questions about serrated blades...
- lonerider1013
So... got my 2nd native5. This one is half serrated and also has a dark coating. Some questions..
I've never had a serrated blade before... I like it, but how do you sharpen it?
2nd, how durable is the coating?
btw this is an s35vn version...
Lonerider
Lonerider
"A fool's blade may be sharper than his brain"
“Learn to ride a bicycle. You will not regret it if you live." - Mark Twain
Re: questions about serrated blades...
I use the Sharpmaker. It's really just as simple and easy to sharpen SE as plain edge.
Have you watched the Sharpmaker video? In it, Sal demonstrates how to sharpen serrated edges.
- Connor
- lonerider1013
I'll have to watch that. This serrated thing is all new!
Easy, and once you get them sharp, you’ll enjoy them. The coating scuffs, but doesn’t seem to wear off. Mine is quite scuffed, but still looks great. I’m considering a PE now in the same model. It’s kind of my new favourite.
Enjoy it. Here’s mine...
- best wishes, Jazz.
There are a lot of sharpening methods and products out there, but for serrated blades the Sharpmaker is the most common (only?) option.
To sharpen serrations you need triangular rods, according to what I've read here (don't have any sharpening equipment of my own yet).
The black DLC coating on the Native is fantastic. If it ever looks like you've scratched it, then it's likely just the material that scraped against it leaving a trail of itself behind (like chalk would if you rubbed it over sandpaper). Scrub it with a toothbrush and maybe some soap or oil or other solvent, should clean it right up.
I have only one knife featuring serrations (Delica CE); No problem to keep those sharp on the sharpmaker.
One thing I wonder: Will the tips of the serrations get rounded over time when dragged across the corners of the rod during the sharpening process?!
Basically you use the corners of a sharpmaker stone with a normal stroke. You DO NOT need to sharpen serrations individually.lonerider1013 wrote: ↑Fri Jan 11, 2019 6:37 pmSo... got my 2nd native5. This one is half serrated and also has a dark coating. Some questions..
Lonerider
Aside from that, the biggest difference is you sharpen the presentation side about 4-5 strokes, then do a nearly flat to the stone pass on the back side with no bevel on the SE portion.
Here is a video that goes into further detail:
https://youtube.com/watch?v=Ptmx1iJELhU
Yes.
Two things to note though:
The effect isn't as pronounced as you'd expect. I have a 12 year old Tasman Salt SE that's been reprofiled twice and used as a beater for over a decade, and the rounding is not extreme.
I think this imrpoves the function of the knife. Slightly rounded tips on a SE knife reduce the snagging that can happen on certain materials like cloth, and they don't cut any worse.
Agree Slightly rounded tips improves the knife for the reasons you stated.Vivi wrote: ↑Mon Jan 14, 2019 3:10 amYes.
I’d go so far as looking at some new knives, I’d actually round off some of the points quickly, either by hard use or with a stone.
Thanks! That´s an interesting and reassuring observation. Since I only have ONE knife featuring serrations, I can not compare new and slightly rounded serrations against each other obviously, so it´s good to know that slightly rounding them is not an issue.Vivi wrote: ↑Mon Jan 14, 2019 3:10 amYes.
