Chaparral Raffir Noble scales
Can the Chaparral's Raffir Noble scales be changed to the ones from the carbon fiber model? I can't decide between the two, and if that can be done, it solves my problem. Thanks!
Re: Chaparral Raffir Noble scales
I don't know for sure, but I think probably yes? Take a close look at the scales in photos and check if all the screwholes seem to line up, first.
With both models having the exact same xhp blade steel, what are you trying to achieve?
Currently have 163 :spyder: 's & 41 different steels.
Bench Stones Atoma Diamond Plate 140,400,600,1200. Naniwa Chosera 400,800,1000,3000,5000.
Shapton Glass 1000,6000. Suehiro Rika 5000. Shapton Pro 320,1000,2000,5000,8000.
Naniwa Bonded Diamond 400,600,800,1000,3000,6000. Venev Gen2 OCB Combo Diamond 800/1200.
Spyderco 306UF, 306CBN. Doublestuff2 303FCBN2, & 204MF Sharpmaker w/204CBN for Spidie Edges.
Want List Steels 15V, S125V, K490, M398, Magnacut, S390, SRS-15, Vanadis 8, Vanax SC, Vancron SC,
Hi Moneyman,
Welcome to our forum.
Apparently the Raffir Noble is a bit delicate, so I'd like to use the carbon fiber for everyday wear, and then put on the Raffir Noble for fancy occasions.
Thanks for the kind welcome Sal. I appreciate it.
- The Deacon
Spyderco does not sell things like scales. So, even if they're interchangeable, unless you know of someone who had custom scales made for a CF Chaparral and is willing to sell you the originals, there would be the question of acquiring the CF scales.
- RadioactiveSpyder
Interchangeable? Yes. Certainly folks around these parts with custom Chap scales too! :)
I just assumed that replacement scales were available. So if you damage the scales on a Spyderco, what do you do? Aftermarket scales are the only option? That seems...odd. Is that standard policy in the industry?
My Cat has a good-sized chunk out of one scale. Again, I thought I could just call the outlet store and get another one. I'd be surprised if there are aftermarket scales for the Cat. Nuts.
