM2, Serrated Shaman, XHP Shaman, DLC XHP Shaman, REC Shaman, Smallfly 2
Always in Pocket: Hawkbill Dragonfly 2 H1
Fixed Blades: Proficient, Junction, Waterway
Special and Sentimental: Southard, Squarehead LW, Ouroboros, Calendar Para 3 LW, 40th Anniversary Native, Calendar Watu
Sumdumguy
Postby Sumdumguy » Wed Jan 23, 2019 11:31 am
Contoured scales?
I want to see a new titanium compression lock aswell, I hope that's what the larger Caribbean is. No holes in the scales though.
I would buy a tanto PM2, but otherwise I'm not interested in more PM2s.
-Thomas Jefferson
koenigsegg
Postby koenigsegg » Wed Jan 23, 2019 1:26 pm
Contoured handles would be sick, I think maybe a wireclip and squeeze a bit more edge into the handle
ugaarguy
Postby ugaarguy » Wed Jan 23, 2019 4:22 pm
The PM2 doesn't feel very good in my hand. I think the Shaman was a vast improvement. I also agree that a Ti frame with integral compression lock would be a huge improvement.
Doeswhateveraspidercan
Postby Doeswhateveraspidercan » Wed Jan 23, 2019 4:32 pm
#1.Find an Orange Handled DLC PM2 in CTS-XHP for a reasonable price.
#2. Reopen the Government.
Postby vivi » Wed Jan 23, 2019 5:05 pm
Switching to a back lock would make me put a PM2 back in my rotation.
I miss owning one, it was a nice knife for when I wanted a tiny and unobtrusive carry, but the lock gave me issues.
Join us at the Spyderco Swap!
Current favorite: Pacific Salt
Bloke
Postby Bloke » Wed Jan 23, 2019 5:15 pm
This is contrary to popular belief and brothers SpyderEdgeForever and Pelagic are working on a Sheepsfoot PM2 with Tanto tip and possible serrated edge as I type. :cool:
Tucson Tom
Postby Tucson Tom » Thu Jan 24, 2019 12:00 am
I agree with the OP with a whole heart. The PM2 is just amazing. I was actually going to post my own "ode to the PM2" after laying on my cot
opening and closing one of mine. The blade is the perfect size to my taste. The compression lock is probably the most clever lock there is.
The knife fits my hand nicely (I know this varies with individuals). The Manix fits more like a glove, but the PM2 is friendly and comfortable.
The CBBL is awkward to close with one hand (possible, but tricky). The compression lock is straightforward. The backlock is absolutely impossible.
Not that I often find any urgent need for one hand closing (it can be handy when the other hand is holding something and you want to put the knife back in your pocket). I admire the strength of the backlock, but it loses points on closing.
As for a PM2 with contoured handles. I think that might just be the Shaman. And as for Tanto and Sheepsfoot variations, I guess that is fine,
but I view them as interesting variations, not improvements.
Postby vivi » Thu Jan 24, 2019 12:19 am
:confused: :confused: :confused:
Here's two ways to easily close either with one hand. You can also activate the lock release and push the spine of the blade against your leg
Tucson Tom
Postby Tucson Tom » Thu Jan 24, 2019 12:44 am
Thanks Vivi --
You set me to practicing. The reach to the hole for the backlock is tricky, and I have to take care so my other fingers don't wander into the way of the closing blade. The same is true of the CBBL if I try to use a finger to push it close. Both can be done nicely if the knife drops free. My Manix drops free with ease. The Manix backlock only does so if you really fully depress the lock bar. So, thanks for showing the way.
But I still maintain that the compression lock is literally made for easy one hand closing.
Bloke
Postby Bloke » Thu Jan 24, 2019 12:45 am
I’ve had an absolutely perfect S110V PM2 since they first came out. I’ve carried it maybe a dozen times and it still sports a factory edge. I don’t know what it is but I prefer the Stretch 2 even though I like the compression lock over a back lock and I prefer the Military to the Stretch anyhow. Ah, hahaha! :)
I won’t buy another one and certainly not a Tanto or Sheep’s Foot. :rolleyes:
Postby vivi » Thu Jan 24, 2019 1:07 am
Thanks Vivi --
It takes some getting used to, but with practice it should become second nature. I use the method of keeping my index finger in the spydiehole to close all of my backlocks. This lets me ensure the blade doesn't swing into my fingers, because I can control how much it travels manually.
elena86
Postby elena86 » Thu Jan 24, 2019 4:41 am
As much as I like PM2 as it is, I must boldly affirm that it can be improved big time :
1. Thinner blade stock(3.2mm instead of 3.7mm) and thinner behind the edge when profiled at 15dps( 0.02 inch instead of 0.08 )
2. Better blade to handle ratio
Marius
" A mind all logic is like a knife all blade. It makes the hand bleed that uses it " ( Rabindranath Tagore )
Postby Wartstein » Thu Jan 24, 2019 5:15 am
Thanks Vivi --
I find the backlock very easy to close with one hand, but that´s probably just because it is my favorite and byfar most used locks.
Additional to the methods Vivi described, there are several more I use:
- My most used one: Close the blade halfways while keeping you index finger in the spydiehole; then rotate the knife by 180 degrees in your hand, so that the back of the handle faces downwards; while rotating the knife, your index finger automatically gets out of the hole and with the other 3 fingers to the side of the handle, the thumb to the opposite side of the handle; than put your thumb in the hole and close the knife (the other 4 fingers are automatically out of the way) by pulling the blade downwards
- Just one more, before it gets to long winded: Close the blade halfway again with your index finger in the hole; then put your thumb on the other side of the hole and do some "reverse Spydie-drop", so flick the handle upwards towards the edge and close the knife by doing so
Top three going by pocket-time (update July 21):
- EDC: Stretch 1 in VG10, Tenacious LW in S35VN, Endela SE in VG10.
- Mountains/outdoors: Pac.Salt 1 SE in H1, Endura in VG10 (Micarta scales), Salt 2 SE in LC200N
Postby Doeswhateveraspidercan » Thu Jan 24, 2019 7:46 am
1. Hear the clatter of the coin that is the final down payment on a woman’s happiness.
2. Benefit from being right in an argument with your wife.
Those are two things that cannot be done today! :)
https://imgur.com/gallery/wFfDhMk
Crux
Postby Crux » Thu Jan 24, 2019 10:48 am
Except, then came the Para 3, which came and broke the speed of light.
BornIn1500
Postby BornIn1500 » Thu Jan 24, 2019 11:49 am
Make the tip more stout so there are less snapped tips. Chamfer the edges of the g10.
Postby JD Spydo » Thu Jan 24, 2019 12:51 pm
Really I couldn't have said it any better myself. Even with all the fanfare and "hoopla" going forth about the PM3 model I just have to seriously scratch my head because personally when they shortened the blade on the PM 3 it just made me cringe :( .
Now I'm much more of a C-36 Military fan than I am a PM2 fan>> but I do agree with you when they introduced the PM2 they truly hit that one out of the park with two men on base :cool: I'm keeping two of the PM2 models in my arsenal just in case I was to have to move or temporarily be located at a place where they have draconian, non-Constitutional knife laws :mad: >> then I'll have a good piece of hardware to get me by till I can get back to the love of my life which is my M390 Military :cool: But the PM2 with S90V or S110V do make great back up units needless to say.
Users browsing this forum: Brock O Lee, dkelley661, eventhorizon, Google [Bot], knifemovieguy and 73 guests
