How well does the brown/tan G10 take color?
Looking to try for an OD green color, or close to.
Not sure how well the brown scales on my Para 2 will take color. Rit says to use green and brown mixed to get an olive green color, so I wonder if the brown in the handle will affect the color, and just using green would be enough.
Re: How well does the brown/tan G10 take color?
Gave it a go.
The Rit Dyemore for synthetic materials worked pretty well. Their green is called Peacock Green, which is a darker green. Already close to OD as it was. I mixed it strong, half the bottle to only a few cups of water, with a little vinegar in there as well.
After two minutes, the color was an OD, but with a bit of a muddy brownish look, from the original brown underneath.
An extra minute made for a darker drab green color. A bit darker than typical OD, but I like it.
There is a very little bit of the brown peeking through on the edges, as they don't take dye as well, but it looks good.
I actually liked the result at the 2min mark, but wanted a bit less brown, two and a half minutes may have been perfect for me, but I am happy with the results.
Picture?
Dream as if you'll live forever. Live as if you'll die today.
James Dean
James Dean
This got me thinking that I need to dye my natural g-10 PM2 to red! Did you heat up your concoction like the directions indicate?
Just get both and have the best of both worlds!
15 's in 10 different steels
Yes, heat to a low boil, a little vinegar, I used about a quarter cup for the 3 cups of water.
I hear a little soap can help as well, but I would use only a small amount, not enough to bubble. I didn't use it, and it worked fine.
Dye for synthetics is best as well. Should permeate further.
Same boat contemplating navy blue on the earth brown S35VN Paramilitary 2 and going to DYE my Military in natural G10 with M4 steel Navy Blue it should come out nice.
If they do not I can always dye them black.
wow I always thought the Earth brown was a good looking color ..one of my favorites!
Not that I dislike the color, but I got the color for two reasons, the blade steel, and the ability to change to a darker color if I chose to do so. ODG is a favorite, not the most, but maybe #2 on the list.
Here is a look.
The color isn't exact to real life in the pic. In person under neutral light like sunlight it is a drab green, under interior lighting it seems a bit more drab and darker green.
That turned out very nice, good job.
I do like the knife a lot. Very balanced. The color is icing.
