Page 1 of 1
Spydie Logo Differences - Golden vs. Taichung
Posted: Fri Jan 11, 2019 8:20 am
by Zatx
I purchased a digital microscope for experimenting and improving my sharpening skills and thought I would document the differences between the Golden and Taichung manufacturing facilities when etching the Spyderco logos.
This first image is at 40x magnification. The left logo is on my Amalgam which is produced in Taichung; the right is from my REX45 PM2 manufactured in Golden Colorado. I have acid etched this blade to create a beautiful patina so the coloring will look different than the S30V Amalgam.
This second image is at 250x magnification (same layout - Taichung Left - Golden Right).
The differences are apparent, but also understandable. Laser engravers that are capable of the quality found used in Golden are extremely expensive so that cost is factored into the price of every knife. If Taichung were to purchase such a machine, their costs would go up as well.
Re: Spydie Logo Differences - Golden vs. Taichung
Posted: Fri Jan 11, 2019 8:37 am
by The Deacon
And yet, some folks think the Taichung logos look better because they appear to be more intricate than the ones on Golden or Seki Spydercos.
Posted: Fri Jan 11, 2019 11:05 am
by Sharp Guy
I'm curious what digital microscope you purchased. I've been thinking about picking one up so I can see how the edge of my knives look microscopically. I don't want to spend too much money but I want something that actually works.
Posted: Fri Jan 11, 2019 7:56 pm
by ronT2
The Deacon wrote: ↑Fri Jan 11, 2019 8:37 am
That would be me. I just like the Taichung logo better and of all things the web like design.
Posted: Sat Jan 12, 2019 2:12 am
by JacksonKnives
The contrast and sharpness of the laser mark really look great with that etch.
I also am fond of the Taichung engraving. Neither is "better," but I always like seeing a toolpath turned into a beautiful pattern. Maybe it's because a photo etch and laser etch seem so trivial to accomplish, while the CNC programming seems (to me) to involve more careful planning.
Doubtless there's a lot of money and skill that went into each.
Posted: Sat Jan 12, 2019 3:01 am
by 500Nitro
Can you post the two logos from normal eyesight range ?
Posted: Sat Jan 12, 2019 8:14 am
by The Meat man
Zatx- very interesting images. Thanks! I'm looking forward to seeing your edges under the microscope.
BTW, what microscope is it? I'm curious too.
Posted: Sat Jan 12, 2019 8:38 am
by Zatx
The Meat man wrote: ↑Sat Jan 12, 2019 8:14 am
Here is a picture of the edge that came on my new Amalgam. This is the sharpest knife I've ever received from the factory, and the image reveals why; it is entirely devoid of a burr without a micro-bevel, which is remarkable.
Posted: Sat Jan 12, 2019 9:50 am
by JonLeBlanc
Interesting pictures, I also think the Taichung engraving looks cool. Another interesting observation I've had is the coloring of the engraving on the 52100 PM2; it has a golden-ish cast to it that looks really good against the satin gray of the carbon steel. I almost wish it was more apparent or brighter whatever, and if all spydercos had that I think it would be cool too.
Posted: Sat Jan 12, 2019 10:39 am
by Zatx
JonLeBlanc wrote: ↑Sat Jan 12, 2019 9:50 am
I have the 52100 PM2 as well and examined it with the microscope. The discoloring looks like it's caused by both burning and oxidation/corrosion. I wonder how deep the heat from the laser or machining tool affects the heat treat (not that it matters way up on the blade).
Posted: Sat Jan 12, 2019 10:59 am
by Joey
I’ve noticed that on my 52100 PM2 as well, and wondered if it was chosen because of the handle material (full CF)? Either way I think it looks so neat in comparison to other blades from Golden.
Nice pictures! What are the specs on that bad boy? I need a good microscope too. My 10X loupe shows the neat engraving, but I want something that zooms in further.
Posted: Sat Jan 12, 2019 2:15 pm
by JonLeBlanc
Joey wrote: ↑Sat Jan 12, 2019 10:59 am
Yeah doesn't it look cool on the 52100!? Gives a nice little flash of color. I have two 52100's, one is pristine and the gold hue still shows brightly and the other is patina'd so the gold is mostly dulled which is interesting given what OP said about it looking like oxidation under his microscope.
Posted: Sat Jan 12, 2019 3:47 pm
by The Meat man
Zatx wrote: ↑Sat Jan 12, 2019 8:38 am
What's the magnification on that?
It does look like a sharp edge. I wonder what grit finish that is.
Posted: Sat Jan 12, 2019 4:17 pm
by Crux
Took this pic with my phone. :)
Posted: Sat Jan 12, 2019 7:18 pm
by Zatx
The Meat man wrote: ↑Sat Jan 12, 2019 3:47 pm
It's around 250x. The grind marks coming out of Golden look to be around 600 grit, the ones from Taichung look closer to 800-1000.
Posted: Tue Jan 15, 2019 7:19 pm
by gundamaniac
Wow, nice images Zatx! I too find the logo differences quite interesting. I always thought it was really neat that Spyderco took the tool path for their Taichung logos and made it part of the design, adding a sort of texture to the logo. I like both the Golden and Taichung blade logos.
That said, I prefer the clips on the Golden knives; the ends of the clips are shaped slightly more pleasingly aesthetically than the Taichung clips in my opinion, and I also prefer the logo on the Golden clips.
Posted: Wed Jan 16, 2019 10:39 am
by Zatx
gundamaniac wrote: ↑Tue Jan 15, 2019 7:19 pm
After you posted this I took off the Taichung clip and put on a Golden; I didn't care for it as much. The Taichung end is lower and flatter, so it doesn't hang on stuff as often. Also, the Taichung version sits lower/closer to the knife scale which also helps with avoiding bumps/snags.
